Anybody Ever Successfully Put a Tube Patch On Another Patch?
Quoted: 38 Post(s)
Liked 9 Times
Funny how I was thinking that this might be theoretically possible to glue one patch on top of another while looking at this tube itself but, when I look at the photos, the answer I'm seeing is "No. Not for this one."
Anybody ever had this bad luck?
This leaking bulge kind of resembled a nipple when I first saw it. It looks more like a nose in these photos.
I have been successful when the leak was on the side of patch. I don't think I've ever had a puncture in the middle of a patch.
You aren't losing much by trying so I would give it a shot. Be sure you test it before taking it out on a long ride.
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
You can totally patch on a patch. There is no reason you couldn't provided the first was installed appropriately with "dried" vulcanizing fluid over a roughed up & clean surface.
You might want to revisit your spoke works in this particular case though.
Car dependency is a tax.
Give it a shot and see what happens. Worst case you have to replace the tube. Big deal. Report when done.
Likes For frdfandc:
Bikes: 1990 Schwinn Curcit is my main bike
Quoted: 42 Post(s)
Liked 48 Times
The trick is to use a bigger patch than the original patch, so you totally cover the original patch.
Quoted: 3957 Post(s)
Liked 7,310 Times
I think there's a baby derailleur hanger incubating under the patch.
Quoted: 2604 Post(s)
Liked 1,933 Times
Quoted: 38 Post(s)
Liked 9 Times
I am having a problem where the tension from the spoke coming from one side of the hub is minimal while that of the adjacent spoke coming from the opposite side is near maximum.
Quoted: 38 Post(s)
Liked 9 Times
Imagining the range of possibilities, I did facetiously wonder if I might be able to monetize this somewhere ridiculous such as onlyfansdotcom.
Don't know if I'd be able to deal with the folks coming there having peculiar fetishes.
At least you're disciplined enough to find something bicycling related in the photos
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
As to this patch, if the patch is holding air, just use it. The pressure of the tube against the tire will push down on the weak spot in the patch and shouldn’t be an issue.
Stuart Black
Stuart Black
Quoted: 5224 Post(s)
Liked 3,585 Times
how old is that patch?
Quoted: 18424 Post(s)
Liked 15,582 Times
Liked 3,585 Times
fortunately that was about 20 years prior to Wifey giving birth to our kids, otherwise it could have caused nightmares for both of us!
Cantilever believer
Quoted: 537 Post(s)
Liked 1,846 Times
I've replaced several patches due to age or type ("glueless", etc.). But I use a dremel with a sanding drum to completely remove any vestige of the old patch and expose clean rubber prior to applying the new fluid or patch. Never a problem afterward.
Quoted: 504 Post(s)
Liked 437 Times
I'd cut the patch through the defect and try peeling it off from centre to edge - otherwise that's going to take a lot of sanding, might be one for the bin.
