Garage Bike Storage
Quoted: 5 Post(s)
Garage Bike Storage
I am sure this topic is extensively discussed, but no amount of searching I do (either through the forum search box, or Google) brings anything of substance. I am looking for the most space efficient way to store up to 10 bikes in a garage. What do you do?
SO, can you either direct me to the best threads discussing this, or comment here with your solutions?
Many thanks in advance!
Still learning
There are at least a half dozen threads about bike storage on this forum
Google:
bike storage bikeforums site:www.bikeforums.net
Google:
Bikes: Trek Madone 2.1
Ceiling pulley mount system...$17 on ebay, $24 at performance bike...My wife's bike stays there, mine doesn't get stored yet.//.
Quoted: 569 Post(s)
Liked 582 Times
I use the ceiling pulley for bikes or frames in long term storage and for shorter term I use what Harbor Freight calls a cycle tree which hold 4 bikes in about 16 square feet. It's on rollers so it tucks into a 4 ft space and then rolls out to place or remove bikes.
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
Avoid using plastic covers as it catches /retains moisture that can cause corrosion on your bike. An old, thin blanket would be a better choice, just to keep the dust and dirt off the bike.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Depends how many bikes. I have a lot, so my approach is to mount a piece of 1/2 inch conduit perpendicular to the ceiling joists, then use vinyl coated hooks to hang bikes, frames, and wheels. By far the cheapest option I have found if you are trying to store quite a few
Bikes: (3) 1970's Raleigh Sports, (1) 1968 Robin Hood 3 speed, 1974 Raleigh Grand Prix, 1976 Raleigh Grand Prix, 1969 Peugeot UO-18, 1971 Peugeot UO-08, 1980 Giant road bike, 1954 Humber, 1940ish Hercules Popular, 1963 Dunelt, 2007 Trek 3700 mountain bike
I bought a "Cycle Tree" from Harbor Freight a couple of years ago that holds 6 bikes in a small footprint plus the caters allow you to move the entire rack if needed. Cost about $32 if you use one of their 20% off coupons.
https://www.harborfreight.com/cycle-t...rage-2628.html
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
You can easily hang 15 bikes along a 10 foot length of pipe, which can be attached directly to overhead floor joists.
I made a tool for bending up to 3/8" steel rod, but 40-pounds will hang safely from hooks made from 3/16" steel rod if the bend radious doesn't exceed 5/8". The 3/16" rod hooks are toward the right in this photo, while the thicker ones might hold a small motorcycle.
Thrifty Bill
Liked 964 Times
Pipe is a lot stronger than conduit, so I have to attach the conduit to every other ceiling joist.
Still learning
Quoted: 5 Post(s)
Google:
Google:
Bikes: 84 Trek 620, 74 ladies Raleigh Sports, 74 mens Raleigh Sports, 10 Scattante x330
Kobalt K-rail and the bike hooks to the wall. Holds em nice and steady and you can close pack them. Prolly about $40 total at Home Depot. Expandable too.
feros ferio
Quoted: 1393 Post(s)
Liked 1,326 Times
My rafters are spaced 2' OC, so I hang a bike from each one, upside down, using two bicycle storage hooks.
