Schwinn Passage
Quoted: 152 Post(s)
Liked 237 Times
I would consider the Schwinn Passage a kissin' cousin of the Schwinn Voyager.
From this post on BF a brief summary:
Details:
Details:
- The Passage was only made one year, 1986, and both frames were made using double-butted Columbus Tenax tubes.
- The Passage has frame angles of 72.5 ht and 72.5 st vs Voyageur's 72 ht and 74 st
- The Passage fork doesn't have low-rider mounts, and the catalog claims it's hi-ten vs Voyageur's crmo fork
- Catalog Passage weight: 25 with a rear rack
- Catalog Voyageur weight: 24 without a rear rack
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Agree, I think the Voyageur and in particular, the Voyageur S/P were fine touring machines. IMO. Schwinn hit their touring peak with the 1983 SP. Came with stock front and rear racks, Tange Champion DB frame.
1984 and 1985 Voyageur SP were fine bikes too, had a Columbus SL frame, but lost the factory racks.
Quoted: 753 Post(s)
Liked 737 Times
I think you need to identify specific vintage of Trek 520 you want to compare the Passage with. I think there were at least 3 "different" Trek 520's during the 80's.
Bikes: Trek 400 Elance, Losa Winner, 1994 Schwinn Paramount, Specialized Tarmac Pro, Miele SLX, Ibis Ripley, Colnago Oval CX, 84 Masi GC, 1986 Schwinn Voyageur, 1988 Schwinn Tempo, 1998 Schwinn Peloton, 1991 Paramount Ser3
Quoted: 150 Post(s)
Liked 90 Times
I think for some years, early to mid 80s, Panasonic Pro Touring = Schwinn Voyageur, Panasonic Touring Deluxe = Schwinn Passage.
Trek’s 720 & 520 (‘83-84) remind me of Voyageur & Passage respectively. Trek had the 620 which at a glance reminds me of Super Le Tour.
Quoted: 332 Post(s)
Liked 747 Times
There was also a later version of the Passage, which was more of a road than touring bike. Must not have been made for long as I’ve only ever seen one or two.
pic stolen from the internet
Quoted: 753 Post(s)
Liked 737 Times
I've got a beat up 86 Passage, and I'm hoping that its Columbus tubing will make it a bit sportier than heavy tourer.
Bikes: 1984 Fuji Club, Suntour ARX; 2013 Lynskey Peloton, mostly 105 with Ultegra rear derailleur, Enve 2.0 fork; 2020 Masi Giramondo 700c, full Deore with TRP dual piston mech disk brakes
Quoted: 324 Post(s)
Liked 81 Times
in 85 Schwinn also went from DiaComp 960 to 980 brakes, the 980 were cold forged aluminum and thus a lot less flex then the older 960, while weight a bit less; the hubs were upgraded in 85 as was the headset; plus other upgrades.
The 83 Voyageur SP had loosely more in common with 85 Schwinn Le Tour Luxe than either the 85 Voyageur SP or the Voyageur; and the LeTour Luxe came with rear racks.
Likes For greatscott:
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
I think of it in terms of the basic hierarchy-
720 = Voyageur SP - top of the line
620 = Voyageur - 2nd from top
520 = Le Tour Luxe 3rd from top
But by 1986, the 620 and 720 were gone and the 520 was not a loaded tourer as well as Schwinn cancelled the Voyageur SP leaving just the Voyageur.
So basically, you had the Voyageur as top of the line and Passage as the 2nd from top.
Looking at the specs for the Passage- it's pretty close to putting the components of an 85 620 on an 85 Le Tour Luxe.
Despite the HiTen stays and fork, I'd consider it more 620 than 520.
Commence to jigglin’ huh?!?!
