Climbing Speed
Climbing Speed
I should really have titled this thread "Pitiful Climbing Speed". Anyway, looking at the data from many rides (road, mountain and gravel) I've noticed that on long rides my climbing rate (elevation change / time) is always about the same (a slow 1000-1200 ft/hr). It doesn't matter if it's a 2% grade on the road bike or a 12% grade on the MTB - on long rides where I'm staying at a comfortable aerobic pace it always end up about the same. I can go 2-3 times as fast on shorter climbs, but once it's longer than maybe 15-20 minutes I always end up plodding up at the same rate.
My question isn't what speeds others climb at. Obviously the strong riders here will climb much faster. My question is whether others also tend to a fairly constant climbing rate on long solo rides regardless of conditions.
BTW This becomes really obvious looking at bike computer outputs of elevation plotted against time - all my hills then look like they have exactly the same slope.
Liked 2,159 Times
If I were to plot my speed against the grade, there'd be a consistent and repeatable decrease in speed as the grade increases. I can usually maintain 15 mph up to 2-3%, and then it goes down to about 3 mph around 9-10%. I guess my power, heart rate, and respiration rate go up as the grade increases from that point, as I'm huffing and puffing more, but it's easier to work harder than to stay upright over that.
FWIW, you might want to zoom in on your hills and see if there's any variation in the grade. Modern road engineers like to keep grades at 6% or below, but I think there are some hills with older roads out in your county where the grades are more challenging.
I think you misunderstood my question. I'm not asking how fast you go, but how fast you go up. In fact, your numbers confirm my suggestion: 2% x 15 mph = 10% x 3 mph - a consistent 0.3 mph climbing rate (which is about 1500 ft/hr).
Likes For wayold:
Bikes: Lemond Zurich/Trek ALR/Giant TCX/Sette CX1
Liked 1,125 Times
Full gas over a 1+/- hour effort - 3040 ft/hr, or VAM of 920. Normal climbing I can do 1500-2200 ft/hr,
That is about 1/2 of what the average elite rider can do.
From what I understand - the steeper the incline, the higher VAM you can achieve. You are rolling slower, but have less aero drag and rolling resistance, so you can climb/gain elevation at a faster rate.
climber has-been
Liked 4,059 Times
As long as you're producing consistent power, the steeper the grade, the higher your climbing rate.
Before the days of power meters, climbing rate was the thing to watch. Now that power meters are more common, the focus on climbing rate has diminished.
I no longer even look at my climbing rate. What's important to me is average power over a specific climb.
I'm just happy if I can get to the top of the danged hill.
Likes For Bald Paul:
Liked 5,404 Times
If it's a short climb such as the rolling hills around me that are 1000' of distance and just 50' of vertical gain, then I'll rip up them as fast as I can, while taking into account the distance I plan to ride and the remaining hills I'll need reserve energy for. After each hill, I can recover on the backside going down and the brief false flat till the next climb.
Regardless of which type of climb it is, HR and my PM give me clues as to whether I can go faster or slower than the time before.
Liked 3,932 Times
Liked 3,932 Times
To respond to the thread ... i assume everyone has a comfortable balance of power and breathing/heart rate which they know t from experience or sort of osmosis (absorbed unconsciously into the brain through repetition) which they revert to.
With a mighty wind
I used to live near a 12 mile dirt road that had 3 or 4 thousand feet of climbing.
My times up it with an 18lb road bike with a low gear of 34x30, a 22lb gravel bike at 40x44, and a 29lb MTB with 30x46 were all almost the same.
I haven’t lived there in a few years. I miss that hill.
I always try to maintain a climbing speed consistent with not falling over
Likes For Steel Charlie:
If we ignore aero losses, the rate of climb will depend on the power. Same power, same climb rate. For a lower gradient, you'll cover more ground horizontally, but the same vertically. I.E., you'll have a higher speed, but not higher vertical speed in ft/min or m/sec. or furlongs per day (pick your units).
But again, I think you "misspoke" as it would make very good sense to use climb rate as a stand-in for power which you say was used before power meters.
Likes For Mtracer:
Perceptual Dullard
Likes For RChung:
climber has-been
Liked 4,059 Times
This is for default rider at 200 Watts:
If you want to set a climbing rate PR, find a road that's 8% or greater.
Back in the day, I could manage 5000 ft/hr on an 8% grade, for a handful of minutes. These days, not going to happen. I'm content to do tempo at 3000 ft/hr on an 8% grade.
Although I did do a short sprint climb yesterday, just to see if I still had it. 16.1 mph, 5.7% grade, 4800 ft/hr. That felt hard, 6.5 W/kg. Glad it was less than 1 minute.
Commuter
Bikes: Main Bikes: 2023 Trek Domane AL3, 2022 Aventon Level.2 eBike, 1972 Schwinn Varsity, 2024 Priority Apollo 11
Liked 519 Times
I don't worry about it. I'd rather climb slowly in a low gear than burn my legs out trying to be faster.
I like to save some legs for the descents and to finish the ride strong.
Unless you're a pro, who cares?
Likes For Smaug1:
Liked 3,302 Times
if i am familiar with the climb* I tend to start & finish about the same rate. The middle area is often flat with a consistent power output.
-YMMV
-YMMV
climber has-been
Liked 4,059 Times
Liked 3,680 Times
I put my head down, downshift & work. if I keep moving forward, I'm happy
Likes For rumrunn6:
In the context of the OP, do you calculate your climbing rate or are you, like most people, trying to get up the hill/climb as fast as possible w/o toppling over? If the latter, then I'd agree that it shouldn't really matter".
Bikes: 1999 Giant ATX MTB, 2002 Lemond Zurich, 2018 Fuji Transonic 2.3, 2019 Specialized Tarmac Disc Expert
Liked 421 Times
I just try to ride the bike up the hill. I'm not really concerned with anything else.
Zircon Encrusted Tweezers
Likes For Steamer:
Liked 5,404 Times
Which in fact is much like I do too. And I definitely am not a pro cyclist.
Of course it shouldn't really matter whether a cyclist riding for just recreation rides that way or not. They should ride how they like to ride. But they also shouldn't make disparaging remarks about those of us that do like to push on our rides to see what we are able to do.
Likes For Iride01:
Commuter
Liked 519 Times
Obviously, the OP doesn't train hard enough to improve his climbing speed. The real question is whether it's worth the effort to him.
Habitual User
Bikes: 2023 Niner RLT 9 RDO, 2022 Trek Supercaliber, 2018 Storck Fascenario.3 Platinum, 2003 Time VX Special Pro, 2001 Colnago VIP, 1999 Trek 9900 singlespeed, 1977 Nishiki ONP
Liked 8,947 Times
Reviewing Strava data, it looks like climbs with grades above 5%, riding at a threshold effort, my VAM is 800-850 (2625-2790 ft/hr). Occasionally, I'll get into the upper 800s, but nothing sustained over 900. I weigh 180-185lbs.
Platypus gravelus.
Platypus gravelus.
Likes For Eric F:
