Aluminum or steel for gravel bike
I don’t live in Tampa
Bikes: 2014 Jamis Ventura Race, 2014 Cervelo P2, 2017 Raleigh Tamland 1, 2015 Jamis Trail X
Liked 42 Times
My prefer is steel but there is a cost factor. I'm a fan of Jamis bikes and am interested in the renegade series.
Expat (steel frame) - $1199
Exile (aluminum) - $799
Or potentially Performance has the Access Old Turnpike (aluminum frame) for $649
Any racing I would be doing would be an afterthought so performance is not a high priority. Not that I want to be slow. most riding on flat roads and mostly reasonably well maintained gravel/fire roads.
Is the cost worth it to get steel frame? and opinions on above bikes are welcomed.
Funny, I was just looking at the Renegade series last night and honestly I think the Expat is worth the extra money. The new Tiagra group is essentially the older 10s Dura-Ace, so it's very good and 10 speed. The brakes are better, the color is better, and steel has a better ride feel. For a bike that I'd likely have for a long time an extra $400 up front is worth it. Now, if you are strictly budget limited there is nothing wrong with the Exile either, it's a very capable bike.
2019 Salsa Warbird
2019 Salsa Warbird
I have a chromoly bike and like it alot. Based on my personal experience riding gravel, I'd recommend steel. However, I have nothing to compare it as I've never ridden an aluminum gravel bike.
You might look into Soma Fabrications for a steel frame. They have road, gravel, utility and CX models. They're very clean looking and priced well. I have their Smoothie frame which is a road fame (caliper brake bosses) but I made it into a no-mud gravel bike.
Liked 42 Times
Soooo.. where in tampa are you finding these roads? Cause I wanna come
I definitely lean towards steel and it's likely a bike I would keep long term. I have a Jamis road bike but I can't get tires larger than 25s on it so it can't really function well even on the service roads. The Renegade would be my long term solution for having a bike I could ride on the road and gravel. I'm probably looking at end of year to purchase. I have an ironman I'm training for this year so I won't have much time for gravel riding. After this year, I'm planning to start riding in the forest more.
lol I am actually not in Tampa anywhere. I'm in Mount Pleasant, SC outside of Charleson, SC within about 5 miles of Francis Marion Forest which has, I believe 100s of miles of trails and service/forest roads. They have a stage race there https://www.facebook.com/pg/Hellhole...ageRace/about/
Sounds like you're not the poke-a-long kind of person considering you're training for an Ironman. If the Renegade is going to be your one-bike-fits-all road and gravel bike then you may want to get a bike that has a little more road or cyclocross geo. The Renegade is designed to be super stable so it won't feel as lively on the road. Just something to keep in mind.
2019 Salsa Warbird
2019 Salsa Warbird
Liked 42 Times
Interesting avatar then
Bikes: Allez/Motobecane 427HT & Ti/Soma Custom Build
I recently bought a Soma frame from Western Bike Works. Very positive experience. Still building the bike, but frame appears to be top notch. May end up buying another frame for a roadie.
BTW the Soma Wolverine is very popular, and most seem to love them.
Wolverine | SOMA Fabrications
Sunshine
Liked 7,726 Times
All my drop bar bikes(touring, road, and gravel) are steel, so I obviously have a bias here, but I would look beyond the frame material and see how you get a lot higher component level and offerings with the Expat. Im no component snob, but...
- The Expat has a carbon fork(vs Exile aluminum).
- The Expat has a thru axle front wheel/fork(vs Exile QR).
- The Expat fork has a ton of mounting options for gear(vs none for Exile).
- The Expat has TRP Spyre brakes instead of the Exile's Lyra.
- The Expat has a Tiagra drivetrain instead of the Exile's Claris. And a higher level crank too.
These are tangible improvements, not just vanity. For vanity, the Expat has Ritchey seatpost, stem, and bars. Being a Ritchey fan(the guy is an incredible talent) thats cool to me, but admittedly the stock Exile stuff is going to be perfectly fine.
The only drawback, to me, is the Tiagra drivetrain is incredibly limiting. It works with itself. You cant use higher or lower current components with it. If that doesnt matter to you(and it wont to 85% of riders), then cool.
So you get all that AND a double butted steel frame for $400 more.
I considered the Expat last summer but ended up with a Black Mountain Cycles Monstercross frame to build from because I wanted the option to run tires wider than 40mm. My current tires are 40 though so I clearly havent used that option yet and the Expat would have worked great!
