Chainring $40 vs $125
Live Healthy
Bikes: Wabi Classic
Quoted: 183 Post(s)
Liked 137 Times
Currently I have a stock wabi chainring$40 on my wabi classic (single speed) and thinking of buying a DuraAce chainring $125. Due to my 16t WI freewheel my options are limited to 3/32 -144mm. Is the DuraAce worth the upgrade? Am I going to notice a big difference? Any thoughts before I pull the trigger?
I ride about 100 miles a week for cardio exercise and no hills.
thanks
thanks
Not lost wanderer.
Quoted: 886 Post(s)
Liked 998 Times
Wear out the stock one first and then change, I feel you will not know the difference until you need a new one.
Quoted: 99 Post(s)
Liked 115 Times
I work in Pounds, but the principle will be the same:
Diminishing returns.
A $20 chainring may be twice as good as a $10 chainring.
A $40 chainring may be "noticeably better than" a $20 chain ring.
Very few people will genuinely notice any real world benefit from an $80 chainring compared to a $40 chain ring.
When the rest of your bike is perfect, buy a $125 chainring.
You will get more performance benefit per Dollar by spending on tyres, pedals, or seat.
If I were going to splash out on either, I would spend a bit extra on the sprocket rather than the chain ring.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
A quality chainring like that is generally going to be rounder and have better tooth profiles rather than just stamping it it is likely machined or machined a lot better and probably out of a stiffer material to reduce flexing. Some also might have coating like a TiNi coating to reduce friction as well. This is not Dura-Ace specific but indicative of other higher quality chainrings.
Quoted: 2432 Post(s)
Liked 638 Times
If I knew the DA was perfectly round and I wouldn't have any tight spots on the chain like I do with my Wabi ring I would buy one. But that's a lot of money for something I'm not positive of.
Likes For Lazyass:
Likes For Mikefule:
Likes For jay4usc:
It's the little things
Bikes: Too many, yet not enough
Quoted: 279 Post(s)
Liked 326 Times
Mojo, in my humble opinion, has great cogs and chainrings for the money.
No experience for DA, nor Wabi, but couldn't imagine spending that much on a DA unless I only had one bicycle or raced competitively. My opinion and thoughts.
Maybe I'm so slow on a bike, that I rarely notice it, but does the tight spots ruin your cadence/speed? Is your chain excessively tight? Just curious.
Live Healthy
Bikes: Wabi Classic
Quoted: 183 Post(s)
Liked 137 Times
Quoted: 279 Post(s)
Liked 326 Times
I do believe there used to be a larger selection of decent chainrings. Seems like they are not as plentiful as they used to be.
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
Another very good choice for a lot less money than Shimano Dura Ace is the Canadian Blackspire 144 bcd chainrings, which are available with 3/32" wide teeth. They are CNC machined from top quality 7075-T6 aluminum and are extremely round. The problem is that they are only available in black and quite hard to find at the present time. I own a Wabi Lightning, and the stock Wabi chainrings are not very round. I replaced mine with a Blackspire, and the difference is very noticeable. You can see how it looks in the photo, and can also see that I've replaced practically all of the stock Wabi components except for the wheels.
2011 Wabi Lightning Scandium
Likes For TejanoTrackie:
Live Healthy
Bikes: Wabi Classic
Quoted: 183 Post(s)
Liked 137 Times
Veteran Racer
Liked 764 Times
Different grades of aluminum can be stronger and/or harder, but they are NOT stiffer because the modulus of elasticity does not change. So, a better grade of aluminum will not result in a less flexible chainring. The only way to increase chainring stiffness is the increase the amount of material used, which is why solid chainrings like the Sugino Zen are stiffer than chainrings with cutouts like the standard Sugino 75 chainrings. None of this matters in the real world, since most of us are nowhere near enough powerful to notice the difference.
For the record, the Wabi chainring is an Andel chainring / crankset . . . Great chainring on a budget IMO. I have a 46t Andel (Wabi) on one Wabi Classic and a 48t Sram Omnom on the other. Don't really notice a difference.
Live Healthy
Bikes: Wabi Classic
Quoted: 183 Post(s)
Liked 137 Times
Live Healthy
Bikes: Wabi Classic
Quoted: 183 Post(s)
Liked 137 Times
I just installed the new chainring today and the Blackspire is definitely an upgrade compared to the Andel ring. It’s much rounder and I notice a significant difference on the dead spots on my cranks where there’s very little play with the Blackspire. There’s also very little difference on the loose and tight spot on my chain. It’s a great upgrade for $59
Likes For jay4usc:
thanks
thanks
Quoted: 967 Post(s)
Liked 1,629 Times
Also... I have noticed that everytime I upgrade some little thing, no matter how small, on my bikes they seam to go faster... Ha
Liked 638 Times
I read somewhere else that the Sugino Zen is perfectly round and has no tight spots in the chain. Then I looked at saw they cost $245 and woah. But I read the details and it also sounds like the chain would be super quiet with the profile of the teeth. Has anyone ever had one? I'm actually considering getting one despite the price. I wouldn't feel too bad since I've had my Wabi for a year and a half and have never spent money on it yet, I've kept it totally stock. I actually like all the components it came with. Even the stock racing saddle is the most comfortable modern one I ever had.
Machined from stiff 7075 T6 aluminum, the Zen is one ultra-round, super-rigid ring.
These mighty chainrings also feature the SSGN super smooth tooth profile, which means the tooth valleys are rounder and the side tooth profile is smoother than standard Sugino 75 rings. This process helps greatly reduce chain noise and improves ring/chain engagement and wear.
Veteran Racer
Liked 764 Times
As an aside, the statement that the Sugino ZEN is "machined from stiff 7075 T6 aluminum" incorrectly implies that there is a correlation between the stiffness of aluminum and its grade. This is untrue, since the modulus of elasticity of all grades of aluminum is the same. The reason that a Sugino ZEN chainring is stiffer than other chainrings such as the standard Sugino 75 chainring is that it is a solid section with no cutouts, and any other chainring made this way will be equally stiff. What can be said is that 7075 T6 is stronger and harder than lower grades of aluminum, and will last longer.
Liked 638 Times
I see the Zen is on ebay for $195. I ride 100-200 miles a week and a quiet drivetrain is almost worth it. Might have to get one despite it being overpriced.
Likes For Lazyass:
Clark W. Griswold
Liked 3,994 Times
I don't see something of quality being overpriced. I use one as well and with my current drivetrain things a smooth and quiet and look good. Yeah it costs money but they aren't just stamping it out and calling it a day. You aren't buying derailleurs or shifters or multiple chainrings or cogs (maybe chainrings and cogs if you race or change ratios often) so spend on a nicer drivetrain and reap the benefits.
