Dura Ace (9100) & Ultegra (6800) cables identical?
Old 12-25-16, 09:26 AM
Noctilux.95
Bikes: Bianchi Oltre XR4 Celeste, De Rosa SK Pininfarina, Giant TCR SL, Giant Revolt Advanced Revolt 0 Gravel Bike, Trek Madone SLR, Cervelo R5 Disk
Quoted: 376 Post(s)
Liked 124 Times in 65 Posts
I'm upgrading my new bikes Ultegra 6800 groupset to Dura Ace 9100. Are cables identical? It would make installation easier if I could install all the components without pulling out all the cables. Thanks!
Noctilux.95 is offline
Old 12-25-16, 10:29 AM
ingo
Bikes: Cervelo S3, Ridley Helium, Cannondale Topstone Carbon, Giant Trance
Quoted: 43 Post(s)
Liked 51 Times in 24 Posts
I don't know how you can change the shifters without pulling the cables.
ingo is offline
Old 12-25-16, 12:22 PM
popeye
Bikes: S works Tarmac, Felt TK2 track
Quoted: 359 Post(s)
Liked 179 Times in 111 Posts
If you are an active rider you should replace shift cables yearly anyway. You really can't judge the new shifters with old cables.
popeye is offline
Old 12-25-16, 01:39 PM
Noctilux.95
Quoted: 376 Post(s)
The bike is new with Ultegra groupset
Old 12-25-16, 02:03 PM
evan326
Bikes: 2013 Cannondale Synapse 6 Tiagra + 2016 Cannondale CAAD 12 Dura Ace
Quoted: 231 Post(s)
It's fine.
You indeed can't change the shifters without new cables, but I just put a fd-9100 on my 105 bike no problem.
evan326 is offline
Old 12-25-16, 02:18 PM
joejack951
joejack951's Avatar
Bikes: 2016 Hong Fu FM-079-F, 1984 Trek 660, 2005 Iron Horse Warrior Expert, 2009 Pedal Force CX1, 2016 Islabikes Beinn 20 (son's)
Quoted: 1242 Post(s)
Liked 94 Times in 65 Posts
Hopefully whoever put on the cable ends on your bike did not go overboard crimping them or you may have a tough time reusing the cable. Just be really carefully feeding it back through the housing. If you catch a loose strand trying to insert the cable into the housing you can easily trash the cable (I won't use cables without all of the strands in place).
joejack951 is offline
Old 12-25-16, 02:20 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Gear or Brake ? or Brifter , that's Both..
Loosen the far end clamp, Pull the whole assembly out,
Put the new stuff on and make up all new cables & housing. , then If you want to swap back you have the whole set up together in a Bag..
fietsbob is offline
Old 12-25-16, 04:34 PM
popeye
Quoted: 359 Post(s)
Then carefully remove the terminal on the end or cut it off and seal the end with superglue. Remove the cable and reuse.
popeye is offline
Old 12-27-16, 12:02 PM
Jiggle
Jiggle's Avatar
Bikes: BH, Cervelo, Cube, Canyon
Quoted: 212 Post(s)
Liked 6 Times in 6 Posts
Do your budget a favor and replace them with standard $1.50 Shimano stainless cables when they're ready to be replaced. The polymer cables are a waste of money for what you get.
Jiggle is offline
Old 12-27-16, 12:10 PM
UnfilteredDregs
UnfilteredDregs's Avatar
Bikes: Salsa Ti Warbird- 2014/ November RAIL52s
Quoted: 67 Post(s)
FYI...Shimano cables have a polymer coating, supposedly for more friction free movement. It's proven not to be the case in my and quite a few others experience. It shreds up and binds, especially within the STI lever- and if it jams up good in there you can potentially ruin the lever. Go with straight up stainless cables.
...and installing new groupset? Trying to save the cables is being pennywise & pound foolish.
