What do I need to get?
Bikes: 1983 Trek 500
I just bought a 1984ish Trek 500. It has a 12 speed Sun Tour package and the stock 27" wheels. I use to ride something very similar and love this bike. I would like to upgrade to a smoother shifting system and some better wheels. I am afraid cost would kill me. What kind of options might I have? I understand bikes pretty well not quite sure the best avenue to go with this. I want to do some longer rides. I am not a small guy, 5-11, 220 or so.
Quoted: 2026 Post(s)
Liked 1,096 Times
The cost of upgrading that bike to current index shifting will be far more than you imagine. First it has 126 mm rear dropout spacing so you will be limited to 7-speeds or will have to spread the frame to take a modern 130 mm spaced 8/9/10-speed rear wheel. Second, none of your current components will work with indexing and you will need new shifters, new front and rear derailleurs, cassette, chain, possibly a new crank and a new rear wheel.
Frankly, unless you are absolutely in love with that bike you would be far ahead to put the upgrade money to a new or at least much newer bike and ride the Trek as it is.
Edit: In the interest of full disclosure, I will admit that I once did update and upgrade an 1983 Trek 400 to 8-speed index shifting and more modern brakes, 700c wheels, etc. However, I had almost all of the needed parts in my collection as retired items from other bikes and did all of the work myself. My actual out-of-pocket cost was very low. I would not have considered that project if I had to source new components.
Thanks! I love it! One owner, looks almost brand new. What about changing to thumb shifters? I really don't need anything to fancy. Racing days are long gone. 56 years old and just want to ride around town. Of course the occasional need for speed too..... The wheels really don't seem too bad. Heard they were garbage. I wouldn't mind staying with the 6 speed cassette. Thanks so much HillRider.
You Know!? For Kids!
I have a mid 80s Falcon of England that was running an old Sach Huret drive train. Bought a used 105 groupset and some used Mavic Open wheels with Ultegra hubs from another forum member and rebuilt the bike with that. Wheel fit into the frame pretty easily acutally, but your results may vary. You might try to borrow a modern wheel off of another bike to see how hard it would be to fit. Also, going from 27 to 700c, you might need long reach brakes
Are you a registered member? Why not? Click here to register. It's free and only takes 27 seconds! Help out the forums, abide by our community guidelines.
Bikes: 20" Folder, Road Bike
Hi,
If it ain't bust dont fix it. A new chain and possibly a new hyperglide
6 speed rear freewheel. I don't know enough about bike history to
say what indexed downtube shifter you could try, and whether or
not it would work with the rear derailleur, but the right old parts
to upgrade it should not be expensive.
Cannot see any changes for the front shifting being useful.
Don't change the wheels. Check and tweak spoke tensions.
Nice tyres if needed. Good brake pads on the front if needed.
rgds, sreten.
rgds, sreten.
Bring the bike in for a complete service .. at your LBS
the stuff you have may work better if cleaned and lubricated, and back in adjustment ..
You let it go too long..
1984ish Trek 500, rather than pour money into a pile of new components, Id look for a New Bike.
Want smooth shifting? NuVinci CVR 360, its an internal gear system hub
that is continuously variable from the lowest to highest ratio.
inherently smooth, because you just turn the grip till the pedal effort feels right ..
tomridestrek, Make sure what you have now is safe and reliable, go out for a few 2-3 hour rides on differing terrain and assess what changes, if any are merited. If you're reentering the sport of cycling there will be plenty of items to spend money on for yourself (clothing) and your bike (pumps, tube replacement/repair items, etc.).
Most updating for your bike will effect more than just a single component and can become expensive quickly. Optimize what is already there, and there are still plenty of quality parts and tires available for it's current configuration.
Brad
Brad
But as others have said, repack all the bearings, get the bike adjusted so that it shifts and stops correctly, get it fitted to your anatomy and ride it for a bit until it becomes apparent whehter you want to upgrade this bike, or save the money for a more modern steed.
Mechanic/Tourist
It may look brand new but still a good idea to check the chain for wear.
Liked 1,096 Times
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
That being said, I have upgraded the entire family fleet to modern drivetrain, starting with 1980s steel frame bikes. But I am on the resourceful side, do all the work myself, and find deals on donor bikes to provide all of the parts.
1984 Trek 500 came with a helicomatic rear hub. If your bike is a 1984, and the rear wheel is original, seven speeds is a non-starter (unless you change the rear wheel).
