Motobecane 'Le Champion' 1972 one owner
Quoted: 5 Post(s)
This is a one owner 1972 Motobecane 'Le champion', modified to 12 spd, in Grand Jubilee colors, in 1973 they won the Tour de France and doubled the price, and went to a solid color on the bike model and all Campy, it is constructed of premium Reynolds 531 double butted steel frame tubes and fork blades, with Campagnolo dropouts front & rear, the frame is a 54 cm IIRC, I have a 32-inch inside seam for pants and stand 6', It has Suntour Cyclone rear derailleurs, and Shimano front derailleur, Shimano fingertip shifters navigate through the 12 total gears, Stronglite 93 double crank, geared 45, 49, there are spare gears for the crank, and rear hub, the pedals are Shimano 600 platforms, the stem and drop bars are Cinelli, I replace the original TTT stem and bars about 20 years ago, when the originals went bad, and I couldn't find a direct replacement for the TTT, Brooks Pro seat, Campy quick release on frame for seat, provide a comfortable perch for all day riding, brakes are all Weinman, levers, hoods and side pulls 50C IIRC with Campy springs with Mafac front pads and rear pads synthetic, rolling stock consists of one pair of early Wheel Smith wheels ( when they were tuning rims with an Oscilloscope with serial number labels, and Specialized hubs and Super Champion rims, second set are Sunshine GyroMaster hubs is Suntour Perfect 6 spd, 15, 17, 19, 22, 25, 29, laced to Mavic(?) rims, hub is Suntour Perfect 6 spd, 14, 17, 20, 23, 27, 31, both are cross 3 with 700C tires, A fantastic machine to get you all around town or into the hills. I rode this bike for over 30 years, so it does have a patina, there was one nasty accident that where the front brake met the frame too hard when I ran out of asphalt coming down an incline, pictured on frame, Call or text see contact info if you want to check it out.
There are also some spare parts, including Camagnolo pump head for a Silca Impero pumpparts included non op), also that will be coming with the bike, that include another set of Shimano fingertip shifters missing the barrels that go in the handle bar, there are spare crank gears, 40, 47, 52, 54, rear gear hub set 'Cyclo Competition' made in France, 14, 15, 16, 20, 22, there is a single 14 gear for what looks like the rear axle also, Shimano fingertip shifters missing barrels, Campy quick release for front wheel hub, quick release for seat post, platform pedals, another set of platform pedals that look like the Shimano's on the bike Campy Nuovo Record front and rear derailleurs, Campy frame bracket for air pump, Campy frame guides 2 each for shifter cables, and cable guide for single cable, spare stronglite left crank arm 9/16-20 x 165 mm, cables and other misc parts. I tricked out this bike when ever I had a chance when I had the money and found something interesting.
I loved riding this bicycle, there were even a few years when it was my only transportation, been hard to part with it and would like it to be restored.
Please ask any questions, request better photos
Larry Griffin
These are poor, I'll be replacing or adding.
This photo shows where the brake removed the paint
Weinmann front brake
Larry Griffin
Wrong forum. But that's the least of your worries.....
My bikes: '81 Trek 957, '83 Trek 720, '85 Trek 500, '85 Trek 770,'81 Merckx, '85 Centurion Cinelli, '85 Raleigh Portage, '92 RB-2, '09 Bianchi
Likes For nesteel:
Quoted: 5 Post(s)
This column was suggested to me, but I did forget to edit the price out, it is also in the for sale column. Now to take some decent pictures
Thanks, Larry
Thanks, Larry
Likes For trailangel:
Quoted: 790 Post(s)
Liked 1,767 Times
Hard truth no one cares. Basic model nice Sschknn so start $200 .
Quoted: 5 Post(s)
trailangel
"Those were nice frames, but the way it's put together and the hard life it's had......not good..."
The frame is double butted steel, and there is nothing wrong with the frame that it couldn't be ridden with some TLC, I stand a little over 6' and weigh 200#, the frame has been tested daily for months at a time, unfortunately my frame is not in as good shape.
zukahn1
"Hard truth no one cares. Basic model nice Sschknn so start $200."
The frame is not your basic model it is Motobecane's top of the line "Le Champion', at the time, there is still enough of label on the down tube declaring 531 frame material, if you are familiar with the sticker, I researched bicycles before I bought this one, and the framed matched the specification of other top of line bikes, but cost about half as much, since it didn't have all the Campy equipment the others had, that didn't happen till after they won the Tour de France the following year. The I don't cares were the kiddies that put their bikes in the rack next to it, it wasn't always possible to put it inside the business I was visiting.
zukahn1
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
Clearly this bike has a lot of sentimental value for you. It's been a good friend for many years.
Would suggest that you take some time to clean it up nicely, remove the seat cover, replace the bar tape and cables/housing so that it looks more like the friend that it is.
Soap and water with a rag and some air in the tires will work wonders on prospective buyers.
Good luck with finding your friend a new home!
Likes For rccardr:
Bikes: Canyon Endurace
Quoted: 1041 Post(s)
Liked 923 Times
I can only assume that the spare parts you have are in the same condition as the bike. I realize it's a "531" bike but even then... I would be hard pressed to give you more than $125 for everything. Way too many consumables need to be replaces on that bike and the effort to clean it up just wouldn't be worth it.
Quoted: 1143 Post(s)
Liked 1,740 Times
The bike itself as-is, $60-80 tops. The rest of the stuff $50 perhaps, if you can find a buyer.
