Threadlock versus anti-seize, when to use?
Bike addict, dreamer
So which parts and bolts on a bike will benefit from threadlock and which will benefit from anti-seize compound?
I see threadlock used on all disc brake bolts: the ones used to mount the adapter to the frame, those used to attach the caliper to the adapter and those used to attach the rotor to the hub.
What about other bolts and parts? Rack mounting bolts, brake/shifter lever bolts, stem/handlebar bolts, etc.?
Thanks.
Adam
Thanks.
Adam
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
https://www.bikeforums.net/showthread...ease+antiseize
https://www.bikeforums.net/showthread.php?t=567518
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
Thanks!
There is a link in one of those posts to Park web page with some good info. So I think I'll use some blue Loctite on my rack bolts.
If you have a fastener which you fear might loosen, then threadlock (blue locktite) can be used. I'm not sure what that might be. If you have any SS screws being threaded into SS nuts, then anti-seize would be called for. Or, if you have some threaded fixtures which get real hot. Otherwise just use some grease to help avoid corrosion.
What about pedals? Does it make sense to use threadlocker?
Thanks!
A.
I don't think it's important to use a thread lock on pedal bolts. Grease them to forestall corrosion, but they don't loosen on their own, in my experience. I think the natural effect would be for them to tighten in use rather than loosen.
Bikes: Peugeot Hybrid, Minelli Hybrid
Dont use threadlock on pedals because the pedaling motion tends to tighten them, but use anti-seize if you ever intend to remove the pedals. I also use anti-seize on seatposts and seatpost bolts.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
+1 Threadlock on pedals is a bad idea. I use anti sieze on bottom bracket threads, on freewheel hub threads and on bottle cage bolt threads. Everything else gets grease.
Quoted: 3376 Post(s)
Liked 5,522 Times
What I do:
* Anti-seize: BB, chainring bolts, pedals.
* Blue Loctite: Everything else.
Although I think wrk101 may be right about bottle cage bolts.
I can't remember ever having one loosen up on its own, but I have nearly destroyed a couple trying to loosen them.
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
Probably one of the most incorrect posts i've ever seen in all of bikeforums. You must go through a lot of loctite. Even on interfaces that require grease instead.
Liked 5,522 Times
Loctite on fasteners that are *not* supposed to move.
just another gosling
Quoted: 3890 Post(s)
Liked 1,939 Times
Loctite on jockey wheel bolts. That's one of those situations where you may not be able to ride home, especially if there is grass in the ditch, though you can always go SS.
I use anti-seize on stem bolts, etc. Never saw one loosen. Also on nipples. Never had one loosen. Important on bottle cage bolts, pedals, etc.
Bikes: 1983 Fuji Touring Series IV, Masi Volumetrica 3VC
Never use Loctite on anything that is used to retain a plastic part. As Loctite cures, it gives off ammonia gas, which can cause some plastics (polycarbonate, especially) to become quite brittle. They will stress-crack within days.
Likes For the_tool_man:
