Well, THAT Was Unexpected!!!
Klaatu..Verata..Necktie?
Quoted: 10425 Post(s)
Liked 11,899 Times
So, after a farcical evening trying to finally get to riding the Zwift Academy Road Finish Line Ride, I finally got going in the 9 PM ride. Took it easy the first 2.5 miles, killed myself up the Titans Grove Reverse KOM, bettering my previous time by >2 seconds. Road easy toward the next segment, a 0.22 mile long sprint that was about 8 miles away 5 miles later, I feel the tire slipping on the drum on the trainer. "That's weird", I think. It keeps getting worse, so I stop, get off the bike, and check the rear tire - squishy. Over the next 2 minutes, it goes completely flat.
That's right. I FLATTED ON AN INDOOR TRAINER!!!!
I really didn't expect that.
Turns out that a patch I put on a tube last December, and then rode all summer, probably at least 1000 miles, suddenly decided it had done enough and started leaking. I'm going to have to rethink whether to used patched tubes, if they can hold together through over 1000 miles of riding and then give out rather suddenly. If this had happened at the wrong point on a descent, I might have crashed.
Likes For genejockey:
Randomhead
Liked 3,698 Times
I have never had a patch come loose, was it a Rema, or one of the no-glue types?
When I first started riding gravel I had some tubes with a large number of patches. I had 20 flats in one year, and when the tire goes flat there can be multiple holes in the tube before stopping. Tubeless put a stop to that, I hate flats.
Bikes: yes, i have one
Quoted: 1138 Post(s)
Liked 1,182 Times
its not a first. back before i got my wheel off trainer i used to go to a bike shop and use a CompuTrainer twice a week. i learned that a few flats had occured on them due to excessive heating of the rear tire. they did get quite hot.
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
Trainer flats happened sort of regular for me. On average ~2 per year, every year. TBH, it's why I moved to a direct drive trainer.
I don't know if I'm above average in strength or not, but it always seemed to happen after sustained hard efforts. Sometimes the tire, sometimes the tube. I always attributed it to heat accumulation...I know my Elite Travel Trac fluid trainer would get so hot it couldn't be touched after a vO2 max workout. So it stands to reason heat would be a factor.
Car dependency is a tax.
Quoted: 821 Post(s)
Liked 1,655 Times
I absolutely detest the no glue patches. They are (barely) useful to get you home if you flat, at which point you put in a new tube. I've gone back to the glued patch kits. Properly installed, I've never had one of those fail. Some out lasted the tire.
Likes For Bald Paul:
Quoted: 313 Post(s)
Liked 682 Times
It's hard to beat the old style glue-on patches. Those repairs are stronger than the rest of the tube!
I've had a flat or two on the trainer in the past (pre-direct-drive days) mostly caused by grit slowly working it's way through the tyre as I was using it indoors and outdoors. Never had a patch fail on me though.
Yea, a properly installed patch lasts forever. A poorly installed patch OTOH will fail and usually quickly.
I used to patch on the road but now just carry 2 spares with me and patch at home in batches. I've bought a can of Rema cement and a box of patches, no more patch kits for me.
Were you able finish the ride and get credit for ZA?
Liked 11,899 Times
Not that night. That flat was just the last of a series of misadventures.
But I re-did the ride today.
Direct drive?
Have you looked at a direct drive trainer. Obviously they’re not cheap, just wondering whether it’s something you’ve considered. Definitely solves the flat problem - I have no rear wheel and my front is probably at 5 psi.
Quoted: 590 Post(s)
Liked 445 Times
Flats happen if you don't "over inflate" your rear to 10-15 psi over your typical street psi. This is because the tire (at road psi) deforms more when on the roller, causing more friction to the tube (and/or patches), so the extra psi reduces the deformation.
Liked 11,899 Times
Yeah, I did. But I can't justify the expense, since the Kick'r Snap I have works well enough.
Liked 1,182 Times
if you get out of the saddle to do hard efforts i would not be surprised if you get a pinch flat, 5 psi is like nothing.
Randomhead
Liked 3,698 Times
I am sometimes too lazy to pump up my front tire. I'm surprised I haven't gotten a pinch flat
Likes For unterhausen:
