Can't ride rigid bikes anymore.
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
As mentioned a couple of times above, comfortably riding a road bike takes technique and experience. Scan the road, identify obstacles, and if you can't avoid them you unweight and let your body flex rather than the bike. There's also a certain amount of HTFU.
A MTBer friend from out of town was visiting me and wanted to go for a short ride around my town. I loaned him a road bike. I was appalled at how much punishment he was taking. Every little bump was telegraphing up his spine and arms. I could see him wince. Less than ten miles into the ride he had enough neck and hand pain we aborted the rest of the ride and went home early. I realized too late he had no idea how to ride a road bike. And I know there are MTB techniques I've never mastered.
In the long & low NORBA era of 140mm stems and 60mm-travel forks, "riding light" was how you got things done.
I've found that modern MTBs are so much more capable on the trail, with long -travel forks and the proliferation of effective full suspension, that takes a lot of the "work" out of riding off-road. MTB geometry also has diverged significantly from the 26" era, more upright and less forward bias than older designs.
Could be that your friend isn't used to any bike without suspension, and add that to different kind of geometry, and the complication of drop bars (Contrary to BF lore, drops are not a natural transition if you're accustomed to riding straight bars) not surprising that he struggled on the borrowed roadie.
Quoted: 966 Post(s)
Liked 1,629 Times
But really, Ya ride what ya got. If it's comfortable then so much the better. The point is to ride. All my bikes are Frankenized for comfort and cost. In some ways it can be embarrassing. Kinda like that guy who has a Spring Loaded Tractor Seat on his MASI. Ya find what you need and quite possibly what you like and put together a bike ya can ride. I don't think I could comfortably ride any off the shelf bicycle... So Sad...
Quoted: 4259 Post(s)
Liked 1,361 Times
Likes For njkayaker:
Liked 1,361 Times
You are saying you "can't ride a rigid road bike (with a sprung saddle) anymore" to people who have no problems riding rigid road bikes (without sprung saddles).
And you are "much more comfortable" than them?
How do you manage to be much less comfortable and much more comfortable than those riders?
How do you managed to be much less comfortable and much more comfortable than those riders?
Easy, I'm much more comfortable than he is, but I'm much less comfortable than what I wanted/used to be.
Anyway, in hindsight I admit the title I wrote was evidently exaggerated.
Liked 1,361 Times
The suspension on rigid bikes is mostly the rider's legs, followed by the air in the tires. Riders get used to automatically loosen-up going over bumps.
If you coast a lot with all of your weight on the saddle, you aren't going to be very happy.
Be sure to read Ironfish's post carefully.
https://www.bikeforums.net/22607808-post28.html
Still, no. What you said doesn't make sense. You have no idea how comfortable he is (or all of the millions of other road riders using rigid bikes).
Let's put it another way then: I'm much more comfortable and safe than him in the (rare, but always possible) case of an unseen pothole or other similar obstacle. Actually, my reply was just in response to him laughing about sprung saddles.
Liked 1,361 Times
People's first posts should try to avoid being inexperienced people telling experienced people they are all wrong about something they do routinely.
(You had 2 posts 7 years ago.)
This is two words (by the way).
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
You either have an exaggerated impression of what a sprung saddle can do, an exaggerated intolerance for minor discomfort, or both. Regardless, you don’t have any idea how uncomfortable anyone else is. Those of us who have put in thousands of miles have learned how to navigate rough terrain comfortably and safely, without suspension or springs.
Likes For Rolla:
Where did I say anyone's wrong? If anything, he ridiculed the fact that I'm using a sprung saddle?
Quoted: 2975 Post(s)
Liked 1,182 Times
A seat of the right width that properly supports your sit bones is more comfortable than any sprung saddle or super thick foam padded gel seat that's out there.
Likes For prj71:
Liked 1,361 Times
This still might not be true. He might be seeing them when you aren't and one can ride in a way that sets you up for ones that one doesn't see.
I'm saying experienced people on rigid road bikes ride in a way that avoids most of the problems that you think both are seeing at the same frequency.
Uh? I never said that whoever rides a rigid bike is wrong.
He might be "ridiculing" you for using a device to compensate for poor technique.
Quoted: 3952 Post(s)
Liked 7,298 Times
Likes For tomato coupe:
Quoted: 822 Post(s)
Liked 1,960 Times
I have similar goals and equipment as you do.
My now primary bike is a 2014 Trek Marlin 6 that is now set up with a mostly Deore group set, a Salsa Cromoto steel fork, ES500 SPD pedals, Ergon bar ends, Marathon 45mm Green Guards and a Cobb enduro saddle. The Marlin has morphed into a quasi Adventure-Touring bike and it is time to measure and research possible bike packing bags for short 3-5 day SoCal mountain tours. The bike weighs 32 lbs with pedals, bottle cages in a XL frame.
I realize the limitations with this bike as is will be to stick to pavement, rough pavement and hard pack fire roads. It is not a bike, as is, for single track or anything technical.
I think the bike will serve my needs and I am not in a hurry so I see no need to budget for a more expensive gravel/adventure bike.
I find the upright position and stance to my liking. I see no reason why your used rigid mtb bike cannot be used as a touring bike if you find it comfortable and adaptable to your purpose.
For the last dozen years or so, I've almost exclusively ridden a cheapo (129 EUR / USD) full suspended MTB, on which I mounted a plushy sprung saddle and slick 42mm tires.
In anticipation of future endurance rides (or possibly even credit card touring) that I'd like to try, and because common knowledge is that a full sus MTB wouldn't be the ideal bike for that, I bought an used '90s rigid MTB to modify for the purpose.
Sure, its 52mm tires and the said plushy sprung saddle which I mounted on it, make it certainly more comfortable than un upright city bike (or a road bike), and yet the full sus MTB is noticeably more comfortable.
Infact, the asphalt where I live is definitely not in good conditions. Moreover, with the full sus I can steamroll over the many speedbumps I cross.
"Duh! Of course a full sus is more comfortable than a rigid!", you are thinking. Yeah, I know. I was just wondering if there's some of you who only rides suspended bikes, with at least a suspension fork, and maybe a sprung saddle. Especially for long distance riding. I know that almost all "advanced amateurs" cyclists ride rigid bikes even for long distance riding, and I wonder how they do it. I would probably be knackered if I'd try that.
Likes For CAT7RDR:
Guest
Liked 3,270 Times
Likes For Rolla:
Liked 1,361 Times
Every choice requires a compromise (a trade-off of different capabilities).
Here you should be thinking of reasons why they do it.
Well, looks like there are people who spend 250$ for a Redshift suspension post to "compensate for poor technique".
Liked 1,361 Times
Whoosh!
Who thinks this?
You are compensating for your poor technique.
Not $100. $20 or $250. It's the same. right?
