Can a wheel crumple with no broken spokes
Quoted: 2700 Post(s)
Liked 486 Times
Hey guys. Weird question, can a wheel without broken spokes catastrophically fail? I have a bike with a back wheel in pretty bad shape, multiple (8?) spokes keep losing tension (Ive been hand tightening them every ~ 10 miles but it doesn't make much of a difference.) None of them are broken but I have a pretty gnarly speed wobble that changes up on me. The question is, what's the worst case scenario? From what ive read and from what experienced people have told me, is that its pretty much impossible for the wheel to catastrophically fail without broken spokes, and it will become wildly out of true before that happens. Im a heavy guy (255 lbs now) and put a lot of wear on my components, and can't really afford to fix this bike right now. Today on the group ride people were concerned about the wheel and I decided to leave because of it, was kind of embarrassing.
How concerned would you be riding with a shot wheel, assuming you don't really mind the speedwobbles? Any horror stories?
Clark W. Griswold
Quoted: 4355 Post(s)
Liked 3,994 Times
Larry you should enjoy that wheel, I think it could help knock a little sense into you.
For those who thought maybe yeah I am having a similar problem. If your wheel is failing like described above time for a new wheel or a rebuild by a capable wheel builder. If you are frequently doing this on multiple wheels you might either need more spokes or possibly you need some handbuilt wheels again by a capable wheel builder and they can suggest some stuff to build a more reliable wheel. Don't ride with others on a broken bike and make sure you are regularly tuning up your bikes as needed.
Likes For veganbikes:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
Likes For Chuck M:
Quoted: 822 Post(s)
Liked 1,960 Times
Larry, do you mind if I take out a life insurance policy out on you?
I feel lucky.
I feel lucky.
Likes For CAT7RDR:
Liked 486 Times
Quoted: 4227 Post(s)
Liked 2,488 Times
Loose spokes = cracked rim.
Likes For wolfchild:
Quoted: 6963 Post(s)
Liked 10,963 Times
You never disappoint, Larry.
You should at least tighten the nipples with a tool, not with hand. Find someone who can true a wheel for you for free or watch youtube videos on DIY wheel truing. It may also be possible the treads on the nipples are shot and needing replacement. At your weight, you absolutely need to avoid using cheap wheelsets.
Likes For qwaalodge:
Quoted: 18415 Post(s)
Liked 15,546 Times
“People say believe half of what you see, son, and none of what you hear.”—M. Gaye
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
A cracked piece of metal supporting a heavy load breaks when you hit a bump? You want to run the experiment of what happens when the back wheel fails, knock yourself out. Literally.
No one's goingbto tell you that ride to failure is a good plan. Given the likelihood that the failure is going to cause damage to the bike and yourself, any notion this makes economic sense is absurd.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
I had the the same issue with a Bontrager wheel from back in 2006 time period. Pain. Had the shop tension the wheel many times. As said above the rim eventually will crack. Trek replaced it under warranty. Second wheel the same problem. I’ve built a few wheels so figured some spike prep was needed. Did not want to completely rebuilt so used some green wicking Loctite. Helped so I’d only get loose spokes every few months. After 11 years the wheel rim cracked. Oh this was an aluminum rear wheel. So upgraded to Aeoles Pro 5 wheels. May be the deep rim but never touch them. After the Madone frame broke these carbon wheels are on a rail trail, lite touring, bad weather bike.
Permatex makes a wicking thread locker version. Heck nail polish would work and add color. I’d thread lock the offending spokes and keep and eye on the rim. Then budget for new wheel.
Likes For biker128pedal:
Liked 15,546 Times
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 464 Post(s)
Liked 547 Times
I have had a wheel fail with multiple cracked spoke holes... On our tandem. The cracks had gone from being not visible to major in about 20 miles.
We did not crash. We stopped immediately when we felt the wobble. Fortunately this happened at home, and we walked the last mile. We have also had a wheel on the tandem crack from an impact at a single point. There were no loose spokes, but the wheel was cracked and bent. We rode that slowly for 5 miles back to the B&B we had stayed the previous day. That was the end of our riding on that tour.
I know you like to do things your own way. But you are describing multiple loose spokes. Stop riding on that wheel.
We used to say something at my old Fire Department: "somewhere somebody is going to do something stupid and I want a front row seat." Continuing to ride that wheel qualifies.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Bottom line: your wheel is headed towards total collapse and will likely do so when you go around a corner which is where lateral forces on the wheel are at their highest. Ask yourself how much you like picking road rash scabs (at the best).
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 15,546 Times
Quoted: 6193 Post(s)
Liked 4,810 Times
Yes, your wheel can taco on you if the right number of spokes in the right places get loose enough. It'll probably do this when you are at speed on a downhill twisty trail. Hope that it's your rear wheel and not the front.
Having to tighten spokes every ten miles and not thinking it needs some more experienced person looking at the wheel doesn't seem .....
Liked 486 Times
For some people, especially poor fat people who don't drive and destroy components, it can be more economical to constantly keep an eye out for dumpster bikes and ride them to failure, than attempting to maintain a nice bike or two. I have 6 bike shaped objects right now, bit of a hoarder its bad. Found an abandoned trailer at work to keep my bikes in.
Liked 4,810 Times
When I need the wheels of my bike looked at, I take them off the bike and to the LBS's here. They don't charge much to go over them. At least not here, and they'll even fiddle with them on the truing stand for a few seconds checking tensions and stuff while I wait and watch. If the wheel doesn't need much then they many times give them back to me free of charge. If one wheel needs some more in-depth looking at then it might cost me $15 - $20 when I get the other back in a day or two.
$400 a bike to destroy them will get expensive quick. While I don't know how it goes for them, when I ride in organized century rides there are quite a few heavy men and woman that speed past me in a paceline while I'm solo or a group of 3. They seem to be on nice mid range priced bikes in the $2000 range.
So if you are buying cheap used $400 bikes, I think there is a flaw in your thinking. If instead you are getting $0 bikes that you just put tires on, that's probably okay.
It needs to be said.
"Larry, is this your homework?"
"This is what happens when you .... and a stranger in the ..."
Likes For ggpepper:
Quoted: 3952 Post(s)
Liked 7,297 Times
Put this bike back in the dumpster and get another one.
Likes For tomato coupe:
Likes For Mackers:
Quoted: 2333 Post(s)
Liked 2,097 Times
How bout someone send Larry a wheel they have laying around. Think of it as payment for the comedy that he has generously given us all.
Liked 15,546 Times
I have a pair of red CXP33s I am willing to part with. 32h. DA hubs. 2001 vintage. Worn braking surfaces. I’ll even throw in the NDS spokes for free. They would be perfect for him. Fodder for the next thread.
