Brake lever choice for mechanical disks
I am reluctantly giving up my drop bars on my Kona Rove that has mechanical disk brakes (TRP Spyre). I will be using a Jones bar with the 2.5" rise. Not sure what works best, long pull, short pull, "linear pull", etc. with that brake and bar combo. I occasionally ride this bike fully loaded so power is a factor, but it is mostly ridden as a road bike on Tarmac. Any suggestions from personal experience is welcome.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
Spyre's are a short pull brake so something like the Paul Canti Levers would be an ideal choice. They have the nicest feel and would be ideal if you are looking for good power and modulation especially with good compressionless housing and quality slick stainless steel cables.
Likes For veganbikes:
Quoted: 3461 Post(s)
Liked 1,467 Times
I think that Tektro makes brake levers that are short pull for flat bars, did you check their website? Levers that are listed as working for cantilever brakes should work on your Spyres.
TEKTRO BRAKE SYSTEMS
Likes For Tourist in MSN:
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 321 Times
I love my 4 finger Sturmey Archer levers on my 3 IGH bikes. They have 2 holes for the rivet but come as short pull, I'm using them long. The newer ones have comfy plastic inserts that are not wearing down AFAIK.
Right or wrong, it's working fine with SA drums, Spryre disc on my Rohloff14 and soso with an old side pull caliper on my CCM front wheel. The Spyre pads grip instantly anytime, 203 mm disc. None of my brakes ever squeak.
Edit >> Well I just had a look at my latest Simcoe roadster bike bought last spring, that I've modified just about everything. The stock levers were crap and the first to go. I put on a second pair of SA levers I bought 5 years ago, they are still at short pull. The front wheel has the SA XL-FDD that was on my tour bike, used it about 500 miles on this bike. I guess I never noticed any difference in feel.
The rear has a Nexus 7i with roller brake. It is very mushy, so maybe I'll have to try something.
Likes For GamblerGORD53:
tektro MT3.0 for flat bars on all my hybrid/mtb bikes.
used with BB7's.
cheap, dependable, bulletproof 2-finger brakes.
used with BB7's.
he needs to do the research on the various tektro levers to match up the lever pull to his spryes.
Likes For djb:
Liked 1,467 Times
Liked 321 Times
2 finger levers are just about the dumbest awkward thing going. IMO. Cheap alright. It's even dumber that they are often paired with twist grips. LOL. Whether they work as well has no relevance. I did use them once or twice on a hotel rental with a rim brake canti.
BB7s are dinosaur technology now.
I rest ALL my fingers on mine, a lot of the time.
I know there's fancy levers now that you can switch the pull anytime. Then you can figure out the pull makes NO difference. LOL.
When I set up my troll with dropbars, and mtn bb7's, I had to be sure to get the right long pull dropbar levers, so this fellow will have to be sure of his levers.
My understanding is that this is pretty important.
Shimano levers have an adjustment for short and long pull.
BL-R780
BL-R550
BL-R4700
BL-R3000
etc...
BL-R780
BL-R550
BL-R4700
BL-R3000
etc...
Likes For katsup:
I did find a couple models on the Tektro website that specify "disk". Two of them are Eclipse MT 2.1, and the RT354AG. Both are an MTB style that look like a 2-finger design. I would love to find one that is more like a 4 finger design. Hard to tell with the Sturmey Archer, levers. The do not indicate if they are short-pull.
I rest ALL my fingers on mine, a lot of the time.....
i dunno if they're officially called/labeled "2-finger levers."
that's just the maximum amount of force required (for me)
to activate them for emergency/fast stops.
in normal use......one finger is plenty.
i did buy a set of moto-x lever pads, cut the small one
in half, put half on each lever. comfy.
might depend on your hand size.
i gots big handses, so it's ueber-comfortable to rest a couple
fingers on the levers with hands on the grips, thumbs on
the trigger shifter.
i want instant brake response in traffic, so no bother.
big hands = unable to use a standard laptop keypad,
need to carry a separate full size keyboard.
Liked 1,467 Times
Canti brakes are considered a short cable pull brake.
it's pretty straight forward with some research
good luck
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Stuart Black
Stuart Black
I get it that there is more here than I thought I needed to learn. One consideration I have to make these days is arthritis in the knuckles of my index and middle of my right hand. It seemed to me a lever I could use four fingers on would be helpful, especially on long gravel descents which abound the local area.
I get it that there is more here than I thought I needed to learn. One consideration I have to make these days is arthritis in the knuckles of my index and middle of my right hand. It seemed to me a lever I could use four fingers on would be helpful, especially on long gravel descents which dominate the local area.
And yes, regular length levers are more appropriate imo than the stubby ones.
It had a pair of Gevenalle CX levers on Salsa Woodchipper bars. Yes, I was happy with the performance of those.
I'm familiar with those levers, I have a set but with avid bb7 mtb versions. Those brakes are long pull brakes, so I had to specify the Gevenalle long pull versions.
Liked 4,218 Times
Helpful to know if you have to sort hundreds of brake levers.
Stuart Black
Stuart Black
if you look at the angle of your finger, from the last joint to the end of finger, I find more finger power and better feel for modulation with that angle 45 degrees+, rather than just a slight angle.
Not very clear I realize.....
but keep this in mind if you have those issues that impact things.
I know some people who think instant engagement of lever is safer in their minds (faster braking response) but it really has less mechanical advantage.
*We are talking small differences in lever position here though.....
Likes For djb:
makes complete sense.
What actual points do you measure from, middle of the anchor points of brake cable end stop things, like middle to middle standard for handlebars etc,
have yet to look at levers I have, just curious.
Liked 1,467 Times
