Powermeter choice (and questions regarding magene)
Bikes: BMC SLR01; Cannondale Trail; Lot's of project and vintage bikes..
Quoted: 342 Post(s)
Liked 168 Times
I'm searching for a powermeter but also I don't want to break the bank.
The product that took my interest are:
Also I'm not sure regarding the pedals, I came from keywin and wahoo pedals but those types I never tried even once.
For me the pedals are less worth since they request even more maintenance...
Has anyone tried the magene?
Do you think will be a wrong choice?
- Magene pes p505 299.99 euros
- Favero Pedals Powermeter Assioma Uno 409.99 euros
- INPEAK POWERCRANK-E for Ultegra r8100 (my currently crank) at 389 euros
I have a P505 Base on order and have done extensive research. I am willing to take a chance. The direct swap w/ Shimano definitely help and the fact that I can use my own chainrings.
Bikes: Lemond Zurich/Trek ALR/Giant TCX/Sette CX1
Quoted: 629 Post(s)
Liked 942 Times
The pedals can be moved from bike to bike - for me that is a big advantage over crank based products.
Thread Killer
Quoted: 3271 Post(s)
Liked 1,813 Times
Yeah, that’s why I have Assioma Duo. I’ve been using them for years, and reliability has been excellent; I maybe replaced bearings once, but it only takes about 15 minutes so I don’t even remember. Cleats wear out, too, but I move the Assioma across a few bikes, so that versatility (and consistency in the numbers) is supremely valuable to me.
I have the Magene, so does my wife. Love it. Prior to this I used 4iii and Stages. Absolutely excellent product.
Perceptual Dullard
Quoted: 960 Post(s)
Liked 1,234 Times
Here's a video of my friend swapping a spider-based PM (in this case, a Quarq, but others are similar):
Likes For RChung:
Bikes: Santa Cruz Blur 4 TR, Canyon Endurace cf sl, Canyon Ultimate cf slx, Canyon Strive enduro, Canyon Grizl sl8
Quoted: 271 Post(s)
Liked 1,174 Times
I have the Favero Assioma Duos (w/Shimano pedal bodies) and I'm totally happy with them. They seem fairly accurate and just work without any issues. Unlike my Garmin pedals for my MTB and gravel bike, that require use of a torque wrench to even get somewhat accurate readings.
Quoted: 891 Post(s)
Liked 738 Times
How much maintenance did you read that PM pedals need?
I've never done anything other than change the batteries on my PowerTaps and have used them on multiple bikes since 2018.
![foo](vb/cache//ds.jpg)
Thread Killer
Liked 1,813 Times
As long as the BB is compatible, moving a crank-spider-based PM is simpler and faster than moving two pedals (if you have the right wrench): there's only one fastener to undo and tighten, rather than two. But in either case, we're talking a difference of maybe 90 seconds for replacing a crank spider PM and maybe 3 minutes for replacing two pedals, so the difference is pretty unimportant.
Quoted: 342 Post(s)
Liked 168 Times
But now thinking I do almost the same maintenance on my speedplay.
Quoted: 342 Post(s)
Liked 168 Times
Quoted: 4645 Post(s)
Liked 5,180 Times
Perceptual Dullard
Quoted: 960 Post(s)
Liked 1,234 Times
Ah. I had not realized that you keep your other bikes around without pedals and you only have one single set of pedals that you use for all your bikes. In that case, nevermind.
Quoted: 342 Post(s)
Liked 168 Times
Update.
I've done some comparison with the weights.
My currently pedals are the wahoo that's weight 334g (cleats included).
The assioma (1Pm/1normal) Weight on total 345g.
That's not an huge weight penalty compared to the 50g of the crank set spider of the magene. Also seems hard to find any lightweight alternative to the currently Ultegra r8100 chainrings.
Plus swapping the assioma pedals body with the Ultegra version will reduce 77g for pair.
If I done my calculations right seems super good for a weight pov.
This made me overthinking more haha
Liked 5,180 Times
Update.
Thread Killer
Liked 1,813 Times
Ha! Well that’s not quite the case, but is closer to reality than the notion that I have bikes sitting around without cranks and only have one single crankset to share between them!
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2837 Post(s)
Liked 3,430 Times
Longtime powertap user that went to Favero Duo so I could have power on race wheels, especially in TT. The Faveros are great. The only maintenance I do is remembering to charge them. The charge lasts a while. They read a few percent lower than my powertap, and a few percent lower than my Saris Hammer H3, but really that doesn't matter as long as they are consistent. I'm a fan 5/5 stars and I will never go back to powertap.
"Your beauty is an aeroplane;
Not actually Tmonk
Liked 3,430 Times
I do swap them between three bikes (2 road bikes 1 TT bike) which is sort of annoying. I'm considering a dedicated crank-based PM for my daily driver TCR so that it's just ready to throw a leg over and ride all the time. I swap the pedals at least once a week and I'd rather not have to do that,
Quoted: 271 Post(s)
Liked 1,174 Times
For me, it was to not introduce another pedal system into my quiver. I already had a couple pairs of Shimano SPD style pedals across a couple of different road bikes, so it made sense to get the Faveros that came as a spindle only. The Faveros really only get used on 1 of my road bikes, as my other has a 4iiii crank arm power meter.
It depends on the rider, but the Faveros with the Shimano pedal bodies can either be a positive or negative. They have an increased stance width/Q-factor compared to standard Shimano pedals or the Faveros with the Look-style pedals. Standard pedals are too narrow for me, so that was a benefit in my case.
