Shimano UG/HG Freebody replacement won‘t work
Hello vintage friends,
I‘m currently trying to replace a 7-speed Shimano 105 HG/UG freehub body on my Motobecane Jubilee Sport (1982), but the new NOS Freehub simply won‘t fit on the rear hub, although the inner spline pattern looks the same. I can‘t post pictures at the moment, since I’m a new member, but here is some info: both freehubs have the same dimensions and look almost the same. On the bottom side the new FH has some additional rubber rings which are missing on the oder one. BUT, the hub socket looks the same.
Does anybody know what I‘m missing here? Are there some different hub socket standards one should know about?
Cheers,
Wheely
Cheers,
Wheely
Check that your freehub spline isn't missing the single wide spline that HG cassettes have.
https://www.sheldonbrown.com/k7.html
Sorry for misunderstanding, I didn’t mean the splines on the freehub, but the splines (maybe it‘s the wrong word for it, they look to me more like teeth of a cog) in the hub itself, where the freehub is inserted. There are 12 equidistant teeth on the hub
![Smilie](images/smilies/smile.gif)
So at the moment my question is, if there were different, but similar standards for connection of the freehub with the hub
Death fork? Naaaah!!
Post pictures to your gallery. The Mods can then post them here.
Top
Top
mycocyclist
Liked 873 Times
Some Of The UG Hubs Are Not Interchangeable
Most Shimano Freehub bodies are interchangeable. The exceptions are:
- Very early Freehubs (sometimes identifiable by the absence of the typical bulge on the right end of the hub barrel) which have non-interchangeable bodies. The Freehub body of these hubs is held on only by the axle bearings, and will slip off once the axle is removed.
- Hubs that use the "silent clutch" mechanism.
- Pre-1997 Dura-Ace Freehubs, which only take pre-1997 Dura-Ace bodies.
- FH-7800 and FH-7801 Dura-Ace bodies, which have a cartridge bearing inside the Freehub body and use a ratchet inside the hub shell. These bodies are removable using a 5 mm Allen wrench at each side. The fixing nut on the right side unscrews clockwise. Shimano information on the 7800; 7801.
- FH-7850 and FH-7900 Dura-Ace bodies, which have returned to a splined attachment between Freehub body and hub shell, but it is larger than the usual one. It is similar but not interchangeable between these two models. Shimano information on the 7850; 7900...."https://www.sheldonbrown.com/k7.html
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/80-img_3778_52efd2cc340e34093a7f1ef07a4873fb1d38cedc.jpeg)
![](https://cimg5.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/80-img_3777_7527b2bfcc06d88c0aabd306595b5379589c00ee.jpeg)
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/80-img_3775_a7a0c44dcdd68a89b9a59f1b4502ec516ddfb164.jpeg)
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/1500x2000/80-img_3773_c89e9dd3813219b9239436e8e84abbb1b9c5dc6c.jpeg)
OP's Album.
Likes For machinist42:
pic assist
Does the freehub spin freely before you put it on? Also- some of these freehubs need a spacer shim. Otherwise it will tighten against the hub and it can't spin. Where did you get this freehub from? Did it have a spacer shim?
Also- what is wrong with the old freehub?
Did the old one have a thin spacer between it and the hub shell? This may be needed with the new one. But you might just have one that’s not exactly compatible with that hub. It can be hard to determine cross compatibility with these. I recently did an 8 speed swap for a RSX hub, used a freehub made for Tiagra 4500.
![](https://cimg3.ibsrv.net/gimg/bikeforums.net-vbulletin/600x600/img_8530_62844add2485259962c062962f51e6886cb28409.jpeg)
Bikes: Fuji Touring, Soma Double Cross, Nashbar Alum Mountain Frame/Surly Troll fork , 1977 Kobe Chapparal
Cheers,
Wheely
Cheers,
Wheely
It looks like the hub is one of the really old ones, early 80s. Possibly one of the ones that used that just used the cone & bearings to hold the freehub body onto the hub shell.
