23 v. 25 vs. 28 mm tire width?
I'm looking at a tire that comes in two widths, 25 or 23 mm. What is the most widely used tire width for road cycling? I understand the thinner the tire, the less contact with the road = more speed. The thicker the tire = better handling on unpaved surfaces. Why would someone want the "thicker" 25 mm or even a 28 mm tire? I don't imagine having to ride on any gravel or grass, should I go with a 23 mm tire?
Aside from performance, how does width affect stability and durability (in terms of getting flats)? Also, will a 23 mm tire fit all standard 700cc rims that come with a 28 mm stock tire?
Quoted: 1743 Post(s)
Liked 1,281 Times
If you do a search I think you will find information that suggests the old "narrow tire = faster speed" belief is no longer considered to be accurate.
Quoted: 6196 Post(s)
Liked 4,810 Times
If you ride one till they wear out then try the same model tire in the other width, then you'll know first hand.
It wasn't much to talk about when I tried it as some have made the great debate sound.
As for the size rims, it depends on the internal width of your rims. But a rim with an internal width of 15 mm will probably fit all of those tires with no issue.
Likes For blacknbluebikes:
Habitual User
Quoted: 4955 Post(s)
Liked 8,097 Times
If you're willing to make the effort to learn a little more about it, this is something that was helpful when I was trying to wrap my head around it... https://cyclingtips.com/2016/08/cycl...-and-pressures.
As a racer-boy from the early 2000s, I used to run 23mm at 110psi all the time. I'm currently on 25mm tubeless at 80/85psi, and they're very good. I'm curious to try 28s, but I don't know if they will fit on my bike.
Likes For Eric F:
Quoted: 20810 Post(s)
Liked 9,456 Times
This is for the Eurobike?
Likes For WhyFi:
Lots of variables to consider: riding style, rider weight, road quality, rim width, tubeless vs clincher,bike type etc. These days for the solo recreational riding I do, I use the widest tires I can comfortably fit on my 2 bikes, so 25c on one and 30c or 28c on the other. In general wider tires can run lower pressures so they give a plusher ride and are better suited for poor roads and even light dirt.
Habitual User
Liked 8,097 Times
Likes For Eric F:
Trying to keep up
Bikes: Pinarello Prince, Orbea Onix, Ridley Fenix
Quoted: 79 Post(s)
Liked 136 Times
I'm running 26 (thank you Pirelli) on my bike. A little wider at a lower PSI does offer some additional comfort. On rolling resistance, the data suggests that at similar PSI, wider tires have lower rolling resistance. If you run them at a little lower PSI for comfort, some of that advantage goes away. The reality is that most of us mere mortals won't be terribly affected by the minimal difference in rolling resistance from running a little lower PSI. I can say my 26mm tires set up tubeless running 70-75 PSI are about as comfortable as the 28mm tubed running 80 that I had on before, though the wheels are different.
In short, no, you do not need to run 23s - I wouldn't recommend it. You'd be more comfortable and just as fast on 25s or 28s, provided you lower your pressure within guidelines.
I can’t understand this never ending topic of increasing road tire width. I ride 23 mm for years on not perfect roads. First clinchers, then tubeless since last year. Around 85 kg “system” (rider+bike). 90/80 PSI back/front tire. Never had a pinch after some 50000 km. I’m absolutely sure that even at 80 / 70 PSI (which I surely had 10-20% of time, after 5-6 days of not inflating the tires), I’m still far from taking a pinch. I could go even further down with the pressure without a pinch, but I really don’t need it.
Besides, in terms of aero - drag, increasing tire width might not be optimal on shallow rims (e.g.: if tire profile exceeds rim width). So, I think the whole system rim-tire can make a difference, but the gains/loses in performance are hard to monitor and imperceptible for amateurs rides.
Habitual User
Liked 8,097 Times
Likes For Eric F:
Quoted: 18883 Post(s)
Liked 10,646 Times
The entire road cycling world moved away from 23s starting about 10 years ago. There's a reason. Actually there are a lot of reasons.
I ride 28s.
I ride 28s.
Likes For Seattle Forrest:
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
I feel like this was a big and hotly debated topic when I went on my cycling hiatus almost a decade ago, and we're still talking about it. It seems, as Eric mentioned above, that the smoother the surface the narrower and harder tire you want to run. You'll still see 23mm and narrower at the velodrome, but most riders are favoring wider tires out on the streets these days.
It's like riding a bicycle
Likes For urbanknight:
Ignoring that amateurs never run Paris Roubaix, never run 150-200 km races and most often don't have the financial and mechanical grounds to correctly fit expensive rims with tires, is the way of useless spending of money for imaginary (or, in the best case, imperceptible) gains in performance.
That's just my opinion, please don't shoot!
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Yeah, amateurs do races of that length, and longer.
The now defunct Everest Challenge was 120 miles, 14,700' day 1; 85 miles, 12,500' day 2. Spectacular ride.
I don't race but entered the 40+ open race for fun on a 24-lb touring bike, wound up with the jersey.
Likes For terrymorse:
Quoted: 4413 Post(s)
Liked 4,867 Times
For me the trend of wider, higher volume tyres has simply made the ride quality so much better without any obvious loss in speed. I don't see any reason to run 23 mm tyres on a modern road bike with enough clearance for 28 mm or above. I prefer running tubeless too, but that's a whole debate by itself!
Likes For PeteHski:
Quoted: 3952 Post(s)
Liked 7,299 Times
Forget about the size, just buy the cheapest tire you can find. Trust me.
Likes For tomato coupe:
Liked 7,299 Times
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Fully agree. But I think that amateurs (and all readers of this forums are amateurs) should think whether it is really relevant for them.
Events like the Furnace Creek 500 or Voodoo 500 are races, and most (if not all) participants are amateurs.
I have yet to meet a current pro on the forum, so it would be fun to try and find one. Better yet, I'd want to know what their mechanic has to say about equipment more than they do!
Finally, imaginary, imperceptible, whatever. We just want to know what's perceived as the "best" and spend our expendable income on it, then let the placebo effect make us "right".
Liked 9,456 Times
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
I will say though that I am guilty of doing exactly what Tomato Coupe suggested. Every time I plan on buying a 25mm tire for my road bike, I see that the 23mm is on sale for less (no surprise considering the trends) and choose to save $10 or $20 rather than save my butt.
ok, i got it, i'll go with either 25 or 28mm size. for the 2 posters who were trying to be sarcastic with lipsticks and pigs and asking for which bike this is...this is for my fat bike...I'm going to try to put 25mm tires in place of my 4 inch tires on the fat bike. that will turn heads. i'm sure those tires will beat everyone in the trails, as they make less contact with the rocks.
Liked 4,867 Times
Likes For asgelle:
Quoted: 1067 Post(s)
Liked 259 Times
