On / Off switch wires
Rebuilding a battery pack with an On / Off switch with 2 reds wires not sure where to connect them to in the battery pack, it was convenient to be able to turn the battery off
Its the red switch in the picture with 2 red wires going from it
Quoted: 340 Post(s)
Liked 275 Times
IF you're using the old BMS. it was connected to the switch. If you replaced the BMS in your rebuild, than you needed a BMS with an ON/OFF circuit.
Likes For Doc_Wui:
