Need some help solving this
Old 08-05-21, 10:11 AM
sloar
Bikes: they change so much I'm tired of updating this
Quoted: 1212 Post(s)
Liked 1,128 Times in 427 Posts
I’ve tried everything I can think of. When the chain is on the small chainring I get a grinding noise on every hard pedal stroke. No noise when I do a soft pedal stroke and no noise at all on the large chainring. Doesn’t matter what the rear cog is and I’ve moved the front derailleur up, down and sideways. I’ve also tried different pedals. Any ideas?
Semper fi
sloar is offline
Old 08-05-21, 10:15 AM
Schreck83
Schreck83's Avatar
Quoted: 177 Post(s)
Liked 313 Times in 162 Posts
Is the inner chainring bent at all? Sounds like deflection when working hard.
72+76 Super Course, 74 P-10+ 79 Tandem Paramounts, 84 Raleigh Alyeska, 84 Voyageur SP, 85 Miyata Sport 10 mixte and a queue
Schreck83 is offline
Likes For Schreck83:
Old 08-05-21, 11:14 AM
qcpmsame
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times in 241 Posts
I’d check the bottom bracket bearings and cups for wear,, and the rear wheel’s bearings as well. I had issues with the pre-load on both of these bearing locations allowing them to loosen and cause grinding of surfaces due to play.
Semper Fi bro👍
Bill
Semper Fi, USMC, 1975-1977
qcpmsame is offline
Old 08-05-21, 11:16 AM
dddd
Ride, Wrench, Swap, Race
dddd's Avatar
Quoted: 1565 Post(s)
Liked 1,296 Times in 866 Posts
A worn chainring with a new chain will produce a rumble felt and heard, which gets more intense as pedaling force increases.
You can file away the forward-facing hooks from the driving side of each tooth to eliminate the noise entirely.
A 1mm bevel to the sharpened corner atop each tooth usually prevents the chain's rollers from contacting the corners during both the engagement and disengagement events as links fall into and out of mesh with the worn chainring on every revolution.
I have fixed many chainrings this way and it's almost always the small chainring that needs it.
dddd is offline
Likes For dddd:
Old 08-05-21, 11:20 AM
droppedandlost
small ring
droppedandlost's Avatar
Quoted: 438 Post(s)
Liked 925 Times in 370 Posts
do I see daylight under the chain?
59 Allegro Special -- 72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
droppedandlost is offline
Old 08-05-21, 11:45 AM
cocoabeachcrab
Myrtle Beach Crab
cocoabeachcrab's Avatar
Bikes: enough one would think, but thinking isn't my strong point
Quoted: 271 Post(s)
Liked 541 Times in 214 Posts
doesn't look like the chain is evenly seated across all the chainring teeth.
cocoabeachcrab is offline
repechage
Quoted: 3464 Post(s)
Liked 2,829 Times in 1,995 Posts
for grins, check the security of the chainring bolts.
repechage is offline
Old 08-05-21, 11:47 AM
CliffordK
CliffordK's Avatar
Quoted: 18376 Post(s)
Liked 4,511 Times in 3,353 Posts
How about some good photos of the small ring?
After replacing the chain, I rotated my small ring a bolt hole or so, hoping to even out the wear, but instead I created noise problems, and I eventually replaced the ring.
CliffordK is offline
Old 08-05-21, 01:48 PM
sloar
Chainring bolts tight, chain is fitting on the ring fine.
Semper fi
sloar is offline
Old 08-05-21, 02:18 PM
juvela
juvela's Avatar
Quoted: 3811 Post(s)
Liked 3,338 Times in 2,178 Posts
another possible contributing cause could be a torsioned chain
you could demount chain and let it hang loosely to check for a torsioned section
juvela is offline
Old 08-05-21, 02:30 PM
Trakhak
Trakhak's Avatar
Quoted: 2482 Post(s)
Liked 2,955 Times in 1,678 Posts
Photo of back of chainrings in post 9 shows badly worn teeth on the smaller ring and moderate wear of those of the outer ring. Notice that the troughs between the teeth of the inner ring are longer and more asymmetrical than those of the outer ring.
I'd replace both rings, but you might be able to get away with replacing just the inner ring for a season or two.
Trakhak is online now
Likes For Trakhak:
Old 08-05-21, 02:36 PM
sloar
I’m going to blame it on the Regina chain. I pulled the cranks to inspect everything. Checked the bottom bracket to make sure it was tight. Then a stuck a narrower chain on it. No more noise, I’m wondering if the Regina was too wide.
Semper fi
sloar is offline
Old 08-05-21, 03:17 PM
Drillium Dude
Drillium Dude's Avatar
Quoted: 2588 Post(s)
Liked 4,824 Times in 1,709 Posts
That particular Regina is pretty wide, and that extra width contributed - but I agree with Trakhak : the "shark tooth" profile on the inner ring teeth dictates immediate replacement.
DD
Drillium Dude is offline
Old 08-05-21, 04:09 PM
juvela
juvela's Avatar
wrt shark tooth profile -
since the chainwheel's dentition is cut from the centre of the stock you can double its life by reversing it
the bushings will protrude one mm or so above the face of the chainwheel but all else will be the same...
juvela is offline
Old 08-05-21, 04:57 PM
Kabuki12
Quoted: 874 Post(s)
Liked 2,288 Times in 1,278 Posts
I had the same symptoms with a worn out chain. I had just bought the bike and it hadn’t been ridden in quite a while . the FW was for racing so I replaced it with a more touring set up. The chain rings looked very good and I did not check the chain before I cleaned and lubed it . Every thing was cool on the stand and when I was just cruising. When I accelerated or climbed I got a grinding feeling. I had already serviced the bottom bracket . I took it apart again and meticulously cleaned and greased the bearings and put it back together with proper adjustment. Finally I gave up after 3 or 4 short rides and took it to my favorite LBS. The first thing they checked was the chain, yup! I bought a new chain AND a chain gage. Bike rode smooth as butter.
Kabuki12 is offline
Likes For Kabuki12:
Old 08-05-21, 07:08 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3588 Post(s)
Liked 3,400 Times in 1,934 Posts
Have you determined where it is rubbing? Hard pedaling in the small ring will cause the chainstays to deflect, which in turn can cause the chain to rub on either the front derailleur or outer ring. If it is the front derailleur that is rubbing, a little trim can fix that. If it's rubbing on the ring, that will be harder to address, and you may just have to live with it or avoid hard pedaling in the small ring.
JohnDThompson is offline