Your 'old' freehub body seems to already be a replacement. It is HG style, so probably not original. Your 'old' freehub body may have a washer on it, (based on the pic).
If the washer is there, transfer it before fitting the 'new' body.
Not sure what all that black 'stuff' is on the hub shell. Is it just cake on grease? Or is there a plastic or rubber spacer on there? It and the lack of the washer may be restricting the freehub body from spinning.
Clean off what you can and post a pic, so we can see what's there.
Likes For KCT1986:
Ride, Wrench, Swap, Race
Liked 1,334 Times
Those freehub bodies aren't made for that hub at all, they are supposed to be secured using a hollow bolt that the axle passes through.
I don't know why one even fits on there, possibly it was modified!
I would find a complete 7s freehub (or complete wheel) for this repair.
Even among HG freehubs, many do not interchange parts-wise with others, the cassette won't be at the right distance from the spokes and the cone, spacers, seals and such also won't fit properly.
When I have swapped freehub bodies, it's either the identical part or a similar one complete with all of the axle hardware to go with it. I have had difficulty swapping random freehub bodies for the above reasons, even though the splines were identical. Adding/subtracting the washer never fixed a problem with a mis-fitting freehub body.
Your particular style of (internal/external threaded) 7s freehub body is special in that a 10s cassette can be mounted on it with the right (11t-size, long-threaded) lock ring nesting into the recess of a 12t smallest cog.
Insane Bicycle Mechanic
Sorry to be a downer but… it’s toast.
Jeff Wills
Jeff Wills
Likes For Jeff Wills:
Thrifty Bill
Liked 1,004 Times
I always find replacement freehubs in the form of a wheel. Pick up a used wheel at a co-op, or even pick up a complete bike. Depending on condition, you might swap entire wheel(s) which avoids any compatibility issues.
Whenever I scrap a a set of wheels, I save cassettes, freewheels, free hubs and entire hubs. Just scrapped a set this morning.
pic assist
The new freehub body spins all right (with my finger as an axis). I bought it online as a NOS Shimano 105 part.
The old freehub was assembled by a friend of mine, who says there wasn’t a spacer shim between the freehub body and the freehub. Neither was there spacer delivered with the new one.
Liked 458 Times
I'm curious to see a picture of your hub. It is hard to tell from your description if the freehub body is held on with a bolt or if it is one of the older ones where the bolt is imbedded in the FH body itself. I like 7 speed Uniglide stuff, it is very well made and generally durable and re-buildable but as others have said, it is important to stick with the exact model for replacement. I put a UG/HG freehub onto a 7 speed uniglide only hub and it did fit but there was some slight incompatibility with the rubber seals making riding it in the rain not quite as water tight as it should have been.
Likes For masi61:
SI-M-98-000-00-ENG.pdf (shimano.com)
The original freehub body was 'press-fit' onto the hub shell.
As mentioned previously, the freehub body that you removed was not original. It was a HG style with one narrow spline out the outside for cassette alignment, a HG feature.
The body that you removed may not have been designed for a press-fit and just slid on the shell. Did you have to use the tool to pull it off? See how the original body was removed per the linked doc. If the tool was not needed, then the balls/cone was the only thing holding the freehub body against the hub shell.
If the body that you are now trying to install is going part way onto the shell and meeting resistance, it may need to be pressed on per the instructions. Per the instructions, this is done by using the 2 washer included with the removal tool. The washers go between the cone on the axle and the bearing cup without the ball bearings installed. The cones are tightened to push the freehub body onto the hub shell. The force used was not very high, see the torque spec, (relatively low). The cones/axle is then removed and ball bearings installed.
Of course, this was with the original freehub body designed for the hub. With the freehub body that you have, this may not work.
Likes For KCT1986:
Likes For WheelyTheGreat:
If your original post is correct, the link is for the spec sheet. This seems to be the only 105 that used that freehub attachment style.
And big Thanks for the link!
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_4034_4badc3c4e2b7f07f377ccaaa593b4dee0fac8814.jpeg)
