Zeus socket wrench
Zeus socket wrench
A shot in the dark. Does anyone have a Zeus Socket wrench out there? If so, I have a kidney I don't need anymore. My non drive side crank has developed an irritiating clicking noise which is the result of it being a little stripped where the pedal goes in. It has to be a thin walled socket wrench made for Zeus 16mm crank bolts (the Park tool is for Stronglight cranks and doesn't work).
Click... click.. click... I will do anything!!!!!
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,062 Times
I just bought a cheap 16mm socket and ground it down on the outside until it fit. Might also work with a 5/8" socket, if you're lucky. If you're really jammed up, I can loan you mine by mail (time consuming, tho).
Bicycle Adventurer
I'm not sure if I understand the problem, but it sounds to me like if anything is clicking and you need a special part (the stronglight special part is a crank puller, I think), it's probably because the crank is loose.
I don't see how the pedals give a clicking sound, it's probably the crank loosening itself to death on the square spindle.
It's happened to me twice. "Creak, creak, creak."
I have a stuck pair of zeus cranks too,
'Zeus 16mm crank arm bolt wrench - Rare!' $27,99 - cafe de velo (our of stock)
after I saw that I have been planning to make one out of an old 16mm socket
When you get the bolts out, you can fit any 14 or 15 mm headed crank bolts, the threads are standard (both crank bolts and extractor).
Sorry, I don't loan tools, particularly halfway round the world.
Plastids
Check with Bicycle Classics https://stores.ebay.com/bicycleclassi...e-bicyclestore.
He seems to have some Zeus tools now and again.
But I agree with other posters. How will removing the crank arm bolt fix a click in the pedal threads?
As to how removing the crank will fix the problem - that's easy I'm going to replace the whole goddamn thing with a campy record crank. Also just in case the makers of my 1967 Zeus crankset are looking on, beautiful bike, but obscure bolts that require obscure special tools are a stupid idea, and may the ghost of Tullio Campagnolo piss on your grave. Or failling that if you're still alive may you hear click-click-click every time you try to go to sleep.
Liked 1,062 Times
yeah, that "exclusive part/tool" idea was a bad thing, but while you're p*ssing on graves, save a big one for both Shimano (especially) and Campy, they did this too. I still love the thrill of having to find (or make) a 7mm Allen wrench when I come across that one, or the weird fractional size Campy used (3.5mm?).
As LWaB points out, you can swap in a standard 15 or 14mm crank bolt, as the threading is standard, and AFAIK you use the standard extractor tool.
Quoted: 113 Post(s)
Liked 16 Times
I know doing this on the net is impossible but in my experience a real "Click" is more likely to be pedals or chainring bolts, and if it's more of a "Creak" then it could be loose crank bolts.
1 Super Record bike, 1 Nuovo Record bike, 1 Pista, 1 Road, 1 Cyclocross/Allrounder, 1 MTB, 1 Touring, 1 Fixed gear
Bikes: 3Rensho SuperRecord Export, Bridgestones MB1 RB1 XO2, Colnago Super, Medici GranTurismo, Schwinn Paramount, Olmo Competition, Raleigh Portage, Miyata 1000, Stumpjumper, Lotus Competition, Nishiki Maxima, Panasonic DX6000, Zeus Criterium
Quoted: 30 Post(s)
Liked 82 Times
the tool prettyshady posted is the right one. i recently got a 70s zeus on CL and the tool came included with the bike. i've successfully used it to pull the cranks and service the BB. i've seen that tool on ebay a couple times recently...
Quoted: 3811 Post(s)
Liked 6,707 Times
Neal
Likes For devinfan:
Quoted: 30 Post(s)
Liked 82 Times
there's one on ebay right now...
Forget ebay! You just need a 16mm head and a sander mixed with equal parts anger and patience for about 10 minutes.
Likes For devinfan:
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Bikes: 1988 Ibis tandem, Bridgestone RB-2, 1950s Invicta 3-speed
Keep your kidney and buy a thin walled socket. That is what I did to remove some Zeus crank bolts. Someone was using them as anti-theft devices on a Nuovo Record crankset.
If I am not mistaken, I mail ordered a Sealy AK6557 socket from Amazon that worked. More clever folks will be able to find one that costs less.
Quoted: 4512 Post(s)
Liked 6,385 Times
Also many here including myself just spin one down on the bench grinder, use an extension to hold it and spin evenly and lightly against the spinning wheel until it is thin enough to use.
No need to order and wait if you can get the job done in house with tools on hand.
Besides, why would you want to miss a chance to buy a new tool?
Liked 6,385 Times
I understand that a thin walled socket is likely to be tempered and stronger than one that you shave down with a grinder. If you grind one down it may lose any temper that it had. This will make it more brittle and prone to cracking than it would otherwise be.
Only if you don't have the experience and expertise to tell the socket won't work. I've been a mech/tech all my life, if for some reason I don't have a tool that I need and can modify one I do have to get the job done at the time, then I do.
Never had a failure and even if it did this would be an expendable example if need be. As long as it gets the job at hand done, you're golden. If I deemed it necessary to grind on a Snap-on socket then that's what would happen.
I do have about 75K worth of tools and still don't always have what I need so as already stated, if I have to grind on one to get the job done, I will.
Likes For merziac:
Laser tools thin wall plug socket set
https://www.lasertools.co.uk/Product...inch-drive-3pc
the 16mm (O.D 20.82mm) fits my Stronglight 106/7 with a 16mm Zeus bolt.
Likes For esasjl:
Bikes: 1972 Gitane Tour de France
Quoted: 7 Post(s)
Tried that, too
the park wrench doesn’t fit, will try the grinding or switch to 15mm. It’s a 1979 Zeus Supercronos
Likes For Schweinhund:
Old fart
Liked 3,400 Times
Sounds crazy but a T-45 torx bit will fit a 7mm Allen bolt. I’ve done this several times.
Semper fi
Semper fi
