Now these are lights!
Pretty cool looking, I’ve never seen a setup like this before.
Semper fi
Semper fi
Likes For sloar:
Quoted: 4512 Post(s)
Liked 6,386 Times
Likes For merziac:
Quoted: 4722 Post(s)
Liked 3,037 Times
Twin headlights used to very very popular in the Japanese market. Attached are samples from Bridgestone, Miyata, National/Panasonic and Sekine.
Likes For T-Mar:
Quoted: 2483 Post(s)
Liked 2,955 Times
Japanese city bikes could get pretty elaborate.
From this page: https://www.ironweedbp.com/ironweed-blog/vintagejapanese
Likes For Trakhak:
Quoted: 3811 Post(s)
Liked 6,707 Times
I think @gugie did a front rack for someone who wanted that setup.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,800 Times
Likes For gugie:
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
Now you guys know what I want for Christmas, lol. 😁😉 This does look like something I might try to copy, kinda sorta. 😎
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
I'm with you. I've got a '70s Bridgestone as my 'townie' bike, and an old NightSun kit that doesn't see much action anymore. Time to start shopping porteur racks
Likes For Ironfish653:
I wish they were on a nicer bike, seller wants $100 for the bike shown.
Semper fi
Semper fi
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
Likes For cudak888:
Liked 3,037 Times
The bicycle looks like an entry level Skyway. It appears to be one of the Bridgestone manufactured models with the bulge formed head tube and the stays that are crimped and spot welded onto the dropouts. It has down tube shifters with full length cable housing and no brake safety levers, so I suspect it's late 1960s to very early 1970s. If so, those may be 26" x 1-3/8" wheels.
Quoted: 1399 Post(s)
Liked 1,882 Times
cost around $180 back in the early 90's - and a current $30 light is probably brighter and runs longer lol
some on this forum are retrofitting LED bulbs etc to old Nightsun lights
Likes For t2p:
Luxor (the French light company) also made some awesome 2 light setups with hammered, smooth, and wavy surfaces. Some were even integrated with a front rack, in a finish made to match your hammered fenders. A few examples at tontonvelo, post number 14333.
I installed the Luxor 50 double light, with LED retrofits, on my wife's bike. Works great and provides more than enough light. Will post a picture if i ever get enough posts on this site.
Quoted: 586 Post(s)
Liked 612 Times
I'm in favor of anything which increases safety and especially visibility to motor vehicle drivers if nothing else. I have seen an older gentleman, who is likely retired, riding in the early morning on my way to work who could benefit from those. He runs a very small light and I don't know if it is the weakness of the light or the angle at which it is set, but it is very difficult to see him until you are almost upon him. In my book you can't be too safe.
Another popular way to do this in Japan is with a dynamo powered headlight on one side and a torch/flashlight on the other. That’s what I do on my tourer
I also use this setup on my randonneur for rides over 400k that will have substantial night riding. The torch acts as a high beam that I can reach down and switch on for dark fast sections.
Likes For fliplap:
RUSA #3100
Bikes: Yes
Quoted: 237 Post(s)
Liked 505 Times
This setup is now dated but was state of the art back in the day! The hub could power one light well under 12 mph but both lights over that speed. PBP proven!
https://utahrandonneur.wordpress.com
Likes For Oldairhead:
Quoted: 753 Post(s)
Liked 737 Times
I have one of those Bridgestone built Skyways in the attic. As I remember the front rack and fender are pretty well integrated. I did some rough measurements and it looked like the "assembly" could be transferred over to another frame and go over 650b x 38 tires. The front rack struts are sized for a touring fork with 2 braze-ons so a leg extension, clamp or other trickery will be needed.
https://www.bikeforums.net/classic-v...et-skyway.html
Liked 4,395 Times
Same for a modern LED w/standlight powered by a 6V AC bike hub (and doesn't require recharging batteries).
-Kurt
Quoted: 753 Post(s)
Liked 737 Times
I'm sure there's a way to retro fit those lights with LEDs to get more out of them.
Likes For bark_eater:
Quoted: 3464 Post(s)
Liked 2,831 Times
Likes For repechage:
Quoted: 1829 Post(s)
Liked 3,376 Times
I've been tinkering with actually coming up with a replacement for a flange mount bulb that would have two LEDs mounted to a copper heat sink. The intent is to still use the original optics, reflector, etc. without the poor efficiency of an incandescent bulb.
Last January, I did get a start by mounting a little 3mm x 3mm LED to a suitably sized copper plate....
(the master link is there to provide a sense of scale)
I was able to attach some 30 gauge wires and clamp it to some aluminum for a heatsink...
At 400mA, it does generate a fair bit of light!
Note that the intended design has two such LEDs mounted back to back, each one radiating in a hemispherical pattern.
Steve in Peoria
Likes For steelbikeguy:
