Tube Failure Below Presta Stem
Quoted: 967 Post(s)
Liked 1,629 Times
Was airing up a wheel set that had been hanging on my garage wall for a few years. The wheel set was protected form the elements except for Texas Heat. Half way through airing at about 28PSI-2BAR they went POP!. On closer exam the tubes and tires were good except at the area below the Presta stem. Is this Common?
Klaatu..Verata..Necktie?
Quoted: 10435 Post(s)
Liked 11,912 Times
OM boy
Bikes: a bunch
Quoted: 517 Post(s)
Liked 645 Times
Well Butyl tubes do go thru a heat vulcanization process, which bonds the tube ends together and also bonds the valve assembly to the tubing.
My guess is that the heat vulcanization may make the rubber more brittle in that area. The valve stem is contained in a thicker piece of rubber, which bonds to the tubing.
So if too much heat is applied, it may harden the rubber a bit more than the overall tube - and could cause that area to fail sooner than the rest of the tube.
Note in your pic that one failure outlines the underlying valve stem rubber foundation...
...not a materials engineer, but know that 'cold' vulcanization' makes for a more durable rubber - over heat vulcanized...
a material engineer would likely provide a more complete picture of all this...
Don;t think this is a common problem, but I have had older tubes which just 'tore' in a similar fashion.
What brand/model are the tubes?
Ride On
Yuri
Ride On
Yuri
Quoted: 2604 Post(s)
Liked 1,933 Times
I'd guess mechanical failure. After sitting for a few years, you had basically zero pressure in the tube, so nothing to hold it firmly in place. Push the pump head onto the stem, you could have had the bead detach from the rim just below the stem and a bit of the tube get in there. When you then pressurized the tube, the part that was pinched between tire and rim popped the tire off the rim, and instant BAM! resulted.
Likes For pdlamb:
Quoted: 6196 Post(s)
Liked 4,810 Times
What internal size rims? That can be a easy place to damage a tube when installing a tire, especially on narrow rims. Though the tube looks more cracked than what I'd expect. What do the other rubber parts look like? Was the bike near something that produced ozone during it's storage time, like a motor?
I've heard that can be hard on rubber. But I'm not where I can go check right now. I put some old tubes and tires near a shop air compressor I have, but so far I don't see any issue. But then again, I don't use the compressor as much as I once did. So it's not running a lot.
Liked 11,912 Times
A point, but the fact that it deteriorated around the hole through the rim is suggestive.
Half way there
Quoted: 986 Post(s)
Liked 880 Times
Deterioration of the tube was probably not the cause. I'd say you had a tire bead seating issue, given that all pressure was lost in storage. This allowed the tube to expand under the bead and pop. I've never found age or storage conditions to affect butyl tubes, having used some that were decades old relics.
Quoted: 967 Post(s)
Liked 1,629 Times
Could have been water rot. These were old well used tubes and tires. I suspect that every time we air up our tires we get a small amount of moisture into the tube. It is bound to build up over time. The wheel set was hanging off the wall for years with he stems at the lowest point. Moisture could have collected at the bottom of the tube where the stem is at and slowly rotted out the tube. Just thinking...
Kinda like having to bleed the moisture outta the bottom of a compressor tank...
The tubes were KENDA 27 1-1/4. Never had trouble with these tubes before so it must have been the conditions of storage.
Bikes: yes, i have one
Quoted: 1138 Post(s)
Liked 1,182 Times
*say it ain't so
Liked 11,912 Times
i know some on BF like to argue for the sake of arguing* but...i think it is very unlikely to be caused by oxygen. i run plain old air in my tubes @ ~90psi. that is about 6 times the air in my tubes vs the air in the...air. that means about 6 times the oxygen swimming around in the tube. if oxygen caused this on the outside i would think that our tubes would have burst into flames long ago. some of my tubes are many years old.
*say it ain't so
*say it ain't so
I dunno. It's an hypothesis, and not one I give enough of a **** to investigate.
Liked 1,182 Times
Okay, but you have to realize that if oxygen DOES react with the butyl rubber, the oxygen would be depleted by the reaction, whereas the oxygen outside the tube is continuously replenished. But it doesn't have to be oxygen. We know that if you leave tubes out in the garage, even where it's relatively dark, they break down over time. If part of that is exposure to SOME COMPONENT OF air, then the are closest to the valve may be more exposed than elsewhere.
i see you are from the bay area. i used to live in Mountain View in what was an old hotel. then later moved to San Jose. i remember riding on some roads over there. some big hill up to La Honda or along Sand Hill. Isn't sand hill near the linear accelerator?
Liked 11,912 Times
everything breaks down over time but i'd rather ride than think about how long.
OM boy
Bikes: a bunch
Quoted: 517 Post(s)
Liked 645 Times
But the one with the 'age' crack under the valve - old rubber giving way...
Some tubes just seem to age and crack faster than others... I don;t buy Conti tubes anymore. Schwalbe, on the other hand seem to be bulletproof at almost the same weight...
Ride On
Yuri
Quoted: 523 Post(s)
Liked 229 Times
One of the tricks I learned working in a bike shop and replacing many tubes was to always push the valve in toward the tire and then pull it back out just before inflating the tube. This made sure the tire bead was properly seated adjacent to the valve. This was just the type of problem that was meant to avoid.
Likes For VegasTriker:
While everyone is theorizing bad rubber, the ragged hole indicates explosive decompression, which is impossible if the tube is fully within the tire. What you have here is the results of a pinched tube, and in the most likely place for it to happen. The reinforced part of the tube got caught under the bead the last time the tire was mounted.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Likes For ThermionicScott:
Quoted: 380 Post(s)
Liked 541 Times
I'm thinking of the valve nut holding the valve against the rim. It can stretch the rubber and rubber don't like being stretched or deformed for a long time, rubber gets cracked.
I only very slightly tighten this nut and I'd definitely remove it for storage.
That said, it's also not good to lay the wheel on the ground for storage. Better hang it if possible.
