Indoor Trainers - Conversion to miles ridden?
Bikes: 2010 Felt F1 SL, 2007 Trek Madone, 2007 Klein Q Elite XV, 2006 Lemond Tete de Course, 20099 Salsa Chili Con Cross Team Clif,
Is there some conversion chart or something out there where I can figure out how many miles I have ridden on my indoor trainer? I obviously will have time and also cadence off my cyclecomputer.
Carpe Diem
Bikes: 2007 CAAD9; 2014 CAADX; PedalForce CG1
Why do you want to know? 1 mile on the trainer is not equal to 1 mile on the road.
"When you are chewing the bars at the business end of a 90 mile road race you really dont care what gear you have hanging from your bike so long as it works."
ΛΧΑ ΔΞ179 - 15% off your first Hammer Nutrition order!
Faster but still slow
Bikes: Trek 830 circa 1993 and a Fuji WSD Finest 1.0 2006
That factors in things like coefficient of friction, body weight, and wind speed?
I'd like to satisfy my curiosity more than anything.
Carpe Diem
then the easiest way to do this would be to get a bike computer with a rear-mounted sensor. I'm sure there's a math formula that can derive distance based on your cadence, gearing and wheel circumference, but really, it'll be a hassle.
LOL..1 mile is 1 mile whether it is trainer or road. The only difference is the factors that make that very same 1 mile more or less difficult.
Stop thinking so literally and pointing out things everybody knows. That isn't the point. Riding 1 mile on a trainer is far easier than 1 mile on the road. Therefore it is pointless to try and even calculate it.
There are so many variables that go into how different it feels riding on the road versus the trainer that you cannot come up with a conversion.
Simmer down dude...i was just kidding. Oh and 1 mile downhill on the road would be easier than 1 mile on a trainer or rollers.
Videre non videri
Bikes: 1 road bike (simple, light), 1 TT bike (could be more aero, could be lighter), 1 all-weather commuter and winter bike, 1 Monark 828E ergometer indoor bike
Ride 20 miles outside with a HR monitor, and take note of the time it took you to ride those 20 miles. Get on your trainer and ride for the same amount of time, and get your average HR and max HR up to the same numbers as for the outdoor ride. The number of miles you rode on your trainer, divided by 20, will then give you a nice conversion factor.
My idea of fun
Bikes: '06 Litespeed Tuscany, '02 Kona Lavadome, '07 Giant TCR Advanced, '07 Karate Monkey
Quoted: 41 Post(s)
Liked 59 Times
Depends on the speed and the hill.
Then along with the time you could calculate distance.
The only way to do it is get a power meter and HRM. That's it. Nothing else will give you a clear indication of the effort and power output.
however, that still won't "translate" into miles, just as an outside ride doesn't either. If you ride 20 miles outside at 20 mph but there's no wind and then two days later you ride 20 miles at 15 mph but there's a 15 mph wind going against you, it doesn't mean you lost ability.
Guest
Posts: n/a
Quoted: Post(s)
https://www.kurtkinetic.com/computer_tech.php
If you use virtual riding simulations like Tacx or Spinervals, they calibrate the power output to be identical to the actual road coarse.
Ride one mile on trainer at 53X12, 100rpm, then tell us it's easier than the road.
Bikes: o5 Specilized roubaix Comp, 06 Tequilo
Unless your trainer is a lot different than mine you dont actually go anywhere when you us it. So there are no miles involved. Also no mph involved. Time on a trainer is time so can only be measured in time. If you have hrm you can measure calories burned but any kind of ratio to calories burned while riding is meaningless.
Guest
Posts: n/a
Quoted: Post(s)
With the kinetic, this speed matches road speeds at the same power output. you can even calculate watts, which is most accurate.
This one is easy. You went zero miles.
When I am on my trainer, I am concerned with resistance. Sometimes I look down and see that my speed is around 30mph because I am in a big gear with very low resistance settings on the trainer. No formula is going to make that translate into miles on a hypothetical road. Stick with time.
Originally Posted by DocRay
You can get this information here, written by people who know what they are talking about, also power outputs and conversions for most trainers:
Unless it was a one mile downhill, I couldn't ride 53 x 12 at 100 rpms on a road. Not to mention, my bike doesn't even have that gear set up.
Since at 34.5 mph there is a considerable wind resistance to overcome, it should be tons easier on a trainer than on the road. I don't know how you can think the trainer is harder assuming no additional resistance.
It is all a moot point for me anyway. I ride rollers. Trainers are for sissies.
But, yes 200 watts is 200 watts. If you have a nice program and a way to measure wattage that is the way to go.
The rear wheel spininnig at any given rpm while actually stationary has aboslutley no realtionship to distance.
Quoted: 24 Post(s)
Liked 42 Times
"The rear wheel spininnig at any given rpm while actually stationary has aboslutley no realtionship to distance."
"Riding 1 mile on a trainer is far easier than 1 mile on the road."
I don't agree with these statement. I use a Powertap on my bike (used to use a rear wheel mounted Cateye Astrale computer) both on my Kurt Kinetic Trainer and outside. The speed recorded for a given power output is surprisingly similiar inside and outside. My perceived exertion is higher inside though (there is no coasting), so the trainer is definitely more difficult.
Indoor training would also be much less useful (and less interesting) if I didn't have feedback from these devices to structure and follow my workouts. I would never train indoors with only a clock and cadence sensor.
Somewhere in CA
-J
Dirt-riding heretic
Bikes: Lynskey R230/Red, Blue Triad SL/Red, Cannondale Scalpel 3/X9
Quoted: 5 Post(s)
Liked 8 Times
There's nothing magical about the resistance on the road that makes it more "real" than resistance on a trainer.
"Unless he was racing there was no way he could match my speed."
Guest
Posts: n/a
Quoted: Post(s)
Time means nothing if you are just trolling along in an easy gear for 45 minutes.
Trainers are best used for intervals so severe they cannot be completed on the road safely.
