Optimal gear for hills ? Lower or highest?
I keep left gear on 2 (out of 1-2-3)
I have a hill that I can either ride up with right gear switch at 1 2 or 3
At 1, it's easy, but move revs for my legs. At 3, harder, but less revs.
Which is ideal? Is min/max vertex parabola?
Mods please lock this thread. It has been solved.
The answer appears to be 80
https://www.bicycling.com/health-nut...cadence-ideal/
Quoted: 3952 Post(s)
Liked 7,297 Times
Interesting hospital interpreting description extreme encounter.
Quoted: 1034 Post(s)
Liked 1,290 Times
Is there a way to stop these obvious trolling threads? They serve absolutely no purpose other than relieving the obvious boredom of the OP. He should probably simply go outside and ride a bike.
The optimum gear is always dependent upon the amount of dumpster vodka consumed and the thickness of the sponge pad in your cycling pants.
Likes For m.c.:
Quoted: 6193 Post(s)
Liked 4,809 Times
Use the gear ratio and cadence that doesn't leave you tuckered out at the top of the hill. What's good for me might not be good for you. And over time what is good for you now probably won't be good for you later.
That said, I'd use a gear ratio that let me comfortably spin at 80 - 90 rpm while seated. If you prefer a lower cadence, then you might also prefer and do better standing.
Riding a bike is not supposed to be hard. So don't use gear ratios that are hard to push. Unless it's for that last little bit before you can't do any more.
Quoted: 822 Post(s)
Liked 1,960 Times
Somebody's Daddy did not give him any attention in his formative years.
So, there is no conventional wisdom on gear choice?
I might do an A/B experiment.
A: Do entire hill in gear 1
B: Do entire hill in gear 3
Compare heart rate and time elapsed.
Username checks out
Just rode. Hence questions. I ask questions.
If you don't like it, learn to use the ignore feature, instead of whining like an embarrassing little child.
Keep trying. Maybe one day you'll actually be clever and/or funny or whatever you're going for.
Keep doing you, Elmer.
Klaatu..Verata..Necktie?
Quoted: 10425 Post(s)
Liked 11,899 Times
Optimum depends on the rider. Some folks like to mash, some like to spin. Personally, I find myself most comfortable doing long seated climbs in the 80s. If I find myself wanting to shift to a smaller gear, (larger cog in back), it's usually because my cadence has dropped below 80. If I find myself wanting to shift to a larger gear (smaller cog in back), it's gone over 90. That's me. YMMV.
Quoted: 3241 Post(s)
Liked 2,512 Times
The answer is 42.
Likes For seypat:
Liked 4,809 Times
Not as far as what specific gears. And that choice will depend on whether it's a easy grade where a steady speed can be maintained all the way up the hill or whether it's a steep grade and speed will diminish from the entry speed for the climb.
And many other factors that we just don't know about your climb or you.
Sounds like a plan. Nothing like trying things out to see what you think works best for you. Data to back it up always helps too.
Quoted: 4227 Post(s)
Liked 2,488 Times
I use non-optimal gear ratios for hills, has worked great for me so far and made me a better stronger climber.
Liked 2,488 Times
No there isn't... The choice of gear ratio varies depending who you ask ...Some people like smaller gears and prefer climbing seated, while others prefer standing on the pedals and riding out of the saddle and pushing bigger gears.
Liked 1,290 Times
Username checks out
I do know how to use the ignore function thank you. Sometimes however, people enjoy watching train wrecks. Yours though have become more frequent, and tend to serve no real purpose.
As for an answer to your "question," use the gear that allows you to pedal efficiently without mashing, thereby damaging your knees.
Okay, thread over, unless you need the proper gear ratio for hopping curbs carrying the extra weight of a golf club.
Quoted: 18415 Post(s)
Liked 15,546 Times
Liked 15,546 Times
Likes For indyfabz:
Liked 15,546 Times
Should Be More Popular
Quoted: 22598 Post(s)
Liked 8,925 Times
Quoted: 4806 Post(s)
Liked 3,928 Times
Actually 42-24. The nice symmetry. Lowest gear you can get with time honored classic 144 BCD crankset, 1/8" chain and proper fix gear cogs. (Of course, there are hills where your legs will scream for 42 gear inches. not chainring teeth. Don't listen to them. They're just legs and not very smart.)
Liked 2,488 Times
Likes For wolfchild:
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Try different gears and see what is most comfortable for you. Conventional wisdom is meaningless, no one else is on the bike with you. You aren't going to blow your knees out, you'll know very quickly if you're uncomfortable.
Seriously, do you suffer from some of an anxiety disorder that prevents you from trying things for yourself without someone telling you that you won't hurt yourself? This incessant asking of questions we can't answer for you because they're obviously personal preference is not normal. 1 or 2, maybe, but this was going on all last year, stopped for awhile, and is ramping up again. I'm not asking for smartass reasons, I'm just thinking you've lost any reasonable perspective.
Tragically Ignorant
Liked 9,098 Times
Likes For livedarklions:
The post about an uncomfortable saddle in which he referred to "sperm tubes" leads me to think there is some trolling taking place.
