Bottom Bracket query
I changed my bottom bracket to a brand new Shimano BB-5500 some 3 weeks ago and all was good after 300 miles in 2 weeks, yesterday there was a squeaking sound on the non-drive side (left) only on the down stroke when pedalling..squeak..squeak...it goes.
I know its not coming from the BB interface with the crankarm and suspect might be over or lack of torque when I tightened the BB end cup. Question - should I try to tighten or loosen the end cup to eliminate the squeak? Do BB cups loosen or tighten after some usage when new?
Lastly, could it be the bearings? It looks sealed type. It is a brand new BB w/ only 300 miles on it.
Any help would be appreciated. Thanks.
Faster than yesterday
Well, you've narrowed it down. If you're absolutely certain it's not the crank interface, probably a loose cup. I'd make sure the crank isn't loose first.
They can, especially if they're not torqued to spec to begin with. Happened to me.
Bikes: 1983 Gureciotti/full SR 2002 Casati Record 10 speed 1995 Colnago C40 2007 Sram Rival 2006 Isaac Sram Force 2000 DEAN Ti DA 10 speed 1987 Schwinn Prologue Funny Bike 2001 Pinarello DA 9 speed 2008 Element6 Record 10speed Origin8 Lutegra10speed
Your frame probably has a English threaded BB shell. If this is the case then both cups are tightened by turning counter clockwise and the cups on both sides loosen by turning clockwise. When you are pedaling down the road -- you are turning your cranks in a clockwise rotation. If your BB cups are not properly torqued then they will loosen up. When they get loose you normally hear a creaking noise on the down stroke on the BB cup that is loose. The more loose the cup -- the more noise even without hard efforts. All the BB cups need to be checked on a annual basis to insure good performance.`The noise could also be from lack of grease on the spindle/NDS arm contact area or loose screws on the NDS arm. Check and make sure you have grease on the pedal threads. Metal on metal without lube can also make a noise like a loose BB cup.
Senior member
Quoted: 943 Post(s)
Liked 659 Times
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
FWIW: I switched the BB on my Ultegra triple crank last summer. It was quiet for a week, squeaked for a week, then it's been quiet ever since. Weird.
Jeff Wills
Jeff Wills
Thank you for all response and I may have to remove the BB again and regrease as first move. Tighten. Then regrease the spindle/crank interface. Finally, grease pedal grooves. It's quite easy since the cranks have self-extractor bolts. FC-6500 Ultegra.
And to tighten cups for BOTH sides, my wrench handle should go in the direction of the rear wheel right?
I do stand corrected about the threads. I should have said that that both cup tighten in the same direction (attach your BB tool and torque wrench --point it towards the rear and press down). To loosen the cups -- both cups come off in the same direction ( attach proper BB tool and a wrench/cheaterbar or whatever and point it towards the front and press down). Since the threads are opposite threaded and are on opposite sides -- each cup goes on in the same direction and both sides come off in the same direction. But the part about your spinning the crank will eventually loosen your BB still stands. The drive side cup loosens to the right and the non-drive side loosens to the left which means both sides loosen in the direction that the crank is rotating.
just pokin' along
Quoted: 11 Post(s)
Senior member
Quoted: 943 Post(s)
Liked 659 Times
It is the reason for using left threads on the drive side in the first place.
Italian and French BBs which use right threads on both sides are prone to loosening cups on the drive side.
Thank you guy's for the technical schooling.
This is intuitive but incorrect. Thanks to a phenomenon called precession, wherein rotational forces are reversed due to the bearings within the assembly, loosening is prevented.
Also, if you haven't eliminate it already, I've found that cleats can occasionally squeak.
Quoted: 809 Post(s)
Liked 712 Times
Jeff Wills
Jeff Wills
"What are you using to tighten the cranks? Those 8mm "self extractor bolts" are tough to tighten properly. Park Tool says 305-391 inch-pounds, or about 25 to 30 foot-pounds, which is a hefty heave on the average 8mm hex wrench."
That much? I am only using a hex wrench with a 6" arm and tighten as best I could. Now I am sure I am not getting enough torque on it, will put a longer extension on the arm to give me more mechanicaladvantage. Will let you know of the culprit as soon as I have isolated it.
