My luck can't be that bad, can it? Can it???
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,927 Times
Take a cotton ball and rub it around on the inside of the tire. If there is something there the cotton ball will catch it. Make sure there are no spokes poking though the rim strip and into the tube.
Get yourself this patch kit. You'll never mess with old school glue patches again after using these.
https://www.parktool.com/en-us/produ...patch-kit-gp-2
Klaatu..Verata..Necktie?
Quoted: 10435 Post(s)
Liked 11,911 Times
Yep... And ya do carry a spare tube... Before I went to Continental Ride Tour tires I was getting flats every now and then. I don't carry a spare tube but still think I should. I do carry a small hand pump, and a Mini Patch kit in which I have added an unopened tube of Super Glue along with the vulcanizing cement, tooth pick, razor blade, and a scab patch. I prefer the Lezyne type mini pump. Its not much bigger then your CO2 device. Ha... Ya probably won't get another flat for years to come. Also, some times with flats it's just your turn...
Amazon
Amazon
I only use it when riding my CF bikes that won't fit a frame pump. The other bikes, I have 3 frame pumps in different sizes, so I have pumps for any bike I ride.
Likes For genejockey:
Quoted: 1109 Post(s)
Liked 1,200 Times
Same here. And sometimes very hard to detect on the side of the road when one's patience is not up to the task. I've certainly been there (second flat). Fortunately, like you, the time it happened, it was a slow enough leak that I limped along re-inflating a couple of times just to avoid needing to patch the spare tube when it went. I learned to be more obsessive about those GD little occult flatteners! And can find them with my fingers ... because I know something is there and just keep at it until I find it.
Quoted: 2976 Post(s)
Liked 1,182 Times
I disagree because I have used these as a permanent solution many times. It's not like they all of sudden fall off or quit working. I no longer use glue patches since I found these.
Quoted: 581 Post(s)
Liked 921 Times
prj71 I find 'glueless' patches to absolutely be less reliable and think they should only be used in emergencies. I am happy you, and some others, have a different experience than me, and many others, but I don't trust them and only use 'glued' patches.
Quoted: 5224 Post(s)
Liked 3,584 Times
yeah I carry a pump & at least 2 cartridges. usually 1 extra tube + patches
on longer rides, I carry another tube & 2 more cartridges
I have 3 bikes all w/ diff. size tires/tubes. so I have to remember to move the pump to the bike of the day & change the tube(s) in my trunk
luck = when preparation meets opportunity
Liked 8,927 Times
Read what I wrote. They are not DESIGNED to be permanent. I expect some people get a more durable response (like you) but I maintain they are not really intended to be a permanent patch. As always, YMMV.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Likes For livedarklions:
Quoted: 8281 Post(s)
Liked 9,052 Times
Another time I was descending a long hill using lots of brake and the stupid patch blew off from the heat.
Liked 9,052 Times
Likes For big john:
Quoted: 185 Post(s)
Liked 36 Times
Flats
I did. I generally find a wire or cut or some such thing to explain why I have a flat. Not this time. I spent several minutes on the side of the road, running bare fingers on the inside of that casing, feeling for anything that might be stabbing the tube. Nothing found. At least not then. I'll spend some time this weekend and investigate more thoroughly and report my findings.
Been there, done that...I had one spring I thought my name might be FlatsALot lol. I had one that I couldn't feel anything, but I was getting one microscopic puncture, that didn't seem to present itself until there were a few miles on it...sometimes as many as 7-10. When I finally took the tire all the way off the rim, and ran a piece of cotton swab, it hooked on the tiniest of wires. Wire wasn't visible on the inside, or out, but was just enough to eventually puncture the tire. I had resisted removing the tire, because it was an absolute knuckle buster getting it on a rim.
Likes For VegasJen:
Quoted: 1069 Post(s)
Liked 788 Times
If you are willing to carry a pump on the frame (right next to a bottle cage), then consider getting the largest version of the Lezyne Road Drive. It can't match a full-sized frame pump, but it moves substantially more air per stroke than some of the really small mini pumps.
For conventional tube patching, I buy two of the Rema Tip Top TT 02 kits, and then combine some of the contents into one of the boxes to carry on the bike. That lets me have an open "in use" tube of cement, and also an unopened backup tube with me in case the "in use" one dries out. My current tube of cement has been in use for ~2-1/2 years.
Bikes: Orbea Onyx, Surly Disc Trucker, Trek 850
Quoted: 12 Post(s)
Liked 19 Times
I also carry a mini bic lighter in my pack. When I spread the glue out, I light it up for a few seconds before I put the patch on. Seals great.
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,836 Times
If it wasn't for bad luck,....I wouldn't have no luck at all!
Therefore, I always try to have a frame pump or minipump - AND extra CO2 cartridges. A spare tubular or 2 spare clincher tubes (depending on wheels) for extended rides. For off-road rides I include a small bottle of Stan's sealant. The little patch kits in my saddle bags are so old they should be replaced, but even new they will always be a last resort. Flats happen to us all - buying good rubber and replacing before tires are too worn is my added 'insurance policy' against roadside issues.
Liked 1,182 Times
Liked 1,182 Times
Check the reviews here. Their experience mimics mine.
https://www.vitalmtb.com/product/gui...t-reviews-7701
How to determine if a mystery flat is caused by rim strip failure when there is no evidence of any road debris to the tire: This has happened to me on a brand new bike build that I did a few years ago. I built up a brand new Lynskey with all new components except the wheels. The wheels were built with Kinlin's lightest aluminum rims & had vittoria rim strips. The wheels come in at 1400 grams. So after a week of riding with no issues, the next week I was getting constant flats on the front wheel. Put a new tube in & pumped it up & a mile later another front flat??? I could find nothing in the tire & was perplexed because it was a brand new tire. Everything on the bike was brand new except the wheels. Got home fixed the tube & next day went out & flatted again 2 miles out. Fixed it on the roadside & thought I would continue on but flatted immediately.
When I got home because I line up all my tires up with the valve hole, I could tell that all the punctures were in the exact same spot of the wheel. This led me to believe that it was the rim strip. Looking at the rim strip alone, you couldn't visibly see that it was defective. Where each rim hole was, you could see its outline & you could see where the spoke had poked into the strip but it did not puncture it. So I decided to just replace it anyway & that solved my problem. Not one front wheel puncture since. So if the rim strip on your wheels is a few years old, its worthwhile to just change them if you start to get mystery flats in the same area with no evidence of debris. Again as I said before, glueless patches can be a lifesaver but they are only a temporary fix & need to be replaced with a permanent patch when time permits.
Likes For stan01:
Liked 8,927 Times
Where does it say anywhere that they are not designed to be permanent? Do you have some facts to back this statement up or is that just your opinion?
You win!
Likes For datlas:
Liked 11,911 Times
Liked 9,052 Times
Obviously it didn't come out and go flying across the landscape.
Bikes: yes, i have one
Quoted: 1138 Post(s)
Liked 1,182 Times
i've used these and they do work until they don't. after about a year or so they invariably leak. i've had to pull them off and replace with a correct vulcanizing patch, done right those don't seem to fail. i still keep them in my saddle bag along with a spare tube and a real patch kit. you never know how many goat heads will be thrown at you.
