I'm riding on 50 year old tires !
Old 07-23-22, 01:24 PM
1964Supersport
Bikes: 1964 Schwinn Supersport
Quoted: 48 Post(s)
Liked 79 Times in 25 Posts
As I restore my 1964 Supersport I continue to learn things. A while back I decided to start riding again as a Health benefit since I'm 67 years old. My bike has been in storage for quite a few years. Last time I took it in a bikeshop was 1983 when I moved to Florida. They replaced the tires and handlebar wrap. About a month ago I had to replace a rear tube so the tire would hold air. Now that I've tested my back and found it will tolerate riding I'm fixing my bike up. While reading about tires I learned about the 4 digit manufacturing code. To my surprise the bike shop installed tires that were 10 years old. The date was June 1973, they installed the tires the summer of 1983. I will be getting new tires this week.
1964Supersport is offline
Old 07-23-22, 02:47 PM
KerryIrons
Quoted: 506 Post(s)
Liked 639 Times in 357 Posts
It's called NOS (new old stock). The only tires they had that fit had probably been on the shelf for a long time. And I'm pretty sure that your bike has to take Schwinn tires made to fit an S-6 rim, which was incompatible with other tires on the market in the mid-60s.
KerryIrons is offline
Old 07-23-22, 05:38 PM
tkamd73
Quoted: 604 Post(s)
Liked 1,064 Times in 535 Posts
The 1964 Schwinn Superport had 27in rims that took a standard 27 x 1 1/4” tire, the S6 was a designation for their 26” rims used on the Collegiate, and numerous other models.
Tim
tkamd73 is offline
Likes For tkamd73:
Old 07-23-22, 07:25 PM
1964Supersport
Quoted: 48 Post(s)
My brain wasn't working earlier, my tires are 49 years old not 50. The local bikeshop told me about a month ago I need 27 1/4 gumwall tires. They have them and quoted me $80.00 for 2 new tires installed. I could probably do it but I think I will let them and be done with it.
Old 07-23-22, 07:28 PM
1964Supersport
Quoted: 48 Post(s)
Tim
You are correct. The local bikeshop quoted me $80.00 for two new tires installed.
Old 07-24-22, 01:02 PM
sovende
Bikes: TNTL (Too numerous to list)
Quoted: 184 Post(s)
Liked 147 Times in 115 Posts
Seems a bit “spendy” to me but the times, they are a changin’! The local Walmart would have suitable tires for ~$40/pair. Mounting tires isn’t a difficult task.
It wasn’t mentioned if new tubes were also included. If so and there are “time, tools & talent” issues, having the LBS do the job makes some sense.
sovende is offline
Likes For sovende:
Old 07-24-22, 01:49 PM
phtomita
Bikes: '87 Centurion Ironman, '86 Nishiki Tri-A, '84 Centurion PT15
Quoted: 244 Post(s)
Liked 180 Times in 112 Posts
It would be a good practice to replace tires yourself, so you will be better prepared when flat happens....
phtomita is offline
Likes For phtomita:
Old 07-24-22, 02:42 PM
bikemig
bikemig's Avatar
Quoted: 5888 Post(s)
Liked 3,471 Times in 2,079 Posts
So a '64 Schwinn SuperSport is a very cool bike to ride particularly since you are the original owner. Looks like it came with alloy wheels which is no surprise since this was a higher end bike BITD:
"First year for this model. It replaced the Superior from 1963. 10 speed, down tube shifters. 38 to 96 gear range. Sprint (39/50) chain set (I saw s/n M3064(12/63) with the old Huret chain set on it). 14"-1"6-20-24-28 freewheel. Sprint derailleurs. 4130 chrome-moly fillet-brazed main frame with 1020 carbon steel rear stays. Huret forged rear dropouts. Full chrome fork, but the stays were not chrome tipped like the Superior it replaced. Round "S" head badge. Brooks B15 saddle. There is no seat tube "panel" decal unlike the other models. Handlebar is alloy and has a sleeve in the center section that says "Sport" on either side of the clamp area. The stem is steel, made by Titan, and says "Super" on the top. Weinmann (K2?) alloy rims. Weinmann center pull brakes with "red button" quick release levers. 27 x 1Ľ tires. colors were Terra Cotta, Sky Blue, Radiant Coppertone and Violet. Frame sizes were 22" and 24". $96.50"
https://www.schwinnbikeforum.com/SLD..._6064.htm#1964
If these are the original wheels, the rims are likely hookless. That means that you want wired clincher tires (not folding) and you won't want to pump it up much over say 75 PSI or so which is plenty.
