Do You Ride A Low Or High Cadence?
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
I don't have a cadence meter on my bike, but I've manually counted and also used stationary bikes with cadence readouts. So my cadence observations that follow are just estimates, but still I wanted to ask the question.
What cadence(s) do you ride? Why, and when?
I used to pedal a fairly fast cadence, from 100 to 120 rpm. This was when I rode my mountain bike around town, with its low gearing (24/34/42 x 13-28, 26") When I started riding a road bike (53/39 x 12-26, 700C), I initially used the same cadence. Then my cadence started slowing, while at the same time my legs became stronger (able to apply more force for longer). Nowadays I usually ride around 80, sometimes as low as 60 on climbs, especially standing climbs. When I'm trying to ride fast, I'm more likely to shift into 53 x 12 and push hard at 90 rpm, than 53 x 17 and spin 120 rpm. I use a higher cadence like 100+ mostly when I'm "resting" or cruising.
From what I read, this seems to be a backwards progression. It sounds like most people start with a low cadence and move to spinning as they become more experienced cyclists.
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Quoted: 1743 Post(s)
Liked 1,281 Times
It's situational for me. Cruising on the flats I like to be somewhere around 85-95 rpm.On mild but longer elevations I'm around 75 rpm. On steeper climbs I'm usually in the 55-65 rpm range. Steep climbs are really tough for me because I'm a fairly normal human (not overweight) but 20 lbs over "cycling weight." As my weight comes down my climbing rpms will change for sure.
Bikes: better than I deserve
"Do You Ride A Low Or High Cadence?"
No, I don't--that is, I don't ride either one of those. My cadence averages around 80-90 rpm, very much in the mid-range.
a77impala
I don't count rpms but due to arthritic hips I tend to spin rather than power. Have been converting bikes to smaller chainrings and larger geared cassettes.
Liked 6 Times
Mine is almost always between 85 and 100. This is according to the data the computer saves for me. When riding I very seldom pay attention to it. When I first started riding, I was obsessive about trying to stay in the upper 90s. Over time, I realized that was just making the ride less enjoyable. Now days my knees will tell me when I should shift and spin.
A conclusion is the place where you got tired of thinking. - S. Wright
Favorite rides in the stable: Indy Fab CJ Ti - Colnago MXL - S-Works Roubaix - Habanero Team Issue - Jamis Eclipse carbon/831
weights are heavy
Bikes: CAAD9 5 (09)
I pay pretty close attention to my cadence and find I'm in the higher range. If I'm below 90 that usually means I'm tired.
Strava says my average cadence was 90 and 92 on my last couple rides. That includes lights and stops which means my moving avg was probably a fair bit higher.
When I first started I would do much more mashing/power pedaling. I think I've reached my ideal mix between anaerobic and aerobic.
YMMV.
YMMV.
Looking at my garmin data from the beginning of the year, my average cadence over 900 miles with 47,000 feet of climbing was 74. I try to spin above 90 or 100 on the flats, and obviously am slower on hills. I consciously worked on picking up my cadence, one of the tools I used was cycle.jog.fm which lets you select songs by the cadence they match.
Have not gathered the Data.. only put a computer on for the 2 odometer functions on bike tours.
my computer on that bike is down on the fork-blade.. rarely look at it.
I stay just ahead of the chosen gear-ratio.. so Im not mashing too big a gear,
or trying to keep up with one too small..
when I'm on my Brompton, 3 speed, I adjust the speed to the gear, low too fast a cadence ?, Slow the pace.
Seat Sniffer
Quoted: 945 Post(s)
Liked 1,990 Times
80-100 RPM.
Slower when I'm cruising. Faster when I'm picking up the pace.
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
I keep a relatively high cadence to avoid knee problems and because I am recovering from an Achilles injury.
Council of the Elders
Bikes: 1990 Schwinn Crosscut, 5 Lemonds
Sounds about right except for hammering where subtract 10 and noodling subtract 5. I really don't like spinning fast while going slow. I usually finish a ride with average cadence of about 78.
