Chilly in morning, warmer in evening - What to do with layers?
I wear a jacket in the morning but it is too warm in the evenings. Obviously I need to the jacket at home for the next morning. I generally just have a bag on the back of my bike (see below) and it already has things like a thin face mask, this that and the other.... other things that are likely to be needed if the weather turns a bit colder or is worse going in than out, etc. I don't seem to have room to carry my jacket, which is more bulky than a higher-tech, more expensive one. Do you just suck it up and wear it home or strap it to your bike somehow? Do you just make sure you have enough storage to put those things and therefore don't have the issue to begin with?
Thunder Whisperer
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times
Put your jacket on top of the bag and strap it down with a cargo net?
Community guidelines
Bikes: 2012 Venge, 2011 Transition, Surly Troll
Quoted: 5793 Post(s)
Liked 2,594 Times
Either get a slightly bigger bag, or pack lighter, or strap the jacket down. You might use a larger bag or pannier to prelocate spare clothes t work once a week or so.
It isn't too complicated,------ improvise.
OR
Here's something I started doing this summer. The USPS offers something called "Regional Flat Rate Boxes". These come in 2 sizes and cost $5.32 or $6.16 to ship locally depending on the size. Plus they're generally delivered overnight for about a 30 mile radius. So I use these to periodically the imbalance in stuff I haul between home and work (spare underwear, socks, rain gear, etc.) when I'm too lazy to bother carrying my messenger bag for the commute. It was really nice all summer, because I could travel light, and make a pleasant long ride of it going home in the evening.
OR
FB
Chain-L site
FB
Chain-L site
Quoted: 69 Post(s)
If I need to strip my jacket off mid-ride and don't have time to stuff it in the panniers (e.g., at a red light), I just tie it around my waist. As a bonus, it adds a little padding to my saddle!
Just a person on bike
Bikes: 2015 Trek 1.1, 2021 Specialized Roubaix, 2022 Tern HSD S+
Quoted: 132 Post(s)
Liked 86 Times
I wear my Shower's Pass rain jacket in the morning. I fold it up and put it in my pannier on my way home.
The value of your life doesn't change based on the way you travel. - Dawn Schellenberg (SDOT)
All good thoughts. Thanks everybody.
Bikes: 2006 Specialized Ruby Pro aka "Rhubarb" / and a backup road bike
Quoted: 7 Post(s)
Liked 13 Times
I recommend putting the jacket into some kind of bag then strapping it to the top of your trunk bag.
Too many times I've seen the sleeves work their way loose and flap around. You do not want them getting into the spokes.
A bag will also keep the jacket cleaner and drier. A small plastic shopping bag is fine.
Another approach is an ultralight drawstring backpack. They work great for bulky but light and soft things like jackets, baselayers, and tights. Good if temperatures are below 75F.
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
Get a big backpack and tie it with bungee cords to the rack. That's what I do.
You could also try with panniers, though they are sometimes less convenient.
Colder weather - more clothes to change, more room. It's normal.
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
If all else fails, I carry a rack strap like this one to bungee stuff to the top. I don't use it that often, however.
Stuart Black
Stuart Black
I wear a back pack as part of my "winter gear" mostly for storing layers.
It's hard to tell from your picture but it looks like your bag expands. Does it have a second zipper on the top that goes all the way around the bag? Even if it doesn't expand, it's not that difficult to get 10 lbs of potatoes in a 5 lb sack. Put anything small...socks, underwear, gloves, etc...in the side and rear pockets. Put larger stuff in the top compartment and then roll everything else as tightly as possible in the main compartment. I've been using rack bags exclusively for about 30 years...I hate using panniers...and I live in an area where the temperature can be 20 F in the morning and 75F at night.
I do have a Burly Travoy that I use when I need to take several days worth of stuff in but I don't pull it just to put a jacket on. I think the combination of freeing up room in my rear bag and using a bungie strap will get me by.
I thank everybody for their input.
Bikes: Trek Mtn Bike
Quoted: 282 Post(s)
Liked 2,646 Times
I just put my jacket in my backpack. If it won't fit I strap it to my pack.
In your case, if the jacket won't fit in your rear bag, roll it up and strap/bungee it to the top of your bag. Watch to make sure the sleeves won't work loose and get in the spokes. Done that already.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
Two words: 100 jackets
Used to be fast
Bikes: 85 Specialized Expedition, 07 Motobecane Immortal Spirit built up with Dura ace and Mavic Ksyriums, '85 Bianchi Track Bike, '90 Fisher Procaliber, '96 Landshark TwinDirt Shark Tandem, '88 Curtlo
I wear a jersey on my commute. I often roll up my jacket and put it in one of the rear pockets.
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Bikes: '07 Trek 520, '09 Gary Fisher Triton, '04 Trek 8000, '85 Trek 500, '84 Trek 610, '85 Trek 510, '88 Trek 660, '92 Trek 930, Trek Multitrack 700
Quoted: 19 Post(s)
Bikes: trex 7500, old diamondback, older diamondback old frankenbike
with fall/winter here now, I have to have full size panniers. As I not only have to layer for the cold mornings, but also be prepared for the rain too.
When I don't need the big panniers, I also have a bag that looks like your top bag, but mine has drop down mini panniers. If it wasn't for all the rain gear, it would easily hold the "layers"
mines like this , but made by "Giant"
https://www.amazon.com/Eleven81-State...ags+expandable