UnfilteredDregs is offline
Old 12-27-16, 12:15 PM
evan326
Quoted: 231 Post(s)
I'm going to use that one
evan326 is offline
Old 12-27-16, 12:26 PM
andr0id
andr0id's Avatar
Quoted: 1422 Post(s)
Liked 7 Times in 5 Posts
Yes, do that if you have no interest in these groups shifting as well as they are designed to.
andr0id is offline
Old 12-27-16, 12:31 PM
Doge
Doge's Avatar
Bikes: 1979 Raleigh Team 753
Quoted: 3375 Post(s)
Liked 371 Times in 253 Posts
Each individual R9150 component is 100% compatible with 9070 as well as 6870 Ultegra Di2.
Doge is offline
Old 12-27-16, 12:49 PM
deacon mark
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times in 121 Posts
Not my experience I put those polymer cables and housing on my Ultegra 6700 and it made a huge difference. I never miss a shift. The cables that route thru the top tube like my Wilier and wrap all under the bar tape bind easily. The polymer eliminated this and I always use jagwire die drawn cables and housing the b st I think under normal conditions.
deacon mark is offline
Old 12-27-16, 01:51 PM
Jiggle
Jiggle's Avatar
Quoted: 212 Post(s)
Works fine. No polymer shredded and binding in the shifter either.
Jiggle is offline
Old 12-27-16, 02:31 PM
UnfilteredDregs
Quoted: 67 Post(s)
Don't credit me...it's an extremely old idiom.
Old 12-27-16, 02:36 PM
UnfilteredDregs
Quoted: 67 Post(s)
Well...if you consider cable binding up in the STI lever as shifting well...
If you really want the group to shift well, toss the suckass Shimano housing and go with the likes of Nokon compressionless housing, which although finicky and requiring tedious & precise installation, results in significantly less friction.
Old 12-27-16, 04:54 PM
Doge
Doge's Avatar
I only use the Cordz now. The new steels cables go in a drawer.
Doge is offline
Old 12-27-16, 04:55 PM
Doge
Doge's Avatar
On 3rd year with Power Cordz. No reason to change if you leave them alone.
Doge is offline
Old 12-28-16, 02:17 PM
UnfilteredDregs
Quoted: 67 Post(s)
If I wasn't going Di2 next these would be the next choice. I've heard good things.
Old 12-28-16, 02:41 PM
Doge
Doge's Avatar
Cordz on all the Di2 rigs. Of course brakes, not shifters. On the MASI they went smaller DIA Cordz now and the brakes have sharp edges. I'm not 100% sure these won't cut. The FELT on the rear only. Venge is on year 3 with same set. Smooth as silk.
These 3 bikes are Di2.
Doge is offline
Old 12-28-16, 03:55 PM
UnfilteredDregs
Quoted: 67 Post(s)
Attachment 547212
Attachment 547213
Attachment 547214
Nice, I'm going hydro disc with the Di2...Gonna be a fun bike.
My "ultimate" "All-Road."
Going to do a 42/32 in the front, 10-42 xx1 rear... XTR Di2 derailleurs with Dura Ace 9100 Di2 Hydro/disc STI & brakes.
I call it a "Two By One." Meaning two different 1x drivetrains on one bike.
Essentially I have 1x mtb via the 32 and 1x CX via the 42.
Lauf Grit fork...
Old 12-28-16, 08:59 PM
Jiggle
Jiggle's Avatar
Quoted: 212 Post(s)
Wait, wait. Did we just agree on something?
Jiggle is offline
Old 12-30-16, 08:10 AM
UnfilteredDregs
Quoted: 67 Post(s)
roccobike
Road Cycling
10
11-26-17 07:45 PM
deacon mark
Road Cycling
19
05-06-15 06:05 AM
AbsoluteZ3RO
Road Cycling
22
05-12-14 05:35 PM
abstractform20
Road Cycling
16
09-11-11 09:36 AM
Lenaxia
Road Cycling
12
06-16-10 04:20 PM
