What are the biggest wastes of time in bike maintenance?
#126
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,221 Times
Chain lubing shouldn't be a complex chemistry experiment. Here are 4 simple easy to follow steps to successful chain lubing / cleaning.
Step 1....Wipe the dirty chain with a rag. You can use a little bit of solvent of your choice or rubbing alcohol.
Step 2....Put a drop of oil in each individual link'
Step 3....Spin the cranks to distribute the oil through the whole chain
Step 4...Wipe off any excess oil with a rag.
Easy peasy, no need to remove a chain from the bike, no need to mix and boil dangerous chemicals and risk an explosion and fire.
People who hot wax have been convinced by others that they need to do elaborate cleaning of the chain for wax to work. There is really no reason for doing so. There really isn’t any reason for doing elaborate multistep cleaning of oiled chains either. They need to be cleaned more often because of the oil but the procedure needs to be no more complicated than a 30 second vigorous agitation of the chain in mineral spirits…which is relatively benign.
Stuart Black
Stuart Black
#127
Liked 4,221 Times
July 21, 2021 at the end of more than 1200 miles of riding around the upper part of Lake Michigan. That included several days of rain riding. The only maintenance I did was to lube the chain after rain.
Bikes simply don’t need to be cleaned all the time…even when heavily used.
Stuart Black
Stuart Black
#128
Quoted: 6972 Post(s)
Liked 10,969 Times
I ride mostly on dirt and gravel roads (=dusty and dirty), and just do a wipe and re-lube every several rides, along with a more serious cleaning (with one of those handheld chain cleaners) when I wash the whole bike. My chain generally looks like yours in the middle of a cycle.
#129
Liked 4,221 Times
Stuart Black
Stuart Black
Likes For cyccommute:
#130
Liked 10,969 Times
#131
Habitual User
Quoted: 4957 Post(s)
Liked 8,098 Times
#132
Klaatu..Verata..Necktie?
Quoted: 10437 Post(s)
Liked 11,913 Times
There is no such thing as ‘a waste of time’ in bicycle maintenance. On the contrary, bike repair can be likened to a holy and mystical experience because it requires patience, attention to detail, and a deep understanding of its mechanical functions. Sufficient study and practice will result in a form of nirvana where you and the bicycle become one as it performs smoothly and efficiently.
Additionally bike maintenance can be almost meditative or therapeutic, providing a sense of calm and focus. Like any activity that requires skill and practice, bicycle maintenance can lead to a more fulfilled sense of self. It ain’t no waste.
Likes For genejockey:
#133
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
All I can think is that those roads in Michigan must be very clean. Just one day of rain riding around here (SF Peninsula) leaves a bike (and a person) pretty grungy. I gently hose my bike down after a wet ride, and I take off the soiled pieces of kit in the garage.
#134
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,437 Times
Arguing about what one should do, and how to do it. You do yours, I'll do mine. Case closed.
#135
Liked 4,221 Times
Stuart Black
Stuart Black
#137
Liked 4,221 Times
Just to be clear, I’m not from Michigan. The worst place to ride a bike in the rain that I’ve ever experienced is Mackinac Island. They don’t allow cars and use horses extensively. It’s best not to think about what is flowing down the road and why it looks green. Ewww!
Stuart Black
Stuart Black
#138
Habitual User
Liked 8,098 Times
As is mine. I just happen to keep the bike from getting dirty while still riding it in the first place. As evidenced in post 55, post 127, and any of the following. You can see in all of the pictures that the bikes have dirt from use on the wheels and tires. They have not been specifically cleaned for the photo. The panniers in the touring bike picture show road grime from approximately 600 miles of riding. But the drivetrains are squeaky clean. I don’t like cleaning and I don’t do it often because I don’t need to.
I don't mind doing cleaning, maintenance, or repairs on my bikes. After a good ride in the morning, spending a couple of hours tinkering on my bikes in the afternoon, with the garage door open, and some music playing, is a very happy way to spend my time. That's how I roll. I'm not trying to tell anyone else how they should do it.
#139
Quoted: 3956 Post(s)
Liked 7,304 Times
My bikes are 17% cleaner with 14% less effort, regardless of the conditions I ride in.
#140
Cleaning what needs to be cleaned to prevent internal contamination is indeed a good initial step in many maintenance tasks. Example from auto maintenance: wiping the dipstick with a clean rag or paper towel/napkin/tissue before reinserting it to check the oil.
But that can be overdone to the point of being counterproductive, both time-wise and mechanically. You don't need to de-grease the exterior of the entire engine before changing the oil.
Likes For Hondo6:
#142
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2585 Post(s)
Liked 5,646 Times
Likes For Fastfingaz:
#144
You are absolutely correct.
I seemed to have missed a memo. I've been severely lacking in the mixing department and I'll be honest, I haven't boiled a dangerous chemical once. Should I be doing that? What dangerous chemicals would you recommend for best results? And also what do I mix them with?
#145
Quoted: 4227 Post(s)
Liked 2,488 Times
I don't mind doing maintenance or repairs on my bikes. I have enough tools to do most of what needs to be done on bikes including wheel building or trueing. What I don't like is obsessive cleaning, there is no need to wash and clean the whole bike when replacing a set of brake pads or replacing a chain. None of the bikes which I own have been fully washed since new.
#146
Liked 2,488 Times
Just clean a small area around the part of the bike and component which is being replaced or worked on. There is no need to get the whole bike sparkling clean.
Likes For wolfchild:
#147
Liked 2,488 Times
I don't know because I don't wax my chains....You should ask all the chain waxers out there about the methods and rituals which they use to create their homebrew chain wax. I do recall some posters here a while ago saying that they boiled all kinds of nasty chemicals to create their homebrew chain lube.
#148
Habitual User
Liked 8,098 Times
#149
I wonder what chemicals were boiled... paraffin wax boils at 370°C but you only need to heat it to around 70°C so that it melts. You sure about that whole boiling part? Seems a bit weird to me...
Likes For elcruxio:
#150
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
