NB to Biking
NB to Biking
I found below ad in Craigslist for $290, do not have enough knowledge, wanted to check with experts here if it is worth of over priced. Thank you for your help.
Trek 420 Fast track in gift condition.
3 X 7 Indexed Shimano drive
Pristine 58cm CroMo frame.
Best for riders 5'7" to 6'0".
One owner bike. Completely reassembled and meticulously serviced.
No short-cuts, hidden issues, "just needs" or other bowl shirt.
All components are in excellent working order.
No rust or rust removed. No chips or scratches.
No signs of "normal wear and tear".
Quoted: 3238 Post(s)
Liked 2,085 Times
Quoted: 1944 Post(s)
Liked 2,164 Times
If it is pristine, it is probably not a bad deal. What else can you buy for less than $300 that has been completely maintained? If that is true, of course.
As for a 58cm fitting 5’7 to 6’0, not a chance for someone 5’7”. More like a minimum of 5’10”.
John
John
Likes For 70sSanO:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
As said above, a 58 cm frame is suitable for ~5'10" to 6'1" or so, depending on stem reach. You didn't include how tall you are, and your relative body proportions (i.e., long torso versus long legs vs balanced proportions). "Will it fit?" is the very first question to be asked. Always.
Likes For Phil_gretz:
Quoted: 822 Post(s)
Liked 1,960 Times
Here is something to consider:
https://www.bikepedia.com/QuickBike/...spx?item=69226
Said bike was only $425 new in 1997.
Tourney components are the lowest in the Shimano lineup.
Keep looking.
Keep looking.
Quoted: 4406 Post(s)
Liked 4,857 Times
Keep looking.
Keep looking.
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
With the limited availability of bikes these days, if it needs no repairs, just a few adjustments... grab it. Offer $250 but if they insist on $290, pay it.
Likes For GlennR:
Quoted: 6193 Post(s)
Liked 4,809 Times
The big question is does it fit you?
Then, is it the kind of bike you really need for the type cycling you will be doing. I just see too many people that really just want a easy leisurely riding bike and they get road bikes then put all sorts of seat posts with large set back, ridiculously extended or raised stems on them and then still wonder why they are so uncomfortable or can't do the things they want to do on the bike they chose.
The bike is old. If you are a experienced bike DIY'er you might can do a lot with it. But when you need to get it worked on or new components, there might be troubles brewing if you have to pay for a mechanic.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Welcome! You're getting some good advice. Most important is fit, but if the bike fits and rides well and you like it, buy it. If you don't know bikes it would be advisable to have a buddy with knowledge accompany you to confirm or correct your impressions. Good luck!
I think, if you like the look and feel of the bike, go for it. In my experience, if the components work well it doesnt make such a big difference if they are tourney or top of the line to most riders.
Quoted: 7652 Post(s)
Liked 3,473 Times
If the bike is mid-to-late '90s, it will probably have 130-mm rear dropout spacing---which means you can put just about any modern wheels and gears on it. From what I see online the bike has 700c wheels---which, again, means that it will be easy to find wheels for it.
If the rear dropout spacing is 130 mm, you could rebuild the bike as a 2x11 or anything else. Often 7-speed wheels have freewheels, not freehubs, which aren't as strong, but should work fine for non-competitive or non-abusive riding. Still, it is nice to know that if you like the frame you could swap in any modern drive train---pull a bike with a decent drive train and a broken frame out of the bike shop dumpster and swap out the gear and go, or pick up old used bikes or whatever .... if it has the old 126-mm spacing, you are stuck using old tech.
This. If you don't know bikes, bring a friend who does. If everything is as advertised and works as intended, it might be a decent ride.
It really depends on three things:
A.) Does it fit? if it doesn't, it could be solid gold with diamonds, it is still useless to you (if it is solid gold for $290, buy it and melt it down for resale.)
B.) Does everything really work perfectly and look brand new? Can you easily shift through all the gears and ride silently (no clicks or clunks) in every gear? Do the brakes stop you swiftly? If there is no wear, no paint chips, no rubbed areas under the cables, then this might be one of those garage queens .... ignored in the corner for years. Great luck for you, if so.
C.) Does it work for the way you want to ride? This is an old steel touring frame, so it probably isn't lightweight ... but that doesn't matter to everyone. I have an old steel Raleigh which isn't at all light but is a great ride.
Does the riding position suit you? You can adjust it, but only so much. Do you want to go really fast? Do you want to put a rack on the back and use it for errands? I'd say the bike could probably work for anything except competition, but likely the frame is designed for pretty narrow tires, so you probably couldn't convert it to a gravel bike, for instance. On another hand, it might fit 32s if it is a late-nineties touring frame.
