1979 California Cruiser or Spitfire?
Bikes: Schwinn Cruiser Diamondback Mountain Specialized ALe Road
Greetings
I am restoring a Lightweight Cruiser style Schwinn SN HQ519685. I believe it is a California Cruiser due to the chain guard having a a upswept tail on the End of it.
is there a way to tell model by the serial Number? HQ designates 1979. The crank has 2 numbers SA 1873 and 127 128. I am also looking for a Head Badge the holes on the frame Neck are 3 1/2 inches apart. is this a 1088 Head badge?
Thanks for any help
Thanks for any help
Quoted: 365 Post(s)
Liked 419 Times
I prefer the GT6, personally.
(My Dad had one, I believe it was a 1973 MkIII. I got to drive it a couple of times as a teenager, what a blast - even better than the TR7, IMHO. Unfortunately, Dad didn't really like working on cars, which is less than ideal if you're an owner of a Triumph.)
See if this helps
https://bikehistory.org/
Quoted: 809 Post(s)
Liked 1,024 Times
@BouleyRE I went though the 1979 catalog and only found the Spitfire, Typhoon or Heavy Duti for cantilever style frames that year. All three of these models have straight chainguards in the catalog.
1979 Schwinn Catalog
It seems that the California Cruiser was a 1976 or 1977 model that had a trademark issue so they changed the name to Spitfire.
The silkscreen on these chainguards fades over time and usage. Can you make out a shadow from the original graphic? Based on the story so far it could be one of the following:
- This could be an earlier chainguard that was bolted on to your '79 bike
- Schwinn still had some old chainguards in 1979
- It is an earlier year bike and the chainguard is original
It looks like in 1978 Schwinn went to the straight chainguard, at least on the Typhoon.
I am assuming that you put your full serial number into the Schwinn History lookup and it told you that the bike was manufactured in 1979.
Bike History Serial Number Lookup
Quoted: 604 Post(s)
Liked 1,064 Times
I prefer just about any 70s British sports car.
Tim
Tim
Quoted: 645 Post(s)
Liked 797 Times
Likes For Litespud:
Quoted: 645 Post(s)
Liked 797 Times
Spitfires only ever had a four-cylinder, although a few had twin carbs. The only Triumph coupes/roadsters that came with 6s were the GT6 (2 liter) the TR5/250/6 (2.5 liter)
Thank you for your input
I think I may have a schwinn with replacement parts. My Bike has the star Sprocket shape and not the clover pattern. (in the catalog 79 spitfire has clover pattern)
searched the SN and it came up August 79. Chainguard with tailfin could be the inconsistency in parts assembly? same with sprocket. No way to tell which Model by serial number?
No help with decal on chainguard, Long gone. do the crank numbers tell anything? Also is the 2 1/2 " head badge unique?
Looking to put the correct decals back on but could be impossible to know which bike i have?.
Thanks Again.
Thanks Again.
Quoted: 1610 Post(s)
Liked 2,591 Times
Sounds like a Typhoon. Which kind of handle bars does it have?
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
It was rounded like yours, the hood opened the wrong way, and the front suspension looked similar to what I imagine a 60’s F1 car suspension would look like.
Bikes: yes, i have one
Quoted: 1138 Post(s)
Liked 1,182 Times
Sorry for hijacking this thread. I love my Spitfire, it is such a fun car to drive. And yes, there always seems to be something to be done on it.
Quoted: 809 Post(s)
Liked 1,024 Times
Interesting piece of information @BouleyRE . The Spitfire had the four leaf clover chainring and the Typhoon had the "Mag' chainring. Here is a link to a Schwinn Mag chainring:
Bicycle Heaven Mag Chainring
As @curbtender mentioned you may have a Typhoon. By the way, thanks for the video. This shows a restored Typhoon including the correct headbadge. The original seat would have been a blue vinyl seat with the "S" painted on it. The replacement seat that grandma put on was more comfortable and not an uncommon change. The crank on that bike had been changed though. That is not a Schwinn Ashtabula crank.
Your crank has a date code on it that looks like it is from the 18th month of 1973. So, 1979 for the frame and 1973 for the crank. It was and still common to swap parts on these bike since they are easily interchangeable.
One good thing about the headbadge is that you can find one on eBay. You would prefer one that does NOT have numbers stamped into it.
From the 1979 Schwinn catalog the Spitfire came in Cardinal Red, Sky Blue and Black. The Typhoon only came in Sky Blue. And the Heavy-Duti only (New York Taxi Cab) Yellow. Did you say what color your bike is? Do you think it is the original paint?
Try posting a picture or many pictures of your bike to your Bike Forum gallery. Perhaps someone can get the picture and post it here. Or just respond 5 times a day and in two days you'll be up to the level needed to post your own pictures.
Quoted: 645 Post(s)
Liked 797 Times
it’s possible - I’ve seen Spitfires retrofitted with GT6 engines. All of these cars’ hoods hinged at the front, and opening the Spitfire/GT6 hood exposed the front end workings
Likes For Litespud:
