Anyone use one of these?
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 460 Times
I have a hobby room I'm going to use for fishing gear and cycling gear. I think one or two of these would look good to store and show my bikes during the winter. Anyone use one of these or any other suggestions?
I was using a somewhat similar "Gear-up" oak floor to ceiling rack until recently. I worked pretty well when I had my bikes all stored in a utility room. I've moved recently and it's pretty obnoxious in an apartment. I felt like I was back in a dorm room. Therefore I'm giving mine away, BTW, to anyone that can pick it up in LA.
I guess you can hold up to four bikes if you put it out into the room, but at that point I'm not sure if you are saving space - more like hogging it. If you wan't them on display, it does that.
Quoted: 235 Post(s)
Liked 349 Times
I use 2 Bike Nook stands. Bikes stand vertically- one in each rack. I have a road bike in one and a mountain bike in the other. I am very happy with them.
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
I had something essentially the same (architecture) but a different company. It was stable enough on carpet (apartment here) and could hold four bikes. The use of vertical space was great HOWEVER since I am a tall guy with tall vintage frames, the hook location for the bottom rung was at the seam of the stacked vertical box section and the frame hooks/arms hooked into holes in the box section. I made a makeshift spacer on the bottom to boost the height to be able to use the lower frame hooks as well as the upper ones and have the bikes sorta not hit each other. It ended up being wobbly--on top of the frame not liking being loaded on only one side. I sold them, happily. I now line up four bikes side-to-side, facing alternating directions, and it takes up just 15% more floor space than that thing did. I'd be ok trying it again, but it would have to be a two-bike vertical wall lean-er where I could have a grid of four bikes on one wall, which would open up floor space. I'd really need to sell extra framesets, but that could be done.
If you're not running 63+cm frames (like, 60cm or so MAX) then you'll be good. These rubber frame hooks open up mounting flexibility really well.
Randomhead
Liked 3,697 Times
I helped the LBS move storefronts, and they gave me a stand like that. I swear it almost made me cry a couple of times when I was trying to put bikes on it. The hooks would just slide down. I'm not sure if it is the same brand as that one or not, but I suppose the hook sliding phenomenon is possible on any of them.
Sliding isn't quite right, the hook would bounce its way down the pole. Put the bike back down, put the hook where it was, touch it with the bike, bounce back down.
I see absolutely no advantage to the "easy" adjustability of those hooks. Something that stays where you put it would be far superior.
Bikes: Some Schwinns, Raleighs, Centurions, Crescent, Bianchi
Quoted: 248 Post(s)
Liked 289 Times
I'm dealing with storage issues right now. Is it ok to hang a bike by the rear wheel on a rubber coated bike hook or should I stick with two hooks under the tt?
Quoted: 378 Post(s)
Liked 1,409 Times
Michelangelo makes a similar one that has to lean against the wall, and it pretty much is a bit more than worthless.
Apex makes a black one, thick arms, single post, one that needs to lean against a wall. Done right (no pedals), you can store two on each set of arms, so have four in about the same space. Pretty cheap, too. Be sure to put some pads on the rail, or you'll mark up the wall.
Bikes: Fuji Finest, Trek 460, 970, Miyata One Ten, Maruishi 606, Univega Alpina Uno LX, Browning Grade V
Quoted: 13 Post(s)
I've been hanging them by the front wheel for over 40 years and never found one out of true. Even heavier bikes should be OK as they have sturdier rims.
Quoted: 1372 Post(s)
Liked 1,751 Times
What ever you use to hang a bike from its wheel, put some extra padding on the hook. If the bike is left for a long time, eventually, there will be a mark made on the rim - hence the extra padding. I just use an inner tube wrapped and taped into place. Works just fine. Also...
When I say extra, I mean it. All of my hooks are coated with something sorta soft, but it is not good enough, in my opinion. Though I have never damaged a rim by hanging a bike on a hook, I have seen lots of rims come in, still attached to the bike, of course, that did sport that damaged section.
