Advantages of Different Seatstay Designs on CF Road Race Bikes?
Quoted: 4494 Post(s)
Liked 4,966 Times
Likes For PeteHski:
Quoted: 4284 Post(s)
Liked 1,377 Times
The Y-foil has a rear triangle (from the photo course if found).
The PX5 has much beefier chain stays.
I’m not sure if the last two were intended to be particularly “comfortable”. I’m not sure if the frames were particularly light. That bikes like this aren’t really made any more suggests they weren’t better than the standard frame that has stays.
So, it seems you don’t need seat stays but it appears there might be compromises needed to remove them.
Given the variety of stay arrangements, it doesn’t seem to matter much where they are placed or their shape. (But manufacturers will certainly still say what they do is the best. Until they change it.) That disc brakes allowed more freedom to move them about makes sense. Lower might be more aerodynamic but, maybe, not by much.
Thread Killer
Quoted: 3195 Post(s)
Liked 1,727 Times
The Trimble has a much beefier “main tube”.
Anyway though, the reason those roads designs did not persist is because they were not UCI compliant, not because they weren't better, which they almost certainly were from a variety of perspectives.
Likes For chaadster:
OM boy
Bikes: a bunch
Quoted: 539 Post(s)
Liked 671 Times
Whose to say whether those design directions might have developed into more or less aero forms in comparison to today's offerings...
However, Triathlon not falling under UCI, meant that they continued to use bikes with these designs, and some can be seen in competition today. Certainly Bike sponsorship will be a big restriction of what you see under the top level Triathletes...
It'll be interesting to see how UCI reacts when REAL electronic shifting comes about - electronic internal hub systems with settable gear ratios, and prolly running belt drives, rather than the 800 lb gorilla of unnecessary weight - the bike chain. There's no reason why an internal gear change system can't be located in the crank/BB location and the rear be a single 'cog'... 'Direct' drive? Possible, depending on material engineering! Motos have had direct drive for many decades,, because weight is much less of a consideration.
At the moment 'Electronic shifting' is pretty much like the electric knife...
Ride On
Yuri - not sure I'll still be breathing when the really new and juicy stuff hits the road...
Liked 4,966 Times
Ride On
climber has-been
Quoted: 3511 Post(s)
Liked 3,653 Times
Liked 4,966 Times
I agree, but I do find them a bit of an inconvenience. Belt drives are efficient too, just need the gearing range etc. I'm surprised there are not more options. We had a couple of belt drive kids bikes and they were great for maintenance.
Quoted: 480 Post(s)
Liked 277 Times
Don't discount one of the primary, if not, the primary drivers in attracting customers in this category – aesthetics. I'll admit the dropped seat stays simply look better. Part of it may be that they make the saddle look higher – and that makes it look like a pro's bike and that make it makes it look like… yeah - aesthetics.
OM boy
Bikes: a bunch
Quoted: 539 Post(s)
Liked 671 Times
Just from the 'heft' test, bike weight seems about the same as a Mid-level CF bike. He's solid middle of pack rider and has no issues on the climbs...
The bike is wonderfully silent and he always seems to have the 'right' gear for the occasion ... I'll have to take a pic and post, when we're both on the next ride...
Between Ski season (WInter lasts until Mid April in the SIerra and Mammoth stays open usually to well past May- last year End of July) and now the Best times to hike in our Back Country, I've been missing the Sunday Rides... The Back Country will soon turn into an Oven, and Sunday Coastal Rides will seem like heaven (which they are...).
Ride On
Yuri
Likes For cyclezen:
Liked 4,966 Times
Likes For PeteHski:
Liked 4,966 Times
There's a rider in our Sunday group, aussie, who had a custom TI frame made, built up the rest himself, using an IGH and belt drive, otherwise upper level road components...
Ride On
Yuri
Ride On
Yuri
Likes For PeteHski:
Having read a fair amount of reviews (and presuming those authors have read the marketing bumpfs), it sounds like the modern frame double diamond design is driven more by aerodynamics than comfort:
- Flat top tubes present the smallest forward aspect relative to any sloping top tube design
- Dropped seatstays put the seatstay/seat tube joint right in front of the top of the tire, where the air is already being spoiled anyway, rather than higher up, which adds to its own drag
- Standard for these days D-shaped seat and down tubes
Comfort is thrown in by way of wide tires, flexy seatposts, and odd suspension designs (ahem, Roubaix and Domane). The ‘default’ race design these days (as outlined above) doesn’t really provide for inherent comfort due to the lower amount of exposed post (flat top tube) and tight rear triangle (dropped stays). An argument could be made that the seat tube itself could be made to flex at the seat stay joint, but any flex there would also impact the top tube and head tube joint as the seat tube bends and effectively shortens that side of the triangle.
So short version… first conclusion: dropped seat stays and flat top tubes are for aero, not comfort.
Of course, regardless of whether your stays are high up or low down, this all happens behind a rider’s thighs and feet, which cause plenty of airflow disruption of their own anyway. Manufacturers are trying to tell us that an extra three inches of half-inch wide seat stay will provide meaningfully more drag, even though it’s primarily in the wash of my 7” diameter thighs and size 10 shoes as they go round and round? Sure, when the absolute most marginal race gains are to be considered, the tiniest fraction of a watt and handful of grams that a shorter stay provides could prove beneficial - or at least, matching what the big boys do is good for optics, both at the start line and on the showroom floor. After all, when Specialized shows up with its new Tarmac, Bianchi and BMC can’t be seen putting "last year’s” technology out there.
Short version, conclusion 2: Marketing wants to make sure our new bike doesn’t look old next to the other guy’s new bike
Liked 4,966 Times
