Shorter Cranks = Higher Seat Post ?
Old 01-11-15, 10:42 PM
rekon
rekon's Avatar
This is probably a dumb question. I raised my seat post about 5 inches and have 170mm cranks. If I get shorter cranks, could I raise my seat higher?
rekon is offline
Old 01-11-15, 10:43 PM
Jiggle
Jiggle's Avatar
Bikes: BH, Cervelo, Cube, Canyon
Liked 6 Times in 6 Posts
Yes
Jiggle is offline
Old 01-11-15, 10:56 PM
CliffordK
CliffordK's Avatar
Liked 4,645 Times in 3,438 Posts
Yes.
Do you have a goal for a higher seat post?
Consider when the pedal is at the bottom of the stroke.
Longer cranks = lower pedal at bottom ==> lower seat
Shorter cranks = higher pedal at bottom ==> higher seat
CliffordK is offline
Old 01-11-15, 10:57 PM
k_kibbler
k_kibbler's Avatar
Bikes: Canyon Ultimate CF SL
Yes, but I really hope you're not doing so for that reason alone.
k_kibbler is offline
Old 01-11-15, 11:01 PM
rekon
rekon's Avatar
I want to have a more aggressive position. I'm thinking I could accomplish this by buying a new bike (smaller than my current 52cm) or shorter cranks...
rekon is offline
Old 01-11-15, 11:08 PM
prathmann
Liked 7 Times in 6 Posts
The effect of 170mm vs. 175mm cranks is going to be pretty minimal (it's only 1/5 of an inch). I'd think you could get a more aggressive position with a change (or adjustment) of your stem that would be much more pronounced.
prathmann is offline
Old 01-11-15, 11:13 PM
CliffordK
CliffordK's Avatar
I'm not sure sticking your butt higher in the air makes you more aerodynamic.
You're better off dropping the handlebars.
Go with 140mm cranks, and it is about a 3cm difference.
Old 01-12-15, 12:37 AM
Fiery
Fiery's Avatar
Liked 18 Times in 13 Posts
You are doing it wrong. Have you removed all the spacers between the headset and the stem (including the large conical spacer)? What is the length and angle of you stem?
Fiery is offline
Old 01-12-15, 01:24 AM
TrojanHorse
SuperGimp
TrojanHorse's Avatar
Bikes: Specialized Roubaix
Liked 64 Times in 47 Posts
ding ding. Sticking your butt higher in the air isn't more aggressive.
I periodically ride with a friend of mine who is a dramatically stronger rider than I am - he prefers speedplay pedals because the stack height is ever so slightly lower and that lets him lower the seat a skosh, to get him out of the wind a little. Since he's so much faster than I am, I pretty much just say "uh huh" and keep pedaling.
TrojanHorse is offline
Old 01-12-15, 01:50 AM
WheresWaldo
Ride it like you stole it
WheresWaldo's Avatar
Bikes: 2012 Cannondale EVO Ultegra Di2, Pedal Force Aeroblade, Rue Tandem
Liked 20 Times in 18 Posts
Then he messes that all up by using shoes that require the 3 hole to 4 hole adapter.
"Never use your face as a brake pad" - Jake Watson
The Reloutionaries @ Shapeways
WheresWaldo is offline
Old 01-12-15, 02:30 AM
dtrain
L-I-V-I-N
dtrain's Avatar
+1. The adjustment for shorter cranks is in the range of 5-10mm. You (the OP) have moved your seat by inches already... ?
"The older you do get, the more rules they're gonna try to get you to follow. You just gotta keep livin', man, L-I-V-I-N." - Wooderson
'14 carbon Synapse - '12 CAAD 10 5 - '99 Gary Fisher Big Sur
dtrain is offline
Old 01-12-15, 06:47 AM
Wesley36
Wesley36's Avatar
I went to 165mm cranks to get more aggressive. I have a flipped and slammed -17 stem, and I am flexible enough that it is comfortable, but the problem was that I kept kneeing myself in the chest with 170s.
I now graze my jersey with my knees with 165s, so yes, shorter cranks did help me use a more aggressive position.
Wesley36 is offline
Old 01-12-15, 06:50 AM
Wesley36
Wesley36's Avatar
Oh, and my seat came up 5mm, of course
Wesley36 is offline
Old 01-12-15, 07:11 AM
WhyFi
WhyFi's Avatar
Liked 9,462 Times in 4,673 Posts
Yeah, but it looks more aggressive, and isn't that all that matters?
WhyFi is offline
Old 01-12-15, 10:27 AM
woodcraft
woodcraft's Avatar
Liked 923 Times in 569 Posts
Don't forget that you'll be faster if you can reach the pedals.
woodcraft is offline
Old 01-12-15, 09:19 PM
KantoBoy
KantoBoy's Avatar
I think a slammed -17 is still too low.
I'm sure you'll defend the set up but I really hope you're getting a full pedal stroke.
KantoBoy is offline
Old 01-13-15, 03:34 AM
Wesley36
Wesley36's Avatar
Based on what? Do some research before deciding you know what is what regarding crank lengths and pedal strokes
Determinants of maximal cycling power: crank length, pedaling rate ... - PubMed - NCBI
Trained cyclists (n = 16) performed maximal inertial load cycle ergometry using crank lengths of 120, 145, 170, 195, and 220 mm. Maximum power ranged from a low of 1149 (20) W for the 220-mm cranks to a high of 1194 (21) W for the 145-mm cranks. Power produced with the 145- and 170-mm cranks was significantly (P < 0.05) greater than that produced with the 120- and 220-mm cranks.*
Determination of the crank-arm length to maximize power production in recumbent-cycle ergometry | Danny Too - Academia.edu
Note in this study highest peak power was around 165mm
Crank Length - Cervélo
Wesley36 is offline
Old 01-13-15, 03:38 AM
Wesley36
Wesley36's Avatar
Wesley36 is offline
rotti
"The 33"-Road Bike Racing
10
06-21-11 12:23 PM
KasbeKZ
Road Cycling
5
04-19-10 06:45 AM
xfimpg
Professional Cycling For the Fans
5
03-11-10 03:47 PM
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Your Privacy Choices -
