View Poll Results: Well, does one of these apply to you?
Do you clean a clean bike?
31
43.06%
Do you re-roll your used tubes?
30
41.67%
Do you cut your cables to be "even" on each side?
42
58.33%
Do you mount tires label-R centered on the valve?
54
75.00%
Do you wipe off ALL excess tubular cement?
18
25.00%
Do you wrap the same turns on each side?
21
29.17%
Do you always use valve caps?
39
54.17%
Do you always use valve stem nuts?
34
47.22%
Do you try to match the seat bag with the bike?
32
44.44%
Do you search for matching skewers?
51
70.83%
Multiple Choice Poll. Voters: 72. You may not vote on this poll
OK, How AR/OCD are you when it comes to bike/wrenching/parts?
Quoted: 378 Post(s)
Liked 1,410 Times
I know there are some less/more AR/OCD than I am.
.I know there are some less/more AR/OCD than I am.
..I know there are some less/more AR/OCD than I am.
...I know there are some less/more AR/OCD than I am.
Pics,
Descriptions,
Anecdotal Evidence,
Accepted.
Pics,
Descriptions,
Anecdotal Evidence,
Accepted.
all of the above, except i dont use valve stem nuts or caps. But for some reason i keep them all.
Semper fi
Semper fi
Bikes: '09 Trek 2.1 * '75 Sekine * 2010 Raleigh Talus 8.0 * '90 Giant Mtb * Raleigh M20 * Fuji Nevada mtb
I though all those things were normal, required activities. Just that I don't use tubular, so no cement. Oh and kinda a slob so I only clean my bike when it gets road dust on it, so didn't check that one.
FB4K - Every October we wrench on donated bikes. Every December, a few thousand kids get bikes for Christmas. For many, it is their first bike, ever. Every bike, new and used, was donated, built, cleaned and repaired. Check us out on FaceBook: FB4K.
Disclaimer: 99% of what I know about cycling I learned on BF. That would make, ummm, 1% experience. And a lot of posts.
Quoted: 1627 Post(s)
Liked 630 Times
My rule is the tire label goes drive-side (natch) but the tube's valve stem lined up with the PSI rating printed on the tire; not that I don't feel free to surpass it pretty much 100% of the time
All Campy All The Time
Bikes: Listed in my signature.
Quoted: 177 Post(s)
Liked 114 Times
Guilty on all counts, Your Honor!
Also replace tires, chain, cables, hoods, and bar tape before their time.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I do some of those things, some more than others. Valve caps are uncommon on my bikes, and I rarely clean a bike; a clean bike looks unloved. But I couldn't say always or never about anything.
www.rhmsaddles.com.
www.rhmsaddles.com.
Passista
Quoted: 871 Post(s)
Liked 723 Times
I have a front wheel, one of the first I built, where the hub label (engraved) reads the wrong way. The easiest way to fix it would be to reverse the rim label decal and skewer and reverse the wheel, but then the pull/push spokes won't match the rear wheel. I could disassemble and rebuild the wheel, but the spoke marks on the hub will be ugly.
I wouldn't go as far as saying I lose sleep over this, but I thought many times about it.
Quoted: 17 Post(s)
Liked 43 Times
I'm using all my used tubes.
If you wrap one too many turns with Tressostar, you'll likely come up short.
I don't use valve caps.
- Auchen
- Auchen
Guilty on many, if not most, counts. I don't use valve caps or nuts, but I seem to have a bunch of them laying about.
I also center the label on the driveside (depends on the tire). And then proceed to normally pump them up from the non-driveside. Go figure.
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
I don't even clean dirty bikes, though I think I will soon begin a perfunctory wipe down after a ride. I always use valve caps. I used to line up the tire label with the valve stem, and then decided that I don't care if I'm looked down upon because of not doing it.
Quoted: 3464 Post(s)
Liked 2,831 Times
I place the tire label on the LH side of the bike (off drive side). Reason being that in the USA right hand turns are more often sharper than left turns.
Bikes: Indeed!
Quoted: 1508 Post(s)
Liked 3,483 Times
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 33 Times
I started listing what I do to my bike that might be OCD, but the list just got longer and longer and longer...