As for a free standing stand - not a chance. Anything free standing might, one day, turn into something free falling. I choose to not take the chance. Besides, I like the look of bikes hanging. Note - the bikes pictured are not mine, nor is there any extra padding. All of these bikes were prepared for a bulk sale to a fellow in Toronto...
Bikes: 1980 Koga-Miyata Gentsluxe-S, 1998 Eddy Merckx Corsa 01, 1983 Tommasini Racing, 2012 Gulf Western CAAD10, 1980 Univega Gran Premio
Quoted: 600 Post(s)
Liked 11 Times
I've used the Michelangelo leaning bike rack (2 bikes) for years. I had 3 in the States, and now one here in Amsterdam. I find them surprisingly stable, and even with only one heavy bike on the top set of hooks (Schwinn Panther), it was dead stable against the wall. I also think they look pretty good, and they become almost invisible when bikes are mounted. Things to watch for are the silicone rubber sleeves (on the hooks where the bikes hang, and around the curly base of the hooks) can slip around, so if you adjust things a lot you need to make sure they stay in place. I also now put a zip tie or a couple of turns of electrical tape at the attachment point of the hooks to the racks, just in case, once I have the hook arms exactly where I want them.
I bought a free standing 4-bike racks for some friends when I was staying with them. Don't remember the brand, but was from Amazon. It was sturdier and bulkier than what you have in the first photo. Worked well, and was stable even without being fully loaded (i.e., one bike or 2 only on one side was fine). What I didn't like about it was it had to sit out in the room to get to the bikes on both sides, and it was in the living room, so we were always bumping into bike wheels when we walked around it. It's also not very good for display.
Bad example
Quoted: 825 Post(s)
Liked 210 Times
I also use a Delta Michaelangelo rack in our apartment in Reims. It can be screwed to the wall at the top and has proven to be perfectly stable for our two bikes.
Bikes: 2011 Handsome/ Twin Six Speedy Devil, 2006 Soma Groove, 1991 Haro Impulse Comp, 1987 KHS Montana Pro, 1986 Ross Mount Hood, 1986 Mongoose ATB, 1985 Shogun Prairie Breaker I, 1973 World Voyageur, 1941 Schwinn DX "Klunker"
Quoted: 83 Post(s)
Liked 96 Times
I like the look of the Venzo bike hangers. Makes the bikes seem more like art.
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Hanging bikes by the wheels
The floor joist in my basement are just the right width.
verktyg
Chas. ;-)
Chas. ;-)
Quoted: 3015 Post(s)
Liked 3,802 Times
I made my own. There is a keyhole slot on the back, panhead screws into the studs on 16-inch centers, and bobs yer uncle.
20181013_104308 by iabisdb, on Flickr
20181013_104339 by iabisdb, on Flickr
Quoted: 1607 Post(s)
Liked 2,216 Times
@MrK. I like those! did you use the ones with the supports under the wheels or just the pedal?
Quoted: 677 Post(s)
Liked 460 Times
feros ferio
Quoted: 1393 Post(s)
Liked 1,325 Times
I hang my bikes by both rims from the garage rafters, using bicycle storage hooks. (Seemed appropriate. )
I envy you guys with basements, spare rooms, etc., but my wife gets the original garage for her art studio, and the grandsons get the third bedroom when they visit or sleep over, and the second bedroom is just big enough to serve as my home office. Space for a larger storage shed belongs to my wife's rose and iris garden.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
I figured out two hooks cost twice as much as one hook, so I have been using one hook for years. If a rim can support my fat as@ on the bike, then surely it can support a 26 pound bike.
Quoted: 677 Post(s)
Liked 460 Times
feros ferio
Liked 1,325 Times
Happy wife (45th anniversary 4 months ago) ... happy life.
Quoted: 83 Post(s)
Liked 96 Times
