What chain for my ‘20 Giant Defy?
Quoted: 4407 Post(s)
Liked 4,860 Times
I agree with the others who say either your chain wear is excessive or your checking gauge is no good. I would start by getting a good tool like the above and go from there.
As for chains, I would just get an 11s Shimano Ultegra. They score highly on the Zero Friction Cycling website review and that’s what I replaced my stock Defy chain with. Just remember to match the original chain length. I had to remove a few links out of the new chain.
For lube I use Silca SS drip-on wax. As long as you start off with a perfectly clean, fully degreased chain and drivetrain it is super easy to keep it that way by simply wiping down and re-applying every 150-200 km or after any wet ride. No need to keep degreasing every week, which is probably doing more harm than good.
The Park CC-4 is the best of the various Park models as it’s longer and measures from the back of each roller, rather than front to back. Some chains have slightly different roller diameters which throws out the front/back of roller measurement.
Also going to pickup some mineral spirits and denatured alcohol….for chain cleaning, before initial waxing.
Liked 4,860 Times
Yes, that’s the one. You can’t go wrong with those.
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
If you're willing to put in the time and effort on the initial cleaning, wax is much, much lower effort. If you want to go through the trouble of the homebrew mix, go ahead, but it's a lot easier to buy a bag of MSW (and it's not expensive - it should last you a 10,000+ miles).
Quoted: 20810 Post(s)
Liked 9,456 Times
300+.
I haven't ridden in much rain this year, but getting stuck in torrential rains last year wasn't catastrophic or anything. I may have swapped out the chain earlier, but it didn't rust out instantly or anything. I really don't know how it would fare in the regular rains of the PNW or anything, but I wouldn't be concerned short of those conditions (or sloppy winter riding, I guess).
Likes For WhyFi:
Quoted: 6193 Post(s)
Liked 4,809 Times
I tend to believe that those that have actual chain issues like low service life are those that produce huge amounts of torque. And/Or probably either pedal up hill at very low cadences and love to do track stands at stops.
As for being finicky with your chain, if that's what makes your cycling fun, then go for it. But I'd think you'd probably get the same results for your chains no matter what.
If you were to change up your routine, the only thing I might say is why don't you try putting the purple power on your rag and not get the rag too saturated with it as you de-gunk your chain. Don't spray or saturate your chain with purple power or any degreaser. You only want the new lube to push out the old lube.
Better yet, just use some of the lubes that seem to be less oily and create less gunk. You'll need to lube more often but just lube your chain and then wipe off the excess. Easy peasy, chain stays on the bike, takes all of two minutes, I get to ride more or keep my fingers in shape here at BF. <grin>
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1947 Post(s)
Liked 1,469 Times
Smoove-Advanced-Guide.pdf (zerofrictioncycling.com.au)
Instructions like the above preclude me from going down similar rabbit holes.
As for waxing, I don't want to be like the witches in the opening scene of MacBeth in my garage.
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
Maybe degreaser is too harsh. I use a dab of dish washing soap in a chain cleaner with water followed by a rinse with just water then wipe dry and lube. Some degreasers weaken the chain
Likes For Symox:
Liked 9,456 Times
Then you have a misunderstanding of what it entails. Once you get past the initial cleaning, it's very low maintenance and very little hands-on time, like 5 minutes a month. Pop your chain in the (cold) mini-crock, turn it on, come back in an hour (or however long it takes to get up to temp, swish the chain around and then pull it and hang it. Loosen the links after it's cool.
Likes For WhyFi:
Liked 1,469 Times
Liked 9,456 Times
Liked 1,469 Times
Got it, thank you. Each Shimano chain I buy comes with a quick link, so no need to pass it onto the next newer chain.
Liked 4,860 Times
I think it's more related to weather conditions. Looking at the Zero Friction Cycling tests for chain wear, once you start to introduce wet and dirty environments then the wear rates go up exponentially. Out of choice over the last few years I've only ridden outdoors in fair weather (hitting the indoor trainer on wet days) and my chain wear has been pretty negligible without spending a whole lot of time on maintenance. When I used to ride in all manner of conditions I saw a lot more chain wear, especially on my mtbs.
I once dabbled a bit in hot wax lubing. I could never achieve more 100mi. It got to be a real chore and I reverted to on the bike maintenance. I believe most eventually will. Imo, for now liquid wax, Squirt, Smoove, super secret etc. looks the most promising. Pricing is insane tho. Have a hard time believing such expensive lubes could ever pay for them selves. A small bottle is more than a new chain ...
Liked 4,860 Times
It's expensive, but a bottle lasts a very long time. One drop per roller is all you need every 150-200 km. I used Squirt for a few years (not bad, good chain wear, but a little gunky) and recently moved to Silca SS, which is excellent. Drivetrain has never been cleaner with this. Only question mark is wet performance, but I don't ride much in the wet.
Liked 4,860 Times
Quick links are reusable, to an extent, however they do loosen considerably if opened more than a few times. Id get a spare or two if crockpot lubing and extended service life is on the menu. Assuming a 200mi interval and a 5000mi life, its more than 20 openings. Imo they be completely loose long before that.
I would get the KMC re-usable quick links. They actually do 2 versions of their quick link, one re-usable and one not. They look pretty much identical and a lot of sellers don't label them properly, so requires a bit of Googling to get the right ones. I agree the Shimano ones are not good for 20 openings. You can use them a few times, but they should be a tight fit.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
The KMC reusable links loosen too, just like the ordinary ones. I have a few, Identified by an "R", that came with some x10 chains. I say about 5 uses and they get noticeably loose. Im not sure its safe, even if I never had one come apart. I much prefer the link having some reassuring resistance and click sound when assembled.
im curious about wet weather and melted wax lube also. I have a Marin flat bar road bike that I use for riding in bad weather (and winter)…..and don’t want to use melted wax on that chain if water and/or freezing temps will be a problem
Liked 4,860 Times
Liked 4,860 Times
It's a tricky one this. I think for wet weather a more traditional oil based lube is probably more effective, but only if you clean your drivetrain religiously after every wet ride. Otherwise you will soon end up with an oily black grinding paste, which is a disaster for both wear rates and your bike/clothing. The wax based lubes tend to get washed off pretty quickly in the wet, but if your rides are not too long and you re-apply it then it should be reasonably effective. Your drivetrain will remain much cleaner with wax, which is more than half the battle won IMO. Not sure about freezing temps though.
Liked 4,860 Times
Possibly yes. If most of the original wax has been washed away and the chain is dirty you are back to square one. Personally I just use the best of the drip-on waxes (Silca SS) and simply wipe the chain down with a cloth and re-apply another drop or two per link. Takes just a couple of mins. But I should stress that I rarely ride in the wet these days. A full comprehensive chain clean is a rarity for me.
Can I apply Smoove or any other bottled wax to the paraffin wax to “touch up” the chain after a rain? Or just do the redip of the paraffin?