Dang!, I guess I am OCD about my bike!!
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 339 Times
I'm not a cleaning OCD guy, but when it is time to repair/tuneup, I am extremely freaking thorough, I grease every bearing I can, and get those brakes working better than new.
Wheel routine:
Remove quick release, disassemble hub axle, clean bearing grease, regrease, grease some more, reassemble hub, check cones, adjust, check cones, adjust, check cones, steel wool rims, drink something, steel wool rims, check and steel wool spokes, drink something, complain about hand pain to no one/the dog, spray rims/spokes with simple green in the yard, wipe down with rag, clean hub body area, throw wheel on truing stand, pull out flip direction and throw wheel on truing stand, check to see if stand is still centered, pull out flip direction and throw wheel back into truing stand, spin, squeeze spokes, spin, squeeze spokes, adjust spoke tension (30 min), squeeze spokes, etc until wheel is true, spin, spin, spin, pull off stand, spin in hands, try to find skewers, find them, steel wool/clean chrome on skewers and skewer nuts, triflow on the skewer came, grease other side, place back through axle.
Next is putting on the tires but you get the gist...the funny part is, I'm not even close to being as bad as I once was either.
Wheel routine:
Spin Forest! Spin!
Bikes: I used to have many. And I Will again.
Quoted: 7 Post(s)
Liked 11 Times
I wire-wheel steel threads until all the gunk is gone and they shine like chrome.
Used to overhaul bearings by coating all mating cups, cones, races, spindles, with Dow-Corning molycote first, before greasing and adding the bearing balls with a magnetized probe.
Set brake pad clearances until both brake levers pull an identical distance that I deem my sweet spot.
Used Permatex aluminum anti-seize compound instead of good ol' grease.
Bikes: Treks (USA), Schwinn Paramount, Schwinn letour,Raleigh Team Professional, Gazelle GoldLine Racing, 2 Super Mondias, Carlton Professional.
Quoted: 78 Post(s)
Liked 30 Times
I'm guilty on all accounts, I even wax my bikes before I ride them.
I re-roll my tubes so they take up less space in my bag. I install my tires with the label on the right, over the valve to make it easier to find puncture debris. I generally use presta caps to keep crud out of the valves (I ride in the rain - I live in Oregon), and valve nuts to make it easier to put my Silca floor pump head on the valves. All that other stuff is just frou-frou.
SP
OC, OR
SP
OC, OR
Bicycle Repair Man !!!
What a bunch of weirdos.
Don't you know you are supposed to chase every thread on a bike frame when you service it ?
Bikes: Trek 4300, '84 Trek 400,'88 Trek, 85 Trek 720 560, 82 Motobecane Randonee, 75 Schwinn Collegiate, Schwinn Sierra, '84 Trek 890, 2001 Trek 5200 OCLV USPS, 99 Trek Y Foil
Liked 14 Times
Ah, Good! I knew I liked everyone here for some reason. I don't use tubulars so I don't need to clean even a little glue, if I had tubulars then I would spend way too much time making the glue perfect. For everything else, I'm guilty. But it is my hobby, I'm not as bad with everything else, the bikes do something to me. It's not my fault.
Robbie, I'll never have equal wraps of bar tape, never ever! I will clean a "clean" bike if it's overhaul time as it's so much easier to reach some spots when the frame is gutted. No tubies.
Two items you didn't list are aligning the hub's designation to the valve stem (not all of mine are) and rim labels readable from the RHS.
Brad
Brad
Wood
Bikes: Raleigh Sports: hers. Vianelli Professional & Bridgestone 300: mine
Quoted: 8 Post(s)
Liked 12 Times
Hardly any of those things up there, but I oil everything, a lot.
Quoted: 659 Post(s)
Liked 595 Times
Ordinary
Cycling
Disposition
Cycling
Disposition
Quoted: 2588 Post(s)
Liked 4,827 Times
I had to say yes to everything but the matching bar wrap question. But I've got far too many other examples of OCD when it comes to bikes, not to mention other areas of my life
FWIW, OCD is looked down upon as a bad thing, but I go the other way: it's those without structure and order that are missing out!
DD
DD