Get some good tires. Panaracer Pasela 27 x 1 and 1/4 is likely your best bet plus the tire comes with brown side walls which will look right.
You know that your bike needs an overhaul, right? Grease doesn't get better with age. Plus you'll likely need new cables and new brake shoes (or at least take a file on the old ones to get a better surface for braking). Kool stop continentals are fine brake shoes and that's what I'd get.
bikemig is offline
Old 07-24-22, 03:05 PM
terrymorse
climber has-been
terrymorse's Avatar
Quoted: 3432 Post(s)
Liked 3,567 Times in 1,793 Posts
Photo of the Schwinn Super Sport from the 1964 catalog:
I worked in my parents' bike shop at the time, and I hated the hookless rims of those Schwinn bikes. They were a hassle to seat properly, and my ears were assaulted by the the occasional BANG when inflating.
Ride, Rest, Repeat. ROUVY: terrymorse
terrymorse is offline
Old 07-24-22, 03:09 PM
bikemig
bikemig's Avatar
Oh yeah, that's why the OP needs to get wired on clinchers and not run the pressure much above 70-75 PSI. I have a '73 Schwinn Sports Tourer. It's heavy for a "lightweight" with that built in kickstand and straight gauge chrome moly but that bike is built like a tank and rides nice.
bikemig is offline
Old 07-25-22, 07:23 AM
1964Supersport
Quoted: 48 Post(s)
They're probably not very good tires.
You can buy two new gumwall Panaracer Paselas on eBay for $51 shipped.
https://www.ebay.com/itm/33405123121...cAAOSw8gVX3g0D
Add a couple Pedros or Park tire levers, and do it yourself as you will need to whenever you get a flat on the road.
Here are my 49 year old HP Sport Schwinn tires. I think I probably will order and install the tires myself.I really hate paying labor , I would rather spend that money on product.
Likes For 1964Supersport:
Old 07-25-22, 11:06 AM
CheGiantForLife
Quoted: 526 Post(s)
Liked 73 Times in 41 Posts
How would this skill help unless he carried a spare tire in his backpack
CheGiantForLife is offline
Old 07-25-22, 11:29 AM
rydabent
Quoted: 3352 Post(s)
Liked 1,056 Times in 635 Posts
Has the older set noticed that bike tires cost the same or more than car tires did in 1960???
rydabent is offline
Likes For rydabent:
Old 07-25-22, 01:15 PM
SkinGriz
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times in 582 Posts
If they’ve been out of the sun and away from electric motors while in storage, I’d just ride them.
SkinGriz is offline
Old 07-27-22, 04:05 AM
Ironfish653
Dirty Heathen
Ironfish653's Avatar
Quoted: 889 Post(s)
Liked 906 Times in 534 Posts
When you’re just trying to get the bike rideable, yes, ride the old rubber; but with the caveat that don’t ride any farther than you’re willing to walk home, or any faster than you’re willing to crash.
Ironfish653 is offline
Old 07-27-22, 04:35 AM
Kabuki12
Quoted: 878 Post(s)
Liked 2,296 Times in 1,283 Posts
I would not ride tires that old . Blow outs happen and never when you expect it. Tires age better when not in the sun, but they still age and the rubber continues to break down . I agree that you should get used to putting tires on yourself and get used to doing most of the minor maintenance so you will feel more confident when you are out and about. It also helps you understand the bike better so you can spot possible issues that may come up.
Kabuki12 is offline
Old 07-27-22, 06:47 AM
GeezyRider
GeezyRider's Avatar
Bikes: There is always room for one more.
Quoted: 185 Post(s)
Liked 391 Times in 226 Posts
I'm interested to know the process you use to remove and repair/replace a tube and also inspect the inside of a tire that has flatted. Some kind of "removeless tire repair" similar to paintless dent repair?
Don
GeezyRider is offline
Old 07-27-22, 09:26 AM
1964Supersport
Quoted: 48 Post(s)
They are coming up for $68.30 instead of $51.00
