Glasses in Rain
Glasses in Rain
It rains a lot where I am. So I ride in the rain quite often. In hard rain it is difficult to see with my prescription glasses.
Anybody have some good tricks for keeping glasses usable in the rain?
Mike
Mike
Quoted: 4862 Post(s)
Liked 4,011 Times
Periodically wipe the lenses with your finger to get an even film of water, not droplets. (In cooler weather, consider wearing gloves that wipe well or that pull off easily so you can use your finger. Visors can help a lot in some rains for a while. In the daytime, Polaroid sunglasses often work well.
I've been battling this challenge for 55 year. Some rides are simply losers and I have to slow to safer speeds but I usually get the finger wipes close to right. Some rains require repeats often. I've thought about wipers many times but haven't put the inventor's cap on yet.
climber has-been
Quoted: 3549 Post(s)
Liked 3,704 Times
Likes For terrymorse:
79pmooney, thanks. You are right - some rides just are too much. I am particularly concerned because I ride in brown bear country and want to be able to see up the road a bit. I will have cataract surgery soon which will hopefully do away with the prescription glasses, but I still will need to wear protective glasses and deal with rain.
Terry, I will give RainX a try. I know it worked well on the pilot house windows of my commercial power troller but it never occurred to me to put it on my glasses. I think you are on to something.
Mike
Mike
Quoted: 20810 Post(s)
Liked 9,456 Times
I often just take my glasses off in the rain, but I guess that doesn't work too well if you need the corrective lenses.
Just Pedaling
Bikes: YEP!
Quoted: 351 Post(s)
Liked 567 Times
I have a small thick pad of paper towel in my vest pocket that I pull out and run over the front of my glasses. It gets soaked fast, but it still improves visibility even soaked better than a finger most times. My gloves just don't do the trick. There is something that I use in my ski goggles for fogging up called 'Cat Crap'; but it doesn't help much with rain.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2668 Post(s)
Liked 5,883 Times
I have a small thick pad of paper towel in my vest pocket that I pull out and run over the front of my glasses. It gets soaked fast, but it still improves visibility even soaked better than a finger most times. My gloves just don't do the trick. There is something that I use in my ski goggles for fogging up called 'Cat Piss'; but it doesn't help much with rain.
RainX is not recommended for use on plastic so repeated use may damage the lenses. Check your local optical shop for recommendations.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Liked 4,011 Times
Yes, paper products make glasses old fast. (You can dab off clean water with a paper towel but don't try to get the lens dry or wipe at all.)
The drawback to RainX is that if you do wipe it, it smears and makes your glasses opaque until you clean then with soap/detergent. At least that was my experience years ago. No something I ever want to repeat. That was mid-ride and the rest was one of the most blind rides I've ever done.
actual wipers exist that slide on over your finger or riding glove, but this is more of a mud-riding thing. In regular rain the smooth finger wipe, with or without an absorbent glove seems to work best for me as mentioned above.
Finger Visor Wiper on Amazon
Longbikes Slipstream
Likes For Wilbur Bud:
Quoted: 6330 Post(s)
Liked 4,926 Times
I use to keep a large cotton handkerchief or bandana in my back pocket for blowing my nose and for cleaning my glasses. That was before I became a champion snot rocket blower. <grin>
I also agree that paper towels are among the worst things to clean lenses with. Cleaning lenses with paper towels, my safety glasses and sunglasses won't last two weeks before they are all scratched up. With cotton rags, they easily last a year maybe two before a arm or something falls off the glasses. Even the very cheapo glasses I wear for cycling.
Maybe narrower glasses with smaller lenses so they are less of a target for rain drops?
Grupetto Bob
Liked 5,883 Times
Quoted: 3261 Post(s)
Liked 2,576 Times
Wear a brimmed cap under your helmet. It will act as an awning.
Likes For seypat:
Quoted: 1000 Post(s)
Liked 1,679 Times
Rain on the glasses no problem... Its the mud that gets me...
Likes For Pratt:
Pratt, contacts worked as a younger man, but not so much as I graduated (or devolved) to bifocals and then trifocals. I am scheduled to get single vision lens as part of cataract surgery in a month. I will need to use reading glasses, but I am fine with that, But I will still need glasses for riding, probably some sunglass variant. And those glasses will still have rain issues. I am a roadie, by the way.
I haven't picked up RainX yet, but will give it a try soon and will be mindful of the kind input herein.
Mike
Mike
climber has-been
Liked 3,704 Times
A couple of taps of the glasses on my thigh, and the water beads up and falls off the lenses.
Likes For randallr:
Liked 4,011 Times
Contacts. I will never wear them for a reason that might be unique. In junior and high school I played ice hockey goalie. Wore glasses then so I had the funky cage. Funky but well padded. Very hard hits between the eyes didn't hurt at all. (My armor had a lot of *****s where successfully blocked shots hurt for days. But those cages worked. In fact, so well that now all the pros use them.)
But - if I blinked when that shot hit, I would have no idea where the rebound went. I might be 3 feet from where I needed to be to block the next shot. So ... I taught myself not to blink and it worked. I could watch the puck come in, hit the mask and be moving instantly to stop the next. Drawback? I still don't have a reliable blink reflex; certainly not one I would trust my vision to. Glasses have bailed me out many times.
Likes For 79pmooney:
Quoted: 514 Post(s)
Liked 652 Times
Yes, and also keep the helmet low on your forehead so it is almost touching the glasses. That way, the upper portion of the glasses will be much more sheltered from the rain. This works whether you wear prescription glasses or just sunglasses. It greatly improves the ability to see.
I will give the brim capped/ low helmet style tomorrow. Plenty of rain in the Tongass Forest temperate rainforest.
Mike
Mike
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Quoted: 215 Post(s)
Liked 204 Times
Mike
Mike
There used to be a liquid called Formula 303 that we used on kayaks and boat hulls that was a UV protectant, and it shed water and made the paddling easier. But I was not risk it on expensive non-glass-lensed glasses.
