First Time Chain Waxer Calling on Chain Waxing Gurus
#152
Quoted: 768 Post(s)
Liked 1,742 Times
I've used them on my chain , but not the cogs, no point in that, they are to simple to clean. However, with the waxing, I just clean them with some hot water and re-wax. easy peasy...
Likes For jaxgtr:
#153
Jedi Master
#154
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
#155
Bikes: yes, i have one
Quoted: 1138 Post(s)
Liked 1,182 Times
You guys are probably right that my cleaning regiment is not necessary from now on. I first waxed this chain only after about 300 initial miles with the Shimano factory grease, so did some extra pre-cleaning this time in case my initial cleaning was not thorough enough.
#156
Liked 1,471 Times
hang on a sec...i still clean mine. i use mineral spirits, two baths, first gets the majority of the grime off, second is just a follow up. the spirits are quite dirty which means the chain was quite dirty. i would not dispense with this. but that is the extent to my prep. drop in wax and take the other out for the bike. rinse and repeat.
#157
My interest in the ultrasonic cleaner is its ability to do a very thorough job of cleaning parts. In the old days we would use Coleman fuel in a shallow tray to clean chains so this just seems to be an improvement on that. At $ 90,00 at Harbor Freight it won’t break the bank...
#158
Liked 1,182 Times
I thought the odorless mineral spirits (or another petroleum distillate solvent, e.g., naphtha) is only needed for the initial degreasing (i.e., prior to the first waxing) to remove factory grease and/or oil based lubricant? You use OMS to clean before each subsequent wax immersion too? Why? If the chain (and the rest of the drive train) had been thoroughly degreased prior to the initial wax immersion, there should be no more grease to degrease, right?
i do use it to remove the original lube because that is very sticky and is a dust magnet but i still wash with mineral spirits. the first bath is quite a dirty grey color from dust, road grime, and i presume residual oil from previous lube style. the second bath is much cleaner but even wiping the chain to dry after the second bath shows residual dark mineral spirits on the paper towel.
chain is running nice by the way. i think this time i'm going to measure how many miles it lasts between waxings. just curious really.
#159
Liked 1,471 Times
because it is dirty.
#160
Quoted: 768 Post(s)
Liked 1,742 Times
#161
It's many years since I last used wax on a chain, but I don't recall any need to free up the links before fitting on the bike. A couple of rotations, given that the chain links were exercised in both directions as it passed over the RD jockey wheels, always seemed to do the trick.
What do they make wax out of nowadays?
#162
Jedi Master
#164
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
I am getting about 300 miles on mine. I have a 2 chain setup going, wax both initially, then swap them out so I will always have a chain ready to roll. Although, I need to do a better job breaking the wax on the clean chain, I put the fresh chain on Friday, went for a 35 mile ride on Saturday and had a link that was a little sticky and it was hitting the rear mech cage brace a little. was more than annoying for about 20 miles and then seem to loosen up toward the end.
#165
Quoted: 768 Post(s)
Liked 1,742 Times
Yea I saw that. I have a fairly long dowel rod, I need to try and rig something up that will be stable and use that.
#166
Quoted: 768 Post(s)
Liked 1,742 Times
Interesting observation.
#167
Liked 1,471 Times
Likes For SoSmellyAir:
