What are the biggest wastes of time in bike maintenance?
#101
Quoted: 1279 Post(s)
Liked 1,393 Times
the grinding sound was horrifying. never again will i ride on a "factory grease" chain even around the block.
Likes For Lombard:
#103
Quoted: 18424 Post(s)
Liked 15,581 Times
#105
Liked 15,581 Times
Likes For indyfabz:
#106
1) in nice summer conditions around 400km. Could go for longer but I want to try to keep wear to a minimum.
In bad winter conditions around 150km. So with three chains in rotation I'll be waxing once a month.
if the 150km seems short, in those conditions the need to relube with a drip lube was between 20-40km.
2) no idea yet. The websites actually studying this stuff claim around 15000km per chain. We haven't put those kinds of distances on chains yet since every bike has multiple chains. However none of the chains are even close to indication 0.5% wear. Also we too have not had to swap cassettes /drivetrains since starting waxing which is refreshing.
Wax getting gummy depends on the wax. Fully refined paraffin doesn't get gummy. If you add oils or some other softeners, it will but it'll also work worse. You really shouldn't do that. Some drip waxes can get gummy maybe? I don't have that much experience with those.
#107
Quoted: 7653 Post(s)
Liked 3,481 Times
Yes, adding air on a schedule is ridiculous. Add air based on pressure, not the, whether hourly or annually. If the tires need air, add air.
Likes For Maelochs:
Likes For Peevess:
#110
Quoted: 62 Post(s)
Liked 255 Times
I recently had tasks that required a bearing press (PF bottom bracket and freehub bearing replacement), so I bought the tool. I also needed to align a bent derailleur hanger, so I bought that tool, too. I checked the hangers on all my bikes, and every one needed at least a little tweak. I love how smooth and quick shifting is when everything is aligned correctly. I enjoy having an excuse to buy new tools.
Likes For daywood:
Likes For tyrion:
#113
Habitual User
Quoted: 4957 Post(s)
Liked 8,099 Times
Likes For Eric F:
#115
Quoted: 4227 Post(s)
Liked 2,488 Times
Chain lubing shouldn't be a complex chemistry experiment. Here are 4 simple easy to follow steps to successful chain lubing / cleaning.
Step 1....Wipe the dirty chain with a rag. You can use a little bit of solvent of your choice or rubbing alcohol.
Step 2....Put a drop of oil in each individual link'
Step 3....Spin the cranks to distribute the oil through the whole chain
Step 4...Wipe off any excess oil with a rag.
Easy peasy, no need to remove a chain from the bike, no need to mix and boil dangerous chemicals and risk an explosion and fire.
Likes For Camilo:
#117
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
#118
Habitual User
Liked 8,099 Times
If I'm getting into a deeper cleaning of my bike, however, I'll take the chain off and give it a swirl in a bath of cleaner, rinse it off, dry it off, and then lube it up. Quick links have made that process significantly easier...until I start dropping quick link pieces.
#119
BF's Resident Dumbass
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 792 Post(s)
Liked 1,494 Times
#120
Quoted: 4806 Post(s)
Liked 3,932 Times
Obviously latex tubes are beyond hopeless. Mine all have thousands, maybe millions of slow leaks. (I've never counted them. They're too small to see without a microscope. But I am sure that mechanic cleaning the chain "the Sheldon Way" has that number.)
#121
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2587 Post(s)
Liked 5,649 Times
There is no such thing as ‘a waste of time’ in bicycle maintenance. On the contrary, bike repair can be likened to a holy and mystical experience because it requires patience, attention to detail, and a deep understanding of its mechanical functions. Sufficient study and practice will result in a form of nirvana where you and the bicycle become one as it performs smoothly and efficiently.
Additionally bike maintenance can be almost meditative or therapeutic, providing a sense of calm and focus. Like any activity that requires skill and practice, bicycle maintenance can lead to a more fulfilled sense of self. It ain’t no waste.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
#122
Imo, conflating washing with maintenance. Its not at all the same thing, but many seem to think washing the bike + chain lube = maintenance, forgetting actual maintenance is more a mechanics type job. - replacing worn parts, opening bearings, bleeding brakes etc. Washing does next to nothing and the chemicals might even be detrimental if they find their way into bearings, the freehub, pivots etc.
#123
Sock Puppet
Liked 863 Times
#124
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
- clean
- inspect
- detect
- correct
Likes For terrymorse:
#125
Grupetto Bob
Liked 5,649 Times
Oh, I think its time for a disagreement!
