Carbon wheels for mere mortals
#177
Quoted: 2333 Post(s)
Liked 2,097 Times
Mg damping is almost as good as some carbon frames, both blow steel out of the water
https://www.precisiontandems.com/cat...amagnesium.htm
#178
Thread Killer
Quoted: 3149 Post(s)
Liked 1,714 Times
No, we're talking specifically about the ExoGrid tubing and the claims made around that, but in any case, it's a discussion way off-topic in this thread. I'm sure that if you want to start a new thread asserting that frame material doesn't impact frame stiffness or vibration damping, it will be well attended.
#179
Quoted: 3956 Post(s)
Liked 7,309 Times
#180
Thread Killer
Liked 1,714 Times
#182
Liked 7,309 Times
#183
SuperTeams
#184
Quoted: 1088 Post(s)
Liked 1,026 Times
Here you go, carbon wheels without a loud and obnoxious hub. Double fixed novatec rear hub, nothing to make any noise. Built with Pillar wing21 spokes. Took a touch over a pound off the bike. Daughter has been doing an excellent job of really putting effort in and staying in the paceline with the older, faster kids so I figure she deserves them. The 23c tires measure just over 25c with the wider rims, hopefully they won't be too rigid on the Kissena track.
Edit: better pic, also bike now weights 15.33lbs, once the rims have stretched I'll swap the tubes for latex for less rolling resistance and more rotational weight loss. Get it to that 15lb line.
Likes For Russ Roth:
#185
Sealant on inner tube
Modern tubeless tires leak air, so they require liquid sealant to be installed within the tire, and the sealant must be refreshed periodically.
This inherent leakiness of a tubeless tire is considered by some to be an advantage, as the mandatory sealant is able to seal small punctures. If the ability to seal small punctures is something you desire, sealant also can be used within a traditional inner tube.
#186
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
The tube needs to have a removable valve core. Then sealant is inserted the same was as it is in a tubeless tire:
- unscrew the valve core
- inject the sealant via a small flexible tube
- reinstall the valve core
Likes For terrymorse:
