A question about bibs for tall guys
Old 05-24-24, 04:04 PM
wayold
Bikes: Tallboy, Domane, old 90s MTB beater/grocery-getter, and a new franken-gravel experiment based on a Sirrus x 5.0.
Liked 49 Times in 36 Posts
I ride primarily in cycling shorts. I've tried bibs several times, but always find that either the straps are too tight (if I get my usual size L or XL) or the seat and thigh are a bit loose if I go with a XL or XXL. I'm OK with the latter and have some XL bibs from 100% and XXL from Castelli that I wear sometimes, but I prefer the more compressive fit around the legs I get with a good pair of shorts. I've found some brands that sell bibs for 'big and tall' riders, but these seem to just have a longer inseam relative to the standard cut rather than longer straps I want. What do you tall riders wear? I would have thought that tall and skinny isn't that unusual a build for cyclists.
wayold is offline
Old 05-24-24, 04:18 PM
Liked 16,201 Times in 7,603 Posts
How tall are you?
Old 05-24-24, 04:22 PM
tomato coupe
Liked 7,825 Times in 3,124 Posts
I like Castelli bibs, but I find the straps to be on the short side when compared to some other brands.
tomato coupe is offline
Old 05-24-24, 04:38 PM
CAT7RDR
Liked 1,990 Times in 958 Posts
I tried the Pactimo Summit 12 hour bibshorts in the XL Long for more compression further down my quads and these deliver.
I am 6'2" 210 lbs and the fit is perfect for me.
They are also on sale now.
https://www.pactimo.com/products/men...42425204834483
CAT7RDR is offline
Old 05-24-24, 05:14 PM
wayold
Originally Posted by indyfabz
How tall are you?
I'm really not that tall or that skinny. Officially 6'1", but with short legs, so my torso is similar to that of someone 6'2" - 6'3". I weigh 180, which again, isn't that light for a cyclist of my height. Nevertheless the various bibs I've tried all have the fit issues I've described (too short in the strap or too wide in the hip/thigh). I suspect part of the problem is that bibs are designed for an aggressive road riding posture. I ride somewhat more head-up than most which probably puts more pressure on the straps and exaggerates my problems with fit.
wayold is offline
Old 05-24-24, 05:49 PM
shelbyfv
Expired Member
shelbyfv's Avatar
Liked 5,940 Times in 2,994 Posts
What don't you like about your waist shorts?
shelbyfv is offline
Old 05-24-24, 06:08 PM
Steve B.
Liked 2,207 Times in 1,252 Posts
Don’t get Pearl Izumi. They went cheap and eliminated the seamed edging on the straps, now it’s just thin lycra which is difficult to lay flat. I’ve purchased my last pair,
Steve B. is online now
Old 05-24-24, 06:20 PM
jaxgtr
jaxgtr's Avatar
Liked 1,897 Times in 1,080 Posts
Have you check into the Black Bibs? They have bibs with longer straps in all three versions
https://theblackbibs.com/collections...houlder-straps
Brian | 2023 Trek Domane SLR 7 AXS | 2023 Trek CheckPoint SL 7 AXS | 2016 Trek Emonda ALR | 2022 Trek FX Sport 5
Originally Posted by AEO
you should learn to embrace change, and mock it's failings every step of the way.
jaxgtr is offline
Likes For jaxgtr:
Old 05-24-24, 06:25 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Liked 1,565 Times in 1,028 Posts
I have some of these, however from ~8 years ago.. great bibs. Came across this listing -- awesome price if the L fits you. FWIW, I'm 6'2", 185lbs and wear a L. Similar to you, out of my height, my inseam is only a 33"
https://bikecloset.com/product/sugoi...-shorts-black/
Sy Reene is offline
Old 05-24-24, 07:51 PM
GGDaddy
Liked 8 Times in 8 Posts
Have you tried Assos? Pricey but worth it IMO. I'm 6'4" with longer legs (36" inseam) and relatively shorter torso, and they fit perfectly on me (including the strap length). Good luck!
GGDaddy is offline
Old 05-24-24, 08:07 PM
rsbob
Grupetto Bob
rsbob's Avatar
Bikes: Bikey McBike Face
Liked 6,126 Times in 3,130 Posts
I am HWP with a long torso at 6’1”, size Medium. The straps on the bibs I have bought are so short, they just about give me a chamois wedgie. I have a pair of Black Bibs and the chamois doesn’t work for me.
Road 🚴🏾‍♂️ & Mountain 🚵🏾‍♂️
rsbob is offline
Old 05-24-24, 09:12 PM
Troul
Troul's Avatar
Liked 3,209 Times in 2,039 Posts
it's either the legs are too tight, the front part doesn't go low enough, or both. Hard to find a just right fit in all black with thin or no padding.
-YMMV
Troul is offline
Old 05-24-24, 09:17 PM
rsbob
Grupetto Bob
rsbob's Avatar
Sounds like the story of Goldie Locks and the Three Beers Bears
rsbob is offline
Likes For rsbob:
Old 05-24-24, 09:24 PM
Troul
Troul's Avatar
the best pair are the ones you can fall asleep in... so they say.
-YMMV
Troul is offline
Likes For Troul:
Old 05-24-24, 09:27 PM
rsbob
Grupetto Bob
rsbob's Avatar
Originally Posted by troul
the best pair are the ones you can fall asleep in... So they say.
lmao!
rsbob is offline
Old 05-24-24, 09:47 PM
jaxgtr
jaxgtr's Avatar
Yea I tried a pair of the middle range model and I was not a fan of their chamois, but the ultimate version I found very comfortable. Sort of hit an miss. I like the Adventure bibs since they have the leg pockets and pockets on the upper back, but I also use the short inseam models as well. The standard leg inseam is just a bit long for me.
jaxgtr is offline
Likes For jaxgtr:
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Your Privacy Choices -
