Is 3 wheel revolutions per 1 pedal considered fast?
hello, i'm a little confused .. need some advice
is 3 wheel revolutions per 1 pedal considered fast enough for a bike with 29"x38mm sleek road tires at a mostly flat road .. can it atchive 30km/h? or it should be at least 4 wheel revolutions per one pedal whole cycle?
Quoted: 4227 Post(s)
Liked 2,488 Times
Just enjoy riding your bike and don't worry about wheel revolutions, pedal stroke and other irrelevant nonsense.
Likes For wolfchild:
Expired Member
Quoted: 3674 Post(s)
Liked 5,431 Times
Normally, three is fine. If you find it takes you too long to get places, it won't hurt to try four.
Likes For shelbyfv:
Quoted: 822 Post(s)
Liked 1,960 Times
OP Have at it and report back with your findings.
https://www.omnicalculator.com/every...vide%20by%202.
Quoted: 1182 Post(s)
Liked 833 Times
You might consider a simple bike" computer" They are not very expensive, and will give you speed, max speed, distance, and riding time.
Check this out and look at some other models on this site: Bike Computer
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I rarely ride a gear bigger than 3:1, but still go over 30km/h all the time. Just spin those legs and you'll go fast enough.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12771 Post(s)
Liked 7,687 Times
I'm kinda old and slow though so you might want to go a little higher if you're young and spry
30 km/h is definitely achievable.
Quoted: 1944 Post(s)
Liked 2,164 Times
You can hit 30kph in a 3 to 1 (i.e. 48:16, 39:13) gear ratio with a pretty easy going cadence around 76rpm.
John
John
thanks you all .. i really appreciate your helpful responses
CAT7RDR thanks for the link
omnicalculator[.]com/sports/bike-cadence-and-speed-calculator .. this what i really needed
My 'light headwind/small hill' gear is about 82 inches. It can be spun to 20 mph, but my legs find it less tiring to upshift from there when maintaining 20+ mph.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2581 Post(s)
Liked 5,639 Times
A good rule of thumb, on flat land, is to count the number of pedal revolutions per minute (one pedal only). If you can maintain 80 pedal revolutions per minute you are doing well. If well below that, go for lower gears until your get that RPM. It may feel strange at first to have your legs spinning quickly but it is all about efficiency and energy conservation. The more you conserve the farther you can go with out tiring rapidly. On a hill climb, if your RPM starts to drop below 80, down shift until you can maintain it. On very steep climbs you will not be able to do this but gear down to your lowest gear and do your best. Welcome to cycling and enjoy the ride.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
