My new '83 Trek 400
My new '83 Trek 400
I picked this up off craigslist in my area for $50, I'm going to convert it to single speed and I have a few questions:
I'm going to strip/paint it myself, and there are a few rust spots. I'm thinking since I want an even coat, I should strip the whole frame with chemical stripper, then sand down the rusted spots, anything wrong with this idea?
Does anyone know what size BB I need that will fit and give me a 42mm chainline?
Does anyone have any experience with these bikes? It's mangaloy 2001 tubing
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Suggest you try the fixed gear/single speed forum. They will be able to give you a lot of info.
If you want to return it to good, stock, running condition, this is the better forum.
brain damaged bovine
Location: back on the dental floss ranch, wielding zircon encrusted tweezers
Bikes: Schwinn wrecked ol' Probe 1x2, 84 Bianchi Limited,Cannondale F400,Raleigh 20 folder,78 Schwinn LeTour III Fixed Gear,Redline Conquest Pro,71-73 Gitane TdF,Gitane Grand Sport de Luxe,78 Raleigh Super Course,80 Schwinn World Sport
^^^ Nice exercize of restraint there Thrifty Bill.
Dropped
From the frame painters sticky, some guidelines from Dr. Deltron:
https://www.bikeforums.net/showpost.p...0&postcount=20
There may be more good info in the sticky; might be worth perusing.
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
Before you consider repainting, consider polishing her out with KIT Scratch Out or Meguiars Scratch X. You'll find that the original paint, as is, is a lot nicer to live with then a cheap rattle-can job that will chip to a state worse then the original paint is now within a week.
-Kurt
-Kurt
By the way, nice find for $50
EDIT: Well maybe it's not Imron. I can't remember if the lower-end Treks had Imron or not, but the original paint is still your best bet.
Liked 4,396 Times
Well, that is not necessarily true. I can get a rattle can job to look nearly factory myself, but as the paint has no catalyst in it, you can just as well hang the frame up for 6 months before the paint becomes remotely hard - and even then, the first time a penny falls on the paint, you'll have a nice fat chip in it. As the paint is - and will remain - soft, it'll also be attracted to road grime quite easily, dulling whatever is left of the paint reasonably quickly.
-Kurt
-Kurt
Alright well I'll sand down the rust spots before I strip any paint, and then post close up pictures of the paint job/chips, if I can find touchup paint/nailpolish that matches the silver exactly I may just keep the original paint. I also have an 87 trek 400 elance that I kept the original paint on and it's help up great over the past few months.
Thanks for all the input
Liked 4,396 Times
cudak888: you sure it won't damage paint? Should I just get some wood bleach with oxalic acid in it and use that, or order labratory grade oxalic acid?
Liked 4,396 Times
That said...
Everything You Wanted To Know About Oxalic Acid, But Were Afraid To Ask:
https://www.bikeforums.net/showthread...nt+acid+oxalic
-Kurt
Bikes: 2 Centurian Ironman, Rossin Genisis, Greenspeed GT3, Stowaway (wife)
please don't remove any of the braze-on's or cut off the gear changer hanger. It can then be put back to multi-speed service in the future.
Gone World Hepster
Liked 7 Times
From the '83 Trek Brochure:
'The Trek Model 400 is the first Trek International Series Bicycle. The International Series designation distinguishes a Trek-designed frame, which has been imported in unfinished component form from Japan, taking advantage of the latest high volume production technology for heat tolerant Manalloy tubing. These frames are finished, painted and assembled at the Trek factory to exacting standards.'
I'm willing to bet you can find a very close match to that metallic silver Imron paint on your Trek at your local hobby shop; Testor's has one that I've used before that matches up nicely.