Humvee of bikes =Worksman
Quoted: 10 Post(s)
Liked 6 Times
Sad to say there are those of us that , due to medical reasons, are clocking a moderate to slow cadence with one speed.
I don't mind really since I'm on a bike and still pedaling my ass all over town!
My preferred bicycle brand is.......WORKSMAN CYCLES
I dislike clipless pedals on any city bike since I feel they are unsafe.
Originally Posted by krazygluon
Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred, which one would you rather have under your butt at 30mph?
Quoted: 8287 Post(s)
Liked 9,061 Times
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
I can pedal fast (110-120) or mash (75 or so). But I find I'm most efficient around 85, especially if I want to ride at a brisk pace.
Shredding Grandma!
Bikes: I don't own any bikes
Quoted: 46 Post(s)
I used to have a computer that showed cadence. It helped me developed and improve from about 60 - 70 rpms (and pushing/mashing) to currently 90 rpms. I no longer use that computer, I can tell what level I am spinning...
______________________________________________________________
Private docent led mountain bike rides through Limestone Canyon. Go to letsgooutside.org and register today! Also available: hikes, equestrian rides and family events as well as trail maintenance and science study.
Looking at all my rides from this past year, (2013), excluding the two bikes that do not have a cadence sensor, I've averaged between 61 to 66 for my rides of a distance between 15.2 miles to 100.1 miles, (I rode 59 on a 3.7 mile ride, but that was an attempt to re-gain my KOM on a short segment close to home). I guess that would make me a "masher". I've had my GPS on more that several occasions when climbing give me nasty warnings that my cadence is too low. Sometimes on a particularly steep climb, it will be in the 40s. (I'm not a very fast climber.)
Why? Because that's how I've always ridden. Been that way since my teen years and I'm now in my early 60s. I guess I've been lucky to never have had knee problems. I've tried to turn faster, but it is very uncomfortable for me, and takes the joy out of riding. Distance ridden doesn't seem to affect average cadence. From quick 15 milers to double-metric centuries...they all average in the low 60s.
When I was a member of a gym and rode the LifeCycle every time, it would want a cadence of 80 turns per minute. Even that seemed quick a lot of the time. At the end of the LifeCycle program, it would ask for 100 turns per minute. I could do that, but it was only for 1-2 minutes, depending on the time specified at the start of the programed ride.
I've tried spinning. Its just not for me.
alpine cross trainer
Bikes: Specialized Roubaix, Quintara Roo Sendoza, DaVici In-2-Ition Tandem,
Quoted: 21 Post(s)
Liked 20 Times
Usually above 85 RPMs but under 100. I listen to what my legs are telling me. If they begin to protest, I shift and spin higher. Used to routinely watch my cadence monitor. Now, I never do. Over time, you develop a pretty good internal cadence monitor.
Trek 500 Kid
Quoted: 2904 Post(s)
Liked 382 Times
You usually have to clue in newbies to keep their cadence up and that it's a cardiovascular thing not a weight room thing. If they don't have a cadence meter then try a ride with fast people and they'll find out fast if they aren't pedaling fast enough. I say: "If you ain't doing it right, you won't be keeping up for long". I tell them a revolution and a half per second....90 rpm on flats.
Since I've never had a cadence meter I couldn't give you specifics but it's probably relatively fast as compared to other experienced riders.
I used to spin.
Then I installed a cadence meter on my bike.
It tells me I mash. My cadence is very predictably 10-15 rpm slow than what I think I'm doing.
Momento mori, amor fati.
Bikes: 2006 Specialized Ruby Pro aka "Rhubarb" / and a backup road bike
Quoted: 7 Post(s)
Liked 13 Times
I struggled for several years trying to increase cadence but find that averaging about 59rpm works best for me.
I got some easier gearing on my most recent bike thinking I could climb at a faster cadence. Mostly, I just climbed slower at the same cadence.
But I sure did like having the 53/11 instead of just a 53/12.
It's all very individual and yes, I am an outlier.
I always rode what was comfortable. I pretty much guessed it was about 80-90, I got a Garmin last year with a cadence sensor, and it confirmed it.