The presentation is horrible, replaced parts. I don't know how bars and stem go bad, you mentioned damage and crash? Alignment probably needed. Tricked out don't mean a thing if it's chunked old and worn out, just like one owner means nothing to value in that condition.
It looks like a trailer park reject, and that's with a good trailer in back ground. Your pictures are fine, better pictures won't increase value of the Champion.
Likes For Mr. 66:
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
What happened to the Universal centerpulls?
Campy DRs
Suspect a crash on front end.
Strange headset.
bad sidepulls
Shimano pedals into a French crank!
Replaced QR rear axle with solid?
What hubs?
Campy DRs
Strange headset.
bad sidepulls
What hubs?
Quoted: 5 Post(s)
Thanks for an appropriate answer, yes the bike needs some TLC, but that is like rubbing salt in an open wound, especially when I may not ride it again. I've downsized, and getting the motorhome ready to travel after sitting for 11 years. I'm looking to move to the Portland area, and in the country. I may just end up selling parts for now, if a bike is still viable when I get settled there, clean it up. I'm getting a better idea of what vintage bike market, but will have to watch 1980s and beyond to learn more.
Quoted: 5 Post(s)
No, actually the Campy Nuovo Record derailleurs I took off my bike shortly I got it. I will post picture as soon as I get familiar with my digital camera again.
Quoted: 5 Post(s)
The Universal brakes went on another bike, the campy DRs, The headset bearings are the original stronglite or Cinelli(?) when I replaced the handle bars, the 1970 were still American threads, even the spare crank arm is marked that from factory, I had problems with busting rear quick release axles, so put solid replacement, and it didn't break, "bad sidepulls", really, how many cable connections does a centerpulls have.
Friendship is Magic
Bikes: old ones
Quoted: 26419 Post(s)
Liked 10,380 Times
...I do some restorations, and even have one Le Champion (from a different year) that I restored as a project.
But the problem with yours, as a project, is that so many of the original parts are gone away now.
The one I picked as a project had some significant paint issues, and some rust. But all the original components were still present.
ON something like a Motobecane, digging up all those components and buying them at internet prices is just a deal breaker.
But yes, they are very nice riding frames. Might be a project for someone who just wants to renovate it as a rider, using good, but not original components.
Likes For 3alarmer:
Quoted: 5 Post(s)
Nice bike, are those lugs the same as mine?
I knew original parts were a positive on old cars, but didn't think it would be the same for bicycle, I've been told you can part your old car out for parts and get more money.
Is there a difference in price between say Campy Nuovo Record and Tipo derailleurs, or the like.
Thanks, Larry
Thanks, Larry
Friendship is Magic
Bikes: old ones
Liked 10,380 Times
Thanks, Larry
Thanks, Larry
I don't know about the lugs they used, but the ones on mine have nice long points, and obviously got thinned with some hand filing, as you'd expect on a better frame.
You might have better luck selling just the frame, stripped of what's on there now, for a reasonable price to someone who wants to build it up using a donor bike for the components. Certainly bare frames are easier to ship.
Quoted: 702 Post(s)
Liked 672 Times
Fuji Fan
I doubt you will get close to $600 for this. The frameset is not in great condition. There appears to be rust on the chainstays. These are nice bikes and a good condition one with original paint is worth the price. I personally think the blue is a bit more desirable, though I own both varieties.
I'd expect probably offer $150 based on the photos. Rough shape means that the stem and handlebars could be stuck. The bottom bracket and hubs likely need servicing, cables and brake pads likely need replacing. All this costs money to the buyer. I know you see them sold for the amount you are asking, but those are often ones that don't need the kind of work that this one does.
GLWS.
GLWS.
Likes For beech333:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,484 Times
That may be, but that is a huge turnoff to a buyer to see a solid rear axle on a bike like this. Just like the rack, seat cover, etc. Too "franken" for many vintage enthusiasts that might otherwise get past the bad paint.
Quoted: 5 Post(s)
Yes Sir, I started out with a Gitane typical 10 spd of the day, even after mods it still felt clunky, I was riding to work delivering Pepsi, I bought a Raleigh Competition, and that was what the front forks were made, sold that and bought the La Champion, and fell in love with it, established a good cadence and sorted out the gearing and could pass in a residential area.
Quoted: 3464 Post(s)
Liked 2,829 Times
I do laugh when I read "one owner", its like the old used car descriptions.
One owner can be equal to "one abuser"
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
The good news is you have obviously got a lot of use out of this bike. Bravo! Most bikes get very little use, but tend to be neglected and worn from storage condition, not so much use.
But dirt and grime does not equal patina. I myself love patina. A collector is going to want the bike with its original parts, collectors know that acquiring the original missing parts will typically be cost prohibitive. So at that point, its not really a collectable bike, but is suitable for a "resto-mod."
$600? Not a chance.
I tend to find several higher end vintage bikes in this condition every year. 99% of the buyers out there want clean, ready to ride bikes. I'm in the remaining 1%, but I expect to get a deal.
On this subforum, you really don't get appraisals. Instead, you get opinions. Now many people that comment here have bought and sold hundreds of bikes, so there is knowledge for sure. To get a "real" appraisal costs quite a bit of money, and you have to find an appraiser that knows vintage bikes. I do not know of any qualified vintage bike appraisers.
"One owner" is really meaningless when bike is missing all of its original parts and overall in fair condition. If it were bone stock in outstanding condition, then one owner would make a difference. I had a "one owner" bike, my 1975 Peugeot from college. But after college, it was poorly stored, neglected, abused. So it did not benefit from having one owner.
$600? Not a chance.
