Bar tape direction?
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 209 Post(s)
Liked 175 Times
Bar tape direction?
Going the opposite way on each side seems to be symmetric.
But, Sheldon Brown disagrees;
Whether you start from the middle or from the ends, make sure to go in the same direction on both sides. I generally start from the underside of the bar, with the tape feeding outwards. You can do it the other way too, but make sure you follow the same pattern on both sides.
What sayeth you?
What sayeth you?
Bikes: 1986 Raleigh Competition (Restored to Original), 1986 Cannonade SR400 (Updated to Dura Ace 7800)
I find that starting at the middle and going down makes the tape more likely to curl up along the edges with use. Sliding your hands down the bars, you catch on those edges.
You want mirror symmentry, not side by side symmetry.
Strong Walker
Fat bar tape (Cinelli Cork etc.) Bottom->top, reason: see TampaRaleighs post
thin bar tape like Benotto: top->bottom, reason: clean end with the provided colour-matched plug
Bikes: 1986 Miyata 110
Liked 6 Times
Though I did a Top to Bottom wrap last time and as martl said, definitely cleaner. It will need replacing soon though because of the issues mentioned by TampaRaleigh.
I agree with Martl. Back when I used cotton tape or plastic like Benotto, you would start at the top and stuff the cut end inside the bars. With fatter bar tapes starting with Bike Ribbon for me, start at the bottom. I usually wrap so that the tape is coming from the underside of the bar and wrapping around to the outside. Grip pressure will tend to tighten it this way.
feros ferio
Quoted: 1393 Post(s)
Liked 1,326 Times
I did Capo #1 in sprint tape, i.e., from the bottom to the brake handle only, and it looks very period-correct. In fact, the 1962 Capo catalog depicts this treatment.
Quoted: 3464 Post(s)
Liked 2,830 Times
Vinyl tape is center to the end.
Modern tape ("Cinelli padded") is end to center. Finishing tape required, I taper the end as to keep the sticky tape band as narrow as possible.
Quoted: 17 Post(s)
Liked 42 Times
This is true if you ride on the tops or hoods, but if you spend more time in the drops, then wrapping top-down actually helps to prevent the edges from curling.
- Auchen
- Auchen
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Bottom up, towards the middle. That means counter clockwise on the right side, clockwise on the left.
Bikes: 4
Quoted: 9 Post(s)
This has been my experience as well. I also install cotton tape wet as it seems to give it more stretch when wrapping. Let the tape dry overnight and it shrinks tight to the bar, no rolling edges anywhere even after a full season of use.
Quoted: 209 Post(s)
Liked 175 Times
It seems like the Sheldon Brown directions suggest going counter-clockwise on both sides...
Going from the ends to the middle is a given with cork tape.
one life on two wheels
Liked 18 Times
I wrap bar end to stem, feeding the tape outwards as I wrap.
Quoted: 1608 Post(s)
Liked 2,216 Times
Still struggling with bottom to top or top to bottom. Way back in the 70's it was always top to bottom using the plugs to end the tape. I was surprized a few years ago (<10) to see bottom to top. When I bought my 84 Colnago, it still had the Bennotto tape and was wrapped bottom to top.
rain dog
Quoted: 16 Post(s)
Liked 8 Times
Here's the park page on handlebar wrapping:
https://www.parktool.com/blog/repair-...ation-drop-bar
Quoted: 443 Post(s)
Liked 27 Times
Liked 18 Times
I think that's mainly because cloth/thinner tape was the norm back then, so it was easy to tuck it under the bar end plugs. With cork/thicker tape, it can still be tucked in, but it's trickier and usually easier to just terminate it with tape at the top.
This is the correct way, but I always forget the direction. When I rewrapped some bars yesterday, I just looked at another bike I had near it, and now both of them are backwards.
Just keep pedalling!
Bikes: 1987 Schwinn Circuit, 1987 Panasonic DX-4000, 1984 Peugeot PSV10, 1989 Centurion Prestige, 1973 Raleigh Sprite, 1987 Peugeot Canyon Express, ~1986 Raleigh Capri, 1994 Trek 850, 1984 Centurion Pro Tour 15, 2012 Gravity Zilla
I usually wrap bars from the top down. I never have a problem with curling or coming loose. I prefer non-adhesive cork tape. The plugs hold the tape at the end. No electrical tape is needed and it looks really clean. I start at the front and go over.
Quoted: 834 Post(s)
Liked 2,126 Times
As others have also said above, I wrap in different dirrections depending on the tape. In most cases I start at the ends and work toward the center so as to avoid curling on the bends. For Benotto tape and, I like to finish with heat and/or super glue for a clean look. For cork or modern tape such as Fizik microtape (my current favorite), I taper the end of the wrap so it has a clean edge at the center. For cloth tape, I go center to end (just like Eddy!) and replace if/when it starts to curl.
It is important to wrap in the clockwise/counterclockwise direction described in the Park Tools link. This is so when you are pulling back on the tops (such as when climbing), you twist the wrap tighter. If you wrap the wrong way, pulling on the tops will help to loosen the wrap.
-Randy
'72 Cilo Pacer • '72 Peugeot PX10 • '73 Speedwell Ti • '74 Nishiki Competition • '74 Peugeot UE-8 • '86 Look Equipe 753 • '86 Look KG86 • '89 Parkpre Team Road • '90 Parkpre Team MTB • '90 Merlin Ti
Avatar photo courtesy of jeffveloart.com, contact: contact: jeffnil8 (at) gmail.com.
-Randy
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
I've wrapped all my bar tapes since the 80's going away from the brake lever down and up towards the stem.
Pressure from the hands in my case goes downwards and out when on the tops of the bar and then, when on the drops, there a tendency for pressure from the hands to push forward a bit from the ends of the bar, so for both top of the bar and drop positions, I do not have any tape edges that can curl up and start gaps. It works, as I never saw gaps on my bar tape ever again since I started this method of tape installation back in the early 80's.......
Chombi
Chombi
Bikes: '73 falcon sr, '76 grand record, '84 davidson
Quoted: 59 Post(s)
Liked 22 Times
i couldn't disagree more with the park instructions. i start from the end and wrap from inside out, so hand pressure is always applying tightening pressure. once you arrive at the lever, you wrap from outside, over the bar, then under and around the outside of the lever and back under, making the 'figure 8.' this puts you in position to continue on the top, wrapping from in to out toward the stem clamp.
i always apply two pieces of electical tape (one atop the other) to complete the wrap, but i cut the width of the black e-tape in half, 'cause a thin finish looks more elegant.
