My luck can't be that bad, can it? Can it???
#53
As a rule, I start with gloved fingers in case it's a gross puncture. No need to get tetanus if I can avoid it. If I don't snag a gloved finger, I'll try running bare fingers lightly through the tube. But adding a cotton ball to my tool kit isn't in any way impractical.
#54
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Where does it say anywhere that they are not designed to be permanent? Do you have some facts to back this statement up or is that just your opinion?
Check the reviews here. Their experience mimics mine.
https://www.vitalmtb.com/product/gui...t-reviews-7701
Got this response by Park Tool to a negative review on their website:
"Thanks for your review! We suggest always replacing damaged tubes/tires as soon as possible to prevent accident or injury while riding. Our patches can last a long time, but there are many variables that can affect the performance of the patch. We recommend not testing the patch by inflating tube while outside of mounted tire. This may stretch tube body and weaken patch bond."
Basically, it says they can a last a long time when they last a long time, but sometimes they don't.
Seems totally unsurprising that some people find it works better for them than others.
Likes For livedarklions:
#56
Quoted: 8280 Post(s)
Liked 9,038 Times
Likes For big john:
#58
Bikes: yes, i have one
Quoted: 1138 Post(s)
Liked 1,182 Times
#59
Klaatu..Verata..Necktie?
Quoted: 10425 Post(s)
Liked 11,898 Times
i've used these and they do work until they don't. after about a year or so they invariably leak. i've had to pull them off and replace with a correct vulcanizing patch, done right those don't seem to fail. i still keep them in my saddle bag along with a spare tube and a real patch kit. you never know how many goat heads will be thrown at you.
E.g. I was running a patched tube in the back tire on a bike I was using in a wheel-on trainer. I was riding a race on Zwift, my power numbers got all weird and then went away completely. The tire had gone flat - which I didn't expect INDOORS! When I submerged the inflated tube to find the leak, it turned out to be leaking at the patch. This tube had lasted miles on the real road and hours on the fake one, so I think I can say it was "done right". I can tell you, it made me feel a lot less confident about patching and reusing punctured tubes. So now I have a bunch of tubes I COULD patch, but haven't. And I'm down to my last 2 new ones.
#60
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Pretty sure I was involved one of those times. You said something about burnishing it properly. Since I had just switched to tubeless at the time, I never got the chance to test it out until recently (temporarily using a tubed tire while waiting for a warranty replacement tire to arrive) but I will probably remove the tube before it has a chance to prove its longevity.
It's like riding a bicycle
#61
Quoted: 1109 Post(s)
Liked 1,200 Times
yeah I carry a pump & at least 2 cartridges. usually 1 extra tube + patches
on longer rides, I carry another tube & 2 more cartridges
I have 3 bikes all w/ diff. size tires/tubes. so I have to remember to move the pump to the bike of the day & change the tube(s) in my trunk
luck = when preparation meets opportunity
People have been impressed by the $20 bill. Why you ask? Well, it's pretty common to carry a bill to use as a tire boot. So why not use a $20 (or $10, whatever). A $20 also serves as emergency snack or drink money!
Likes For Camilo:
Likes For Camilo:
#63
Quoted: 2700 Post(s)
Liked 486 Times
I was shown that trick as a way to dry the glue out quickly so you don't have to wait a few minutes before applying the patch.
vegasjen id throw away the tire you probably have something stuck in it that you can't find. It might give you grief later if you don't.
#64
I was thinking the same thing, but then I checked, and saw that Park had already used some "CB-" part numbers for ChainBrite!
That's one of the downsides of trying to use "significant" part numbers, i.e., part numbers that are not arbitrary, but also try to carry some information about the part.
#65
Randomhead
Liked 3,698 Times
I got a slow leak on one of my bikes and stopped to fix it when it got too low. I ran my fingers around inside the tire and couldn't find anything. I got tired of looking for it, so I replaced the tube and got to the overnight stop. Then I finished the ride the next day. I have another set of wheels for that bike for gravel, and I rode those for the rest of the season. The next time I used the road wheels, it was really easy to find the piece of wire that caused the slow leak. I think wire will move in and out of a tire so it's hidden.
#66
Liked 1,200 Times
#67
Liked 2,971 Times
CS-01 [cotton swab]
-Oh Hey!
-Oh Hey!
#68
I have several tubes I've patched and proven good in the garage. I will likely try it one more time with one of those. If it holds, then I'll keep it, still a lot of tread life left. If not, I'll take your advice and toss it. Of course, I need to determine where the leaks are in the two tubes from that ride. Certainly if they're in the same place on the tube, that gives me a good place to start investigating.
Likes For VegasJen:
#69
Liked 9,038 Times
The little wires from steel radial car tires are insidious.
#70
Quoted: 1397 Post(s)
Liked 1,877 Times
#71
Quoted: 766 Post(s)
Liked 1,737 Times
I have been there. Back a few years, I was getting flats a lot, so I got fed up with it and changed my tires. I am not a quarter mile down the road and I get a flat through a side wall from a little sliver of a 2x4 that I did not see. I was less than pleased. I had a whole 2 mins on this tire and it was ruined.
Likes For jaxgtr:
#72
Quoted: 766 Post(s)
Liked 1,737 Times
I used to carry a old section of panty hose to wipe the tire and rim with to make sure there was nothing there that I was not seeing. Small little slivers of wire nicked 2 tubes for me once.
Brian | 2023 Trek Domane SLR 7 AXS | 2023 Trek CheckPoint SL 7 AXS | 2016 Trek Emonda ALR | 2022 Trek FX Sport 5
Likes For jaxgtr:
#73
Liked 9,038 Times
#74
Quoted: 2604 Post(s)
Liked 1,933 Times
They make a shot for that. My daughter made me get a DTP before I could go visit my new grandson (although she was worried about pertussis, I have a handy way to remember when I got my latest tetanus booster!).
#75
Quoted: 581 Post(s)
Liked 921 Times
During the first mutli-day tour I did I had multiple flats over the first few days. First one - towards the end of day one - was a mystery. The second one was on day 4, racing down a dark road to get to our stop for the night when I went through a section of torn up asphalt too fast and got a pinch flat on the rear including some damage to the tire casing, and a bit of damage to the front tire casing but no flat.
I left the front as it was, patched the rear tube and put a Park Tool 'boot' on the damaged tire casing.
Around lunch time the next day I got a second flat on the rear - wrinkles in the tire boot had chafed a new hole in the tube, but the patch stayed intact.
I lost count but I think I got around ten flats over a 3 week tour. I repaired most with patches, and, happily but meaninglessly, none of the patches failed and caused another flat - they were all due to some other debris picked up.
Super fun fact - the last flat I got was about 500 meters after I bought and installed a new rear tire - I ran over a piece of metal down the road from the bike shop.
