Show Your Miyata 1000!
Bikes: 1984 Miyata 1000, 1984 Univega Specialissima (frame), 1993 Miyata 1000LT, 1987 Raleigh Ventura, 1935 Golden Sunbeam, Early '50s Columbia Bomber
Quoted: 19 Post(s)
My 1984 1000 looks a lot like Badger Bike's, but with a smaller frame. I found it in a bike shop in suburban Norther Virginia in the mid 90s. I wasn't expecting to find anything worth buying but I had lusted after one of these for a lot of years. I saw the "Miyata" decal and looked right past the mattress seat and the bomber handlebars. It looked like someone had bought it, set it up for their mom, then put it away. It had very few miles on it. I casually asked the guy behind the counter how much he wanted for it. When he said ""$150" I nearly choked. But I hid it well and offered him $100 cash. "Sold." I paid up and took it out to my car as quickly as I could. A Brooks B17 and a pair of Nitto Randonneur handlebars and I was all set. It did not disappoint. I have since altered the gearing a bit as a concession to my advancing age. I found a NOS Shimano 14-34 5-speed freewheel somewhere then swapped out the chainrings for 48-38-24. It's just about my ideal touring bike.
I thought about naming the photo "A Tale of Two Mi(y)atas."
Oddly enough, I found my 1993 1000LT a couple years later in another bike shop about 10 miles from the first one. Sadly, I had to cough up $150 for the '93...
Likes For WGD:
Dedicated Detritus Dodger
Bikes: Some mighty fine ones at that!
Quoted: 192 Post(s)
Liked 610 Times
This is a 1981 Miyata Gran Touring that I bought as a frame on eBay. All parts were cannibalized from a 1979 Centurion Super LeMans and a Univega Alpina Pro.
1981 56 cm Miyata Gran Touring double butted CroMo frame with 1024 hi-ten fork and Tange Falcon headset and Sakae Laprade seatpost. From eBay.
Sakae Randnnr bars and SR forged stem from Centurion Super Lemans.
Suntour Barcon bar end shifters from the same Centurion.
SR Apex 52/40/28 triple crankset from eBay.
MKS Quill pedals with Christophe straps from Centurion.
Suntour AG tech front derailleur from Univega Alpina Uno
Suntour AG tech rear derailleur from Univega.
Diacompe 980 cantilever brakes from Univega.
Suntour Tran-Z gold 14-30 6 speed freewheel from Centurion.
27 x 1 1/4" Araya rims laced to Suntour sealed bearing hubs, 40/36 spoke from eBay.
Soma Ta-Bo saddle from Salvation Army.
Bikes: Bianchi San Jose - Di2 Alfine, 1985 Eddy Merckx Corsa Extra, 1984? Miyata TerraRunner, 1986? Miyata 1000, 1988? Fuji Opus III, Nishiki International
Quoted: 49 Post(s)
Liked 8 Times
Does anyone on here with a 56cm frame want to measure the top tube and seat tube for me? I have a lead on a very cheap original owner 86' in about a 56cm, I usually ride a 54, so I was just curious.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Quoted: 49 Post(s)
Liked 8 Times
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
i'm a long legged 5'6 and change and ride a 56cm triple cross (also a miyata with very similar to touring geometry). it measures 55cm center to center at the seat tube and 55cm center to center on the top tube. iow's, if you're 5'9, i'd venture a really good guess that frame you're looking at will fit you....provided you have the leg length to stand over it. my fit troubles are a short torso. so, i utilize shorter stems and sometimes shorter reach bars to get things to fit....ie. bigger frames. i can't see you having that issue, though
Quoted: 49 Post(s)
Liked 8 Times
Quoted: 192 Post(s)
Liked 610 Times
My blue Miyata Gran Touring pictured above is appx. 57 cm c-c seat tube and top tube. The standover with 27 x 1 1/4 Vittoria Saffiro tires is 33". I am 5' 10" with long legs and I have an inch or two of clearance over the top tube. Unless you have really long legs, 54 cm sounds more appropriate.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
i recall from the catalog i could find my triple cross being tagged as a 56cm. i guess it gets down to how measurements are made and sizing is considered. but, if that miyata he's looking to is a 56cm center to top....or even center to center...on the seat tube, i would say it should fit him even if on the larger side of frames for a given rider. 32" of stand over is the largest i'll go, but then with shoes i'd have about an inch of clearance. my schwinn with a 56cm top tube i can ride with an 80mm stem and 75mm reach bar just fine. 54cm frames even i have a hard time getting bars up to saddle height with standard quills. i have to use a riser
Quoted: 192 Post(s)
Liked 610 Times
you said above, though, it's a 56cm . so, yours would actually be more of a 58cm, then....measuring center to top, that is
Indeed, the Miyatas of that time had frames that were measured in inches rather than cm's. My frame is a 23", with the seat tube measured from the center of the BB shell to the top of the seat tube. Appx. 58.5 cm. The next size down is a 21" and that would be slightly less than 53.5 cm. I'm not sure what year Miyata started using the metric system to measure their frames, but at 5' 9" tall, a 32" standover still seems too big. Of course, every body is different, yada yada, but safety and comfort being top priorities, I would say err on the side of more standover.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
mine is an '89. as you can see, the frames are in metric and jump in 2cm increments from medium to large sizes. and, they have to be measuring from center to top on the seat tube because, again, my frame measures 55cm c to c square.
so, yeah...i can see where the year of the frame/how it's measured and the sizing increments would certainly make a difference. to jump from 21" to 23"? wow...yeah, that's a big difference! kind of a bummer, really. a 21" frame is on the small side for my longer legs. a person at his height of 5'9? seems even smaller
1" of SO clearance is safe enough for me on a road bike. as for comfort, long as the handlebars can come up to the saddle and i can balance over the bottom bracket, there's comfort. in which case, 54cm to 56cm frames work for me. to each his/her own, for sure, though.