Liked 42 Times
Liked 42 Times
renegadeexpat
cable runs Under the top tube
https://www.jamisbikes.com/usa/renegadeexile.html
cable runs over the top tube , better if you have to shoulder the bike ..
but sloping top tube does not help ..
Sunshine
Liked 7,726 Times
A couple 80s road bikes, an 80s sport touring bike, a classic full touring bike, a current gravel bike, and im building a 90s mtb frame up to replace another 90s mtb.
So 6.
Excessive when considering how much (or little?) a couple of them are ridden.
Part of what i love about cycling is refurbishing older bikes and building up frames. And japanese made bikes are an obsession. Those two things are why all my bikes but one (the mtb im building) are steel.
Steel gravel/adventure bikes are fantastic jack if all trades bikes. They may not master anything, but as long as you arent doing serious competition gravel racing, there really isnt a downside(weight being the 1) to steel as a material.
My gravel bike is 65cm and it weighs 25#. Not a sub 20# bike by any means, but at that frame size not much will be and itll be too costly. A 25# bike (with pedals, bottle cages, and pump included) for me is plenty light enough to feel quck and fun to climb.
So 6.
Liked 42 Times
So 6.
So 6.
Motorvated
Considering the Expat. I live in flat South Florida so I am basically a roadie, but love going off the beaten path. So I get that but how is it for doing the road thing? Also what kind of pedals are folks using? I would like to stay with my MTB clips.
Liked 42 Times
I've seen plenty of road cyclists using MTB clips (SPD pedals) so I don't see why you couldn't stick with those. The geometry should be similar to a road bike. I'm sure there are some subtle differences. it's the bigger tires that might slow you down a little on the road but from reviews it's not a huge amount. It just depends on how you're riding. You can always add skinny tires if you're just going out for road riding.
I use SPD pedals on my gravel bike, mainly because that's what I had but I've heard some riders prefer them as these have more clearance for mud/dirt, and it's easier to walk with mtb shoes on rough roads.
Sunshine
Liked 7,726 Times
The platform side isnt used often, but ive found its useful. And there is no downside to me as its incredibly easy to lock in with the SPD even if its on just one side.
My road bikes all have A520s which are also one sided and much lighter(no platform side).
Since you already have a style, just use it for any new bikes. There are no rules in all this and if anyone says there are rules, thats good to know so you can identify who you dont want to ride with.
Bikes: '17 Access Old Turnpike Gravel bike, '14 Trek 1.1, '13 Cannondale CAAD 10, '98 CAD 2, R300
Liked 12 Times
I like steel bikes. Right now... the only steel bike I own is an 88 Trek 360. But I really like that bike. But to be honest almost all my riding is done on modern/newer aluminum bikes.
For me... I wanted to try disc brakes. I want to try tubeless tires And I wanted to try gravel grinding. The Old Turnpike wheels are capable of tubeless.... but the bike came with tires that need tubes. But maybe in a couple years I'll give tubeless a try.
I am not attracted to the idea of jumps or fast downhill mountain bike courses. Or for that matter any course that would mean loading up the bike... and driving somewhere to then ride my bike. Although since I just bought the Old Turnpike last week I haven't found any local gravel yet... I feel confident I will.
But I already know the tires worked well in the local snow. And I don't have to worry about the road salt effects on the bikes frame either. I fully intend to... compared to the way I treat my other bikes... abuse the Old Turnpike. Gravel will mean chips and dings and damaged paint. Plus lots of dirt, dust, and potholes. But it also sounds like a lot of fun.
Stainless
I am a gravel rider in Northern Vermont where there are terrific hills and single tracks. I switched from years of carbon fiber to an otso Warican stainless. I will never go back. Ride quality is awesome, components are solid, and the bike is ideal for hardcore gravel rides
Sunshine
Liked 7,726 Times
All seriousness though, I came really close to buying an Otso Warakin Stainless frameset in 2019 when I was looking around for a new gravel frame. It was one of the final 3 I considered and I bet I would have been super happy with it, had I bought one. No idea how it is now, but at the time it was a pretty decent value compared to gravel framesets from other boutique stock production brands. The geometry was just slightly different from what I was wanting, but likely nothing I couldnt quickly adjust to and embrace.
Bicycho415
39
06-18-18 12:43 PM
RadioSuraksan
3
11-02-17 11:45 AM
FlashBazbo
12
10-14-15 09:23 AM
