Pitting, rust, nicks on frame
Old 08-14-10, 10:30 AM
whiteflight
I bought a 1968 Phillips 3-speed a few weeks ago and I'm trying to "restore" it the best I can. The frame has some nicks and some pitting and rust. So, is there anyway to fix up the frame without having to sand it down and repaint it? When I bought this bike, I thought that I would be able to get it looking semi-new again. The bike is worth very little, so putting a decent amount of money into it wouldn't be the best idea. I realize I won't be able to make a masterful restoration, but I'm still going to try to fix it up in a cost efficient way...
Also, have pics if needed. Appreciate any help!
whiteflight is offline
Old 08-14-10, 10:47 AM
damnpoor
damnpoor's Avatar
The only 100% effective way to eliminate corrosion is to grind it out. If you just want it to look pretty check out a hobby shop for matching model paints or a cosmetics counter for matching fingernail polish. Before you put on the touchup paint hit it lightly with a wire brush.
damnpoor is offline
Old 08-14-10, 10:51 AM
whiteflight
Thanks damnpoor. As I said the bike isn't worth much already, but wouldn't either grinding it out or touching it up diminish value?
Old 08-14-10, 12:55 PM
wrk101
Thrifty Bill
wrk101's Avatar
Quoted: 1247 Post(s)
Liked 1,004 Times in 645 Posts
Read the various rust threads on Oxalic Acid, then decide. Anything abrasive will remove everything: rust, paint, and good metal. Treating it chemically is the only way to remove just the rust.
wrk101 is offline
Chucknbob
Bicycle Mechanics
15
02-26-15 07:50 PM
wernst
Framebuilders
19
09-11-13 02:33 PM
dougmc
Bicycle Mechanics
4
10-26-10 04:03 PM
cg1985
Classic & Vintage
8
07-31-10 05:42 PM
cg1985
Classic & Vintage
6
07-30-10 05:55 AM
