Bianchi Reparto Corsa TSX: What should I do?
Bikes: 2001 Trek 5200 OCLV, 2013 Ritchey p650b, Bianchi Reparto Corsa TSX Frame...
Hi everyone,
I've been lurking for a while now. Helpful place!
Through a series of unfortunate eBay encounters, I have come into possession of a Bianchi Reparto Corsa TSX frame from the early 90s. It came with a worn set of Dura Ace 74xx series components which I promptly removed. The frame is my size and I must confess to being enamored with it: the color, the heritage and the craftsmanship.
I have a very nice 2001 Trek 5200 OCLV with Ultegra 6500 that I use now, but I like the idea of building up this Bianchi and getting it back on the road to compliment or perhaps replace the Trek. So my question is this: should I go for used period-correct components from Campagnolo or Shimano....or should I build this up with a fresh set of r8000 Ultegra? Positives and negatives to both directions. I'm curious what you would do in my place.
How bad of condition is the Dura Ace that came on it. If it were mine I’d try to use it, I love the 7400 series.
Semper fi
Semper fi
Likes For sloar:
The STI levers are cracked and the hoods are toast. The rear derailleur is broken and the chain rings are very worn. The wheels seem nice (7403 hubs with mavic rims). Brake calipers seem fine. Cranks seem fine too. All cables are toast. Bottom bracket is a mess.
Quoted: 4236 Post(s)
Liked 2,949 Times
I put 10 speed Campagnolo Triple parts on all of my classic frames, but that's just what works for me. Getting harder to find than they were though.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
Likes For himespau:
Crawlin' up, flyin' down
Quoted: 1027 Post(s)
Liked 2,531 Times
I'll go in reverse order of my personal preference. Keep in mind these are my opinions and they are worth exactly what you are paying for them.
My least favored option by far would be the modern Ultegra set. I have no doubt it works great, but I am an old phart who is set in his ways and I dislike (to put it mildly) the way it looks. I don't like the way modern groupsets look on modern frames, and I think they would look absolutely dreadful and out of place on a classic old Bianchi.
Next higher on my list would be going the period-correct route. I'd probably go Shimano because my sense is that they had their act together better than Campy did in that era. (Somebody will no doubt be along shortly to say how wrong wrong wrong I am about that.)
My top choice, one you did not mention, (hear me out on this) would be Campy 10sp. Veloce, Centaur, Chorus, Record - they all work well and the parts are interchangeable across the various models, not always true with Shimano. For me, it would be 10sp triple, not double, for the low gears. Either way, it looks good on a classic old frame, it works well, and everything will go on your frame seamlessly. You'd probably have to get the rear triangle spread to 130mm, but that is eminently doable. My favorite bikes have Campy 10spp triple and have had the rear triangles spread, so know it can be done with minimal effort beyond finding the parts.. [[i]Edit: I see himespau beat me to it. He is obviously a person of class and discernment.]
I'm glad to hear that you want to get that Bianchi back on the road. It deserves it.
Liked 2,949 Times
My top choice, one you did not mention, (hear me out on this) would be Campy 10sp. Veloce, Centaur, Choruis, Record - they all work well and the parts are interchangeable across the various models, not always true with Shimano. For me, it would be 10sp triple, not double, for the low gears. Either way, it looks good on a classic old frame, it works well, and everything will go on your frame seamlessly. You'd probably have to get the rear triangle spread to 130mm, but that is eminently doable. My favorite bikes have Campy 10spp triple and have had the rear triangles spread, so know it can be done with minimal effort beyond finding the parts.. [[i]Edit: I see himespau beat me to it. He is obviously a person of class and discernment.]
Likes For himespau:
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1226 Post(s)
Liked 3,554 Times
With an early 90's TSX, it probably doesn't even need the rear triangle spread. None of these are set up quite this way now (after getting hit the Concorde needs the rear triangle re-aligned, and the others have gone through several different build iterations/have different saddles/bars/etc. now), but these are some general ideas of 10 speed Campagnolo triple bits with frames of the rough era of your bike.
There were 135 Confentes, but only one...Huffente!
Bikes: Still have a few left!
Quoted: 467 Post(s)
Liked 532 Times
+1 on 10 speed Chorus: Also consider 8/9 spd Daytona/Centaur or Chorus, available for less $$, (sometimes even Record 8/9). I'm happy with Daytona 9 speed on my Masi. Don
1984 Masi
1984 Masi
Quoted: 1562 Post(s)
Liked 1,734 Times
Definitely not the R8000:
I would go for the Ultegra 6500 or Dura Ace 7700. Not period correct, but period close enough. Shimano components are a lot easier to come by than Campy. Check on your local Craigslist and see how many Shimano compatible wheelsets you can find vs Campy.
Yeah, fair point on the R8000 crank issues! From what I have read, Shimano is doing the right thing and replacing them with few questions asked. That said, I agree that they are ugly!
Ultegra 6500 and Dura Ace 7700 are easy to find on eBay. Not seeing as much on eBay for Campagnolo. Is that the best place to find a used groupset for this frame?
Likes For ujeni:
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,405 Times
On a similar age/quality Bianchi frameset, I used 10 speed Dura Ace with a compact Sugino crankset, downtube shifters and BL-R600 levers. Sublime.
Those 7403 hubs are lifetime bits if not damaged internally. Only limitation is a 12 tooth smallest cog.
Quoted: 800 Post(s)
Liked 753 Times
Likes For Piff:
Bikes: Teledyne Titan, Bob Jackson Audax Club, Bob Jackson World Tour, AlAn Record Ergal, 3Rensho Katana.
Quoted: 215 Post(s)
Liked 623 Times
Another vote for Dura-Ace, in my case all 7800 with the classic 7700 crankset, all triple, runs like a swiss watch.
Untitled by nemosengineer, on Flickr
: Mike
: Mike
Booyah Hubba-Hubba!!!
Making up the numbers
Quoted: 107 Post(s)
Liked 501 Times
c. 1997 Bianchi TSX Reparto Corse with Chorus 9-speed, Mavic Opens, PMP Ti seatpost, Ritchey WCS stem FWIW…
Nothing quite says wall hanger like drillium toe straps
Edumacator
Quoted: 2440 Post(s)
Liked 3,130 Times
6500 Ultegra is good stuff and looks pretty nice. Centaur stuff is also pretty awesome! Skeleton brakes are great stoppers. There is a century grey that looks great and if you can source a Campy-freehub one, Cosmos/Cosmic wheels in black would be a cool mix with it.
Quoted: 1608 Post(s)
Liked 2,216 Times
For my De Rosa Professional, I went with 10sp Record bits. they are not form the same year/model but work well for me.
De Rosa in Riding configuraton on Flickr
BigSmall on Flickr
I do like the aesthetics of the crank a lot better than Shimano DA of nearly any model.
The Pinarello Montello got the 9 speed Racing T application.
1991 Pinarello Montello - 9v Racing T on Flickr
P1050228 on Flickr
Both frames ae SLX
BigSmall on Flickr
P1050228 on Flickr
Both frames ae SLX