1981 Miyata 1000 58cm
Very Informative thread, and a nice group of photos! Here’s my 58cm 1000 that I’ve customized to fit my riding style here in the Pacific Northwest. I bought if from the original owner, and swapped out some of the original components, which I have saved in case a future owner wants to return it back to original.
I’ve noticed that most of the postings of the 1000’s in this thread don’t have the original racks (except Brewster II’s, which is looking good!). What year did Miyata eliminate including the racks as standard equipment?
2Fer.
Carridice Nelson longflap saddlebag. Rivendell Sackville front TrunkSack.
Original factory OEM front and rear racks and reflectors.
Michelin Hi-Lite Road 27x1-1/8 Kevlar bead folding tires
Non-Original: Tektro Brake Levers, Salsa interrupter brake levers, Suntour bar-end shifters, Nitto Technomic stem, Velo Orange elkhide hand stiched bar wrap
Suntour Cyclone GT derailleurs, Suntour 32-14, 6-spd. freewheel (non-original), Sunshine Gyromoste hubs, Araya 40-spoke rear wheel, 36-spoke front.
Suntour XC Comp cantilever brakes (non-original) with Cool-Stop pads. Zefal Competition pump
Brooks Champion Special B-17 saddle
Vintage Schwinn Paramount chrome fenders
2Fer.
Go Ride
Interesting, I saw a few of the custom Blackburn racks of submitted 1000’s, perhaps you’re referring to when Miyata discontinued both front and rear racks as stock option?
Sounds like a good project for you to pursue.
Nice specimen.
Cheers!
“Very Informative thread, and a nice group of photos! Here’s my 58cm 1000 that I’ve customized to fit my riding style here in the Pacific Northwest. I bought if from the original owner, and swapped out some of the original components, which I have saved in case a future owner wants to return it back to original.
I’ve noticed that most of the postings of the 1000’s in this thread don’t have the original racks (except Brewster II’s, which is looking good!). What year did Miyata eliminate including the racks as standard equipment?”
Nice specimen.
Cheers!
Nice specimen.
Cheers!
Nice specimen.
Cheers!
I was lucky to find the set of fenders that fit so well with little fitment issues. I think all I had to do was crimp them slightly at the chainstays. Radius to tire was spot on.
Tacreamer, Nice ‘84! Paint looks as good as ever....
Yes, I should have stated front rack. Your rear rack looks original to me, am I correct in that?
2Fer
Just completed 1020km+ on my Miyata 1000 LT from Calgary to Vancouver. This bike exceeded my expectations and the legend lives up to its name.
No flats, no broken spokes, everything on the bike performed flawlessly from point A to point B.
For now, just some pics my Miyata took me on.
2Fer
You are correct, my front and rear racks are the original racks that came with the bike as new.
Ironic that I'm using the same Suntour XC canti's and B17 Special saddle as you.
These are pretty special bikes in my book. You did a great build on yours!
This is a previous picture during a rebuild, and yes, my handlebars are not adjusted yet.
Likes For BrewsterII:
2Fer
The lo riders specifically are wildly different. They're made of much thicker tubing, have additional re-enforcement and are symmetrical vs the asymmetric design of the actual Blackburn units. I stuck them on the scale for giggles and they're a full 4oz more per side, not that it matters when touring.
You can see the difference, particularly in the area where the racks attach to the drop out. You can also see that the Jim Blackburn (I assume?) unit tapers more aggressively in the rear, where as the Koga Miyata unit has the same angle front and rear.
I noticed this as I was sewing new panniers for a tour. I have both racks on different bikes, they're exactly the same dimensions except for that taper, so I made the panniers for the symmetric rack. They fit just as well on the blackburn ones, they just hang over the edge a bit, like rectangular panniers would. Said panniers pictured below. I'll get around to posting shots from the tour eventually.
I wonder if anyone has any information that would indicate that the Miyata racks were built by Jim Blackburn, versus being copies. My Koga Miyata 1000-derivative came with factory branded racks and while the front rack is similar to the Jim Blackburn units, the rear and the lo rider racks are quite different.
The 1982 used this silver one and the 1989 and 1991 used a black front rack with a mid-fork attachment.
Correct me if I'm wrong, but all three my Miyata 1000s had custom made rear racks specifically for the bikes. I tried using them on other bikes but they would not fit.
I believe they might have been supplied by JB. The later models were only branded "Blackburn."
Sorry if I digressed, but I hope I clarified something.
Front and rear:
The low riders too
Then again, Koga Miyata was just really into branding. They even had their fork crowns stamped KM
Likes For fliplap:
I think your bike is earlier than a 1981 ........ as mine, per the specs, has a Chro/Mo fork. Your 1024 fork places it more in the 1979 range.
Quoted: 147 Post(s)
Liked 331 Times
My 1985 i believe. Picked up last week. Have not even given her a preliminary clean.I think it is mostly original except perhaps the RD.
Likes For garryg:
