Neck pain - road riding
Thanks!
I took some of the advises and started to play with exercising for upper back and general body strength. It is amazing how low I had to start, compared with the status from a few years ago. I assume that long working hours spent on a chair during the last years play a big role here. It looks that road cycling does not help at all with that, on the contrary. It only helps to cardio and a little bit with feet "maintenance".
One word about rotating the pelvis forward for further flattening the back: doing that would increase saddle pressure on groin area; to alleviate that, the saddle should be reset a few degrees down, but that would create other issues with high pressure on the hands. Not sure how this works.
Bikes: Shmikes
Quoted: 10223 Post(s)
Liked 5,947 Times
Thanks!
Your point about the saddle angle is right, but I’ve found the adjustment to be small and the solution being to strengthen the hip extensors to cantilever the back and unload the hands a little. The glutes are another important muscle group for which cycling does almost nothing.
Likes For MoAlpha:
climber has-been
Quoted: 3579 Post(s)
Liked 3,764 Times
Klaatu..Verata..Necktie?
Quoted: 10614 Post(s)
Liked 12,235 Times
Thanks!
I've tried saddles that are flat in profile and they're torture for me, cutout or no, because the pressure focuses too far forward. With a wave saddle most of the pressure is still on the sit bones, even when I'm riding either drops or aero hoods.
Bikes: Shmikes
Liked 5,947 Times
I can’t really see mine easily, but I know they were weak before I started working them in the gym. I did a few sessions with my wife’s trainer and he castigated me for my weak butt and said it was generic with cyclists. I’m also a puny little **** with no sprint, so maybe that’s part of it.
climber has-been
Liked 3,764 Times
According to Training Peaks, the glutes are engaged through most of the pedal downstroke:
Source: trainingpeaks.com
Likes For terrymorse:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2716 Post(s)
Liked 6,026 Times
Some good info presented in this article. Unfortunately there may be no ‘quick fix’ or ‘magic bullet’ but adopting one or more of these strategies should help. You can easily look up the recommended exercises. Neck Pain
I do planks and push-ups and free weights targeting the traps and upper back. Also do many core exercises. Good luck
Edit: I suffered from lower neck and scapular pain for a year and by adopting many of the tips in the article, I now have been pain free for over a year.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
TeeOhPea 2tha DeeOhGee
I stretch and have proper fit, but have learned to live with low level chronic neck pain. I pop 2 Alleve 20 minutes before every ride.
OM boy
Bikes: a bunch
Quoted: 555 Post(s)
Liked 714 Times
All other things considered...
Try this
while on your bike, and riding along at an easy pace. You're in your most common posture/position.
allow your arms to straighten, and allow the shoulders to shrug up towards your ears.
Bring your head/face up so you clearly see the road and everything in front of you
Note the feeling in your neck and bottom/back of your skull.
Now, bend the elbows lightly, bring the elbows to a comfortable position closer to the torso/side.
Drop your shoulders 'down', doing this actively by drawing/pulling your shoulder blades down the back.
Now, again, bring your head/face up so you clearly see the road and everything ahead.
Note that feeling...
Which is more comfortable for the neck and neck/skull connection?
strive to remember to use that whenever riding... until it becomes second nature.
Ride On
Yuri
This can also be 'tried' just sitting anywhere. Using the same methods; roll your head backward until you can't roll any further.
use each method - which method allows the head to roll the furthest up and back? without discomfort.
usually always the same result/answer...
Try this
Ride On
Yuri
Likes For cyclezen:
Quoted: 6351 Post(s)
Liked 4,952 Times
It could be genetics--or have something to do with the style of pedaling you do.
Perhaps those of us with no butt have a excuse for how lousy our stats are!
Likes For Iride01:
OM boy
Bikes: a bunch
Quoted: 555 Post(s)
Liked 714 Times
That's interesting, but still the hamstring does more. On the bike, my glutes waste away. Never had much there anyway according to my wife. I seem to get much more workout in my glutes from just a few miles walking than I do for the many more miles I ride.
I still believe that muscle engagement graphic, just doesn't seem to make a difference in muscle size, for me. Hiking definitely seems to work them more... for me
Ride On
Yuri
Quoted: 98 Post(s)
Liked 294 Times
I've just begun these stretches. Working on the speed bag for recovery of a shoulder after a clavicle break, is aggravating the neck injury sustained during the same fall.
Likes For streetsurfer:
I like all the positioning suggestions you've been given, good stuff. Having adjusted to life with a bad neck myself, I'll add a few simple things. First is to get the lightest helmet you can afford. Next , if you ride with glasses or goggles, find a pair with no top frame to block the view when you're looking up. No visors or cycling caps. I also ride my gravel bike as a road bike a lot , a Diverge, it has 38's for tires and just a little shock absorber in the stem called futureshock. It is a smooth ride. Many riders here hate futureshock, but not me. For me, riding more helps. Bothers me early in the cycling season but pain eases up as my core gets stronger. Good luck, you'll find a way.
Noob Bee
Bikes: Specialized Crux, Winspace SLC 2.0, Giant TCR Alliance
Quoted: 68 Post(s)
Liked 81 Times
I try to not be so hypervigilant about always looking up the road. Once I peruse a lightly traveled road ahead, I will go ahead and drop my head to where my eyes are only looking partly down the road. Mainly I am looking downward toward my front hub. I may also rotate my head side to side, then let the weight of my head pull it back down to where I am facing down toward the road again.
I like to do this when I'm in the "aero hoods" position (like this, but, you know, worse when I do it):
And then I'll time my "nods" with my breathing. Breathe in through the nose + look-up, breathe out through the mouth + look-down. I've found this rhythm works well for me to keep my neck moving during long flat stretches.
But again, only when I'm alone on long flat stretches. Also very important to have a visual guide when you look down to keep yourself on a line, typically the white line that denotes the shoulder of a road.
Addendum: I'm actually hesitant to recommend this though as I think about it, as really we shouldn't be looking down at the road almost at all like this. I'm pretty sure this is a bad habit on my end that I should work on moving away from...
Likes For sir_crash_alot:
Liked 12,235 Times
I do something similar, but I try not to look down at the road for long at all, and then only when I'm alone and have space, i.e. not in or near a peloton.
See how curved his back is? And notice how his shoulders are lower than his back? That means to hold his head up, he has to bend his neck WAY back. Compare with the picture below. Notice how, with a flatter back, he doesn't have to bend his neck back nearly as far to look up the road.
Likes For genejockey:
Noob Bee
Quoted: 68 Post(s)
Liked 81 Times
That is exactly NOT what I was talking about above
Technical deficiencies in the first guy's aero position aside (I agree with you that this may not be the best aero hoods form I could have picked), the point was that I do the breathe-nod rhythm from the aero-hoods position. Perhaps if my posture in that position were more proper, then I wouldn't have to do the breathe-nod rhythm at all.
I need to do some video analysis on my aero-hoods position!
Noob Bee
Quoted: 68 Post(s)
Liked 81 Times
p.s. Remco Evenepoel's aero hoods position is IMO the pinnacle of the position, but out of reach for most riders (myself included).
Quoted: 525 Post(s)
Liked 692 Times
Leaving the "Can't adjust the bike" thing aside (for now) Step one is identifying what is hurting and when. Only then can one begin to diagnose the cause(s). Could be a bunch of things, and while trial and error will eventually get you some relief, it may take more time and effort than otherwise possible. Is it a new bike? Are you a new rider? Have you made recent changes to your fit? How old are you? Health history and flexibility? Been off the bike lately? Have you increased your milage significantly lately? Does it occur after a certain milage or time on the bike? Are you happy with life? etc, etc.
